Airspeed Indicator Markings
JetPilot
PostPosted: Thu Jan 25, 2007 7:12 am    Post subject: Airspeed Indicator Markings Reply with quote
I see in a lot of pictures you guys have nice, perfect looking white, red and green arcs on your airspeed indicators.
Being that every plane is different, im assuming that you put these markings on yourself ? How did you guys do this ?
Michael A. Bigelow
Kolb MK-III Xtra, 912-S
PostPosted: Thu Jan 25, 2007 8:03 am    Post subject: Airspeed Indicator Markings Reply with quote
| Michael A. Bigelow
Mike:
Most aircraft parts houses have sticky arcs available in kit form for
a reasonable price.
I did my instruments, as most other homebuilders have done.
ul15rhb(at)juno.com
PostPosted: Thu Jan 25, 2007 10:06 am    Post subject: Airspeed Indicator Markings Reply with quote
Get the sticky yellow, green, and red arcs from LEAF.
Ralph
Michael A. Bigelow
&quot;NO FEAR&quot; - If you have no fear you did not go as fast as
you could have !!!
http://forums.matronics.com/viewtopic.php?p=90358#90358
________________________________________________________________________
Interested in getting caught up on today's news?
Click here to checkout USA TODAY Headlines.
http://track.juno.com/s/lc?s=198954&u=http://www.usatoday.com/news/front.htm?csp 4
MKIIIX040
PostPosted: Thu Jan 25, 2007 1:18 pm    Post subject: Airspeed Indicator Markings Reply with quote
For enough income to actually pay rent and eat I do vinyl lettering
out of my home.
I can make arcs, circles, graphics, panel markings and letters from 1/4' to 24" any color.
Tell me what size,color and what you'd like to donate + postage.
You really should take advantage of this, I'm cheap!
I've also done many #'s & logos for models also.
Vic
MKX 912
Maine
MKIIIX040
912UL
knowvne(at)aol.com
PostPosted: Thu Jan 25, 2007 2:22 pm    Post subject: Airspeed Indicator Markings Reply with quote
Hey VIC
Saw you post on Vinyl lettering...
What would something like this run me???
Letters are to be applied to the windows of a truck shell...
They must fit across a 36 inch space......
So I'm not sure how large the font could be.... I'm guessing 1" maybe
1.25"
I was thinking it might end up being around 1" maybe 1.25" x 36"
Again just the letters without a background color.... Glass is smoke
black now...
Thanks..
Mark Vaughn
 Filesize:  69.53 KB
 Viewed:  596 Time(s)
Richard Pike
PostPosted: Thu Jan 25, 2007 3:07 pm    Post subject: Airspeed Indicator Markings Reply with quote
Vic, I never put the Kolb MKIII vinyl decal/sticker on my MKIII because it is the wrong color. If I sent it to you with a color swatch, could you do a couple clones of them in blue?
Richard Pike
MKIII N420P (420ldPoops)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
planecrazzzy
PostPosted: Thu Jan 25, 2007 4:00 pm    Post subject: Re: Airspeed Indicator Markings Reply with quote
Hi Mike,
I bought my arc's at ??? ACS&S or LEAF....
One thing to remember , If you look at the picture that I attached...
The Airworthiness Inspection requires the glass to be taped to the outer
ring.....Notice my Red Vne.....it overlaps.
Gotta Fly...
Mike & "Jaz" in MN
Michael A. Bigelow
 Filesize:  59.97 KB
 Viewed:  636 Time(s)
JetPilot
PostPosted: Thu Jan 25, 2007 5:35 pm    Post subject: Re: Airspeed Indicator Markings Reply with quote
Hi Mike,
That is the same ASI that I have ! Same ESI also. What is LEAF and also, where did you get the transparent decals with the lettering that give your V-Speeds and that says ESI warning ?
 Filesize:  168.45 KB
 Viewed:  579 Time(s)
planecrazzzy
PostPosted: Thu Jan 25, 2007 6:36 pm    Post subject: Re: Airspeed Indicator Markings Reply with quote
Hey Mike,
I'm a "Cheap" SOB....Those were typed on the computer, Then printed out....cut out....and "Taped"
( By the way , I changed those "V - Speeds" , I had some wrong )
That's another thing that they want for the Airworthiness inspection....
EVERYTHING LABELED....So until you get it the way you want it...
A quick solution is to type it , print it , Tape it...
Do you have the VSI in your EIS ? .....( I Love mine )
Well, it's Not LEAF...... it's L.E.A.F. I think there in Wiscosin....
I bought my Engine and prop from them...
Here's there address :
http://www.leadingedge-airfoils.com/
They have a catolog too , it's not as big as ACS&S
Gotta Fly...
Mike in MN
JetPilot wrote:
Hi Mike,
planecrazzzy
PostPosted: Fri Jan 26, 2007 8:27 am    Post subject: Re: Airspeed Indicator Markings Reply with quote
Hey Guys,
I'm amazed how so many people in our line of hobbie that
don't know about this book.....A packet for Homebuilts is "FREE" from the
FAA ....it's some guide lines to get yer plane in the air....
Here's a copy of the front cover , and page 11 , where they talk about
marking the glass on the instrument .....They say "paint" , but my Tape
worked to pass the inspection.
The book Number ....AC NO 90-89A
Gotta Fly...
Mike in MN
 Filesize:  606.99 KB
 Viewed:  605 Time(s)
 Filesize:  182.14 KB
 Viewed:  570 Time(s)
Michael Sharp
PostPosted: Fri Jan 26, 2007 9:19 am    Post subject: Airspeed Indicator Markings Reply with quote
You can get that guideline from the FAA website in PDF format... I have it if anyone would like me to forward it to you...
Mike
Oak Grove Missouri..
The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike
JetPilot
PostPosted: Sat Jan 27, 2007 6:22 am    Post subject: Re: Airspeed Indicator Markings Reply with quote
I downloaded it from the website. The computer, some paper, and clear tape will make great V speeds.
Thanks Mike !
planecrazzzy
PostPosted: Sat Jan 27, 2007 6:54 am    Post subject: Re: Airspeed Indicator Markings Reply with quote
Hey Mike,
If you notice , the important numbers are in RED....Stall & Vne
One of these days , I'm gonna have an Engraving Shop carve me one out of Plastic ( two tone) like name tags....Then I'll use a red Sharpie to
make the Stall & Vne in red....
Same with the other side where I have "Experimental N381PM"
it'll probly be cheap enough to replace them all with plastic ones...
After you find out "YOUR" stall speed , That book tells you how to figure
out the other "V speeds".....at least "ballpark"
The book is also handy for flight testing your plane....it gives pretty good
suggestions for flight plans....especially that first flight.
One thing the FAA guy wanted , that the book didn'y mention....
He wanted the CG in the "Front half" of the CG Range....
I had to drain my rear fuel tank ( re-plumb ) and also put 16 lbs in
the nose of the aircraft to get it .
Gotta Fly...
Mike & "Jaz" in MN
Thanks Mike !
