dan(at)azshowersolutions. Guest
Posted: Thu Nov 30, 2006 5:16 am Post subject: Beacon? Strobe? |
Has anyone found or know of a low profile beacon that could be fit to the top of the vertical Stab? What are others doing for this? I have a 912s, so the Amp draw needs to be kept low.
Still Building
Dan B
kirkhull(at)kc.rr.com Guest
Posted: Thu Nov 30, 2006 5:54 am Post subject: Beacon? Strobe? |
I made mine out of a tail light assembly with a wing tip lens and a heavy-duty turn signal flasher.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Dan Billingsley
Sent: Thursday, November 30, 2006 7:15 AM
To: kitfox-list
Subject: Beacon? Strobe?
Still Building
Dan B
| Quote: | | www.aeroelectric.com | 0123456789012345
106.34 KB |
249 Time(s) |
Posted: Thu Nov 30, 2006 5:27 pm Post subject: Beacon? Strobe? |
Kirk,
Thanks for the idea. I just can't stand the thought of paying Whellen $300 for a friken lightbulb. I found a source for high intensity LED's and plan to see what I can develop.
Dan
kirk hull <kirkhull(at)kc.rr.com> wrote:
| Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> st1\:*{behavior:url(#default#ieooui) } I made mine out of a tail light assembly with a wing tip lens and a heavy-duty turn signal flasher.
To: kitfox-list
<?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />Still Building
Dan B
roncarolnikko(at)hotmail. Guest
Posted: Thu Nov 30, 2006 6:29 pm Post subject: Beacon? Strobe? |
Dan go to Chief Aircraft or Aircraft Spruce. There are self contained
beacons for 50- 125.00. I found one on fleabay and mounted it on my
vertical stab. I used a plastic funnel cut to fit down over the stab, then
poured full of epoxy and chopped glass for a nice fairing/ mount. The low
profile thing is hard to achieve without needing a belly mount also. Ron NB
Ore
| Quote: | From: Dan Billingsley <dan(at)azshowersolutions.com>
To: kitfox-list <kitfox-list(at)matronics.com>
Date: Thu, 30 Nov 2006 05:15:25 -0800 (PST)
Still Building
Dan B
All-in-one security and maintenance for your PC. Get a free 90-day trial!
Posted: Thu Nov 30, 2006 7:30 pm Post subject: Beacon? Strobe? |
I had the same feeling and gutted the fixture and made a micarda insert that holds a 20 watt halogen bulb from the auto parts store ($1.50). The actual wheelen parts came from a junk pile at the local shop. LED’s would work great inside this type of fixture as they do not but out as much heat. Where are you getting your LED’s and how big are they?
Sent: Thursday, November 30, 2006 7:26 PM
Subject: RE: Beacon? Strobe?
Kirk,
Dan
To: kitfox-list
Still Building
Dan B
| Quote: | | www.buildersbooks.comwww.kitlog.com |
| Quote: | | www.homebuilthelp.com | 01234 |
56789012345678901234567890
kitfox(at)itsys3.com Guest
Posted: Thu Nov 30, 2006 8:52 pm Post subject: Beacon? Strobe? |
I went with the LEDs and constructed "bulbs" which fit into the
unmodified Whelen sockets. Sources, pictures, and specifics are
on my web site (about halfway down the page) at:
www.itsys3.com/kitfox/discover.shtml
Bill Hammond
Series 6 N913KF
Parker, Colorado
kirk hull wrote:
| Quote: | I had the same feeling and gutted the fixture and made a micarda insert
Kirk,
Dan
Billingsley
To: kitfox-list
Still Building
Dan B
www.kitlog.com
www.kitlog.com <http://www.kitlog.com>
Fox5flyer Guest
Posted: Fri Dec 01, 2006 3:37 am Post subject: Beacon? Strobe? |
Ron, as much as I tried, I can't get my feeble brain to visualize what you
described for a mounting. Can you try it from a different angle?
Deke
n113gb(at)yahoo.com Guest
Posted: Fri Dec 01, 2006 3:13 pm Post subject: Beacon? Strobe? |
Does anybody know what are the intensity minimums are for position/anti-collision lights per the FAA?
dosmythe(at)cox.net Guest
Posted: Fri Dec 01, 2006 3:31 pm Post subject: Beacon? Strobe? |
Gary,
That's a good question. Same question I tried to figure out about 8
years ago. I'm under the impression that the Aero Flash units did/do not
meet the minimums for FAA requirements. Maybe your question will have
better luck this time. Sorry, I'm still not sure. The only good part is,
an FAA inspector probably doesn't know either.
Don Smythe
Posted: Fri Dec 01, 2006 5:13 pm Post subject: Beacon? Strobe? |
There is an AC out dealing with that. I will try to find it
Posted: Fri Dec 01, 2006 5:28 pm Post subject: Beacon? Strobe? |
The info is in AC 20-30B that can be found on FAA.GOV under advisory
circulars or I have a 648 KB PDF that I can email if needed
pwmac(at)sisna.com Guest
Posted: Fri Dec 01, 2006 5:29 pm Post subject: Beacon? Strobe? |
Don't have the info you all want but a search of
the aeroelectric archives no doubt will yield the
data. They had a long thread on the subject.
Paul
At 03:31 PM 12/1/2006, you wrote:
Gary,
tried to figure out about 8 years ago. I'm
did/do not meet the minimums for FAA
sure. The only good part is, an FAA inspector probably doesn't know either.
Don Smythe
Posted: Fri Dec 01, 2006 5:49 pm Post subject: Beacon? Strobe? |
Deke I'll post an after picture. The funnel sits pointing downward as if in
use. the flat top is where the base of the light attaches. The spout and
part of the sides get cut off to form a channel which drops over the
vertical stab. Place plastic barrier over stab, then place funnel over,
then fill with epoxy. Remove, sand paint, walla. Sorry I don't have a
close up, but it flares to a flat spot like a Cessna. Ron NB Ore
[quote]From: "Fox5flyer" <fox5flyer(at)i-star.com>
Subject: Re: Beacon? Strobe?
Date: Fri, 1 Dec 2006 06:37:06 -0500
Deke
38.15 KB |
219 Time(s) |
Posted: Sat Dec 02, 2006 4:09 am Post subject: Beacon? Strobe? |
Kirk,
I am getting my LED's from http://www.superbrightleds.com/led_prods.htm
There are some good places on the web that help with how-to applications such as this one that has a calculator to determine the resistors used http://metku.net/index.html?sect=view&n=1&path=mods/ledcalc/index_eng
I have ordered several LED's to experiment with on small circuit boards. Will let all know how it goes.
Dan
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> st1\:*{behavior:url(#default#ieooui) } I had the same feeling and gutted the fixture and made a micarda insert that holds a 20 w halogen bulb from the auto parts store ($1.50). The actual wheelen parts came from a junk pile at the local shop. LED’s would work great inside this type of fixture as they do not but out as much heat. Where are you getting your LED’s and how big are they?
To: <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />kitfox-list(at)matronics.com
Kirk,
Dan
| Quote: | I made mine out of a tail light assembly with a wing tip lens and a heavy-duty turn signal flasher.
To: kitfox-list
<?xml:namespace prefix = u1 /> Still Building
Dan B
567890123456789012345678[quote][b]
Fox5flyer Guest
Posted: Sat Dec 02, 2006 4:18 am Post subject: Beacon? Strobe? |
Thanks Ron. I understand now.
Deke
