sschmidt(at)ussynthetic.c Guest
Posted: Thu Nov 09, 2006 12:36 pm Post subject: Thoughts after 35 hours |
I now have 35 hours on the RV-10 and everything has gone almost perfect.
I did want to point out the one issue that I did have about 6 hours ago and it may be something to look at. The tube that attaches on the left side of the baffles that feeds air to the oil cooler broke during flight. The ring has about 8 rivets in it but the tube is only tack welded in a couple of spots. My oil temps are normally around 185 and then they jumped to 213, it was still getting about ½ the air. Luckily it was 45 degrees out. I made four small brackets and reattached it so that it can’t break again. That is a pretty weak piece though, you may want to reinforce to begin with.
My #1 and #2 cylinders are running the hottest. I cut ¼” off the baffle that covers the #2 cylinder and it made a huge difference. Now #2 is 20 degrees cooler than #1. I am going to cut the other tonight.
I had a bad Grand Rapids oil pressure sensor that was replaced. It would read either zero or 99. I hooked up a mechanical sensor and it showed 65 psi at a high idle so I replaced it. Apparently, they have had some issues with them so watch for that.
One thing that I absolutely love is the throttle quadrant. I was afraid that I wouldn’t get the fine tuning that I thought push pull controls give but I find myself pulling the throttle and the prop back together and I can adjust them much quicker and with more accuracy than the push pulls. I would highly recommend it if you are on the fence.
The Cheltons are great but so are the Grand Rapids, I will have to write a side by side comparison as soon as I am more familiar with both. I am still tweaking the autopilot gains on both and learning the approach procedures on both. But I am very happy that I have the Cheltons, they are really nice.
I love how the plane fly’s with 3 or 4 people. With two you really need a little weight in the back to balance it out.
My only problem now is that I can’t stop flying long enough to paint the gear leg fairings.
Scott Schmidt
sschmidt(at)ussynthetic.com
Tim(at)MyRV10.com Guest
Posted: Thu Nov 09, 2006 1:09 pm Post subject: Thoughts after 35 hours |
Scott Schmidt wrote:
| Quote: | I now have 35 hours on the RV-10 and everything has gone almost perfect.
Thanks for the post on this Scott, you've given me something
else to check on. Haven't had a problem yet, but I better
at least inspect mine.
You're finding exactly what I did. Now for more info..... I ended
up cutting a LOT more off than original. I haven't taken any
photos of the latest yet, but I'll describe...
On the outside ends of the plate, I have it trimmed very short,
tapering higher as you go towards the engine. It's maybe 3/8"
tall on the skinny end, and I've probably cut almost half of the
baffle off on the inside now. The top of the cylinder head
is probably the hottest, and those higher up fins didn't get
hardly any airflow with the baffle in place. It's very
hard to describe without photos, so I'll try to remember to take
some and add them to my cooling page soon. Vic removed his
altogether, so don't worry too much about cutting them down
about half of their original size. It improved each time I cut.
Now #1/2/5/6 are all similar.
I had a bad oil temp probe from them.
Once again, you're finding EXACTLY the same thing that I did.
People who claim they want push-pulls for better fine tuning
really need to fly the quadrant. It's very superior to
the push-pulls I flew in Van's -10's...wouldn't you agree?
They are awesome, and I can quickly get within 10 RPM, or
.1 or 2 MP, and then a little nudge finishes the job. I am
far more precise flying my quadrant than those dang push
pulls in 220RV that made me look like a bumbling idiot.
Like I said, people might have preconceived notions that
the push pulls are more precise, but FLY THE QUADRANT and
compare to the push pulls from Van's and you'll know.
are really nice.
What can I say....you're only going to get more impressed.
Call me some night and I'll fill you in on some more neat
stuff. Like try the MENU - PEAKS ON using the engine page,
and then lean to peak once. Also, MENU - FUNCTION (or is it
FORMAT...the top one) and don't choose MAP, but try the
other options...there's a great route data page there.
I still get amazed even after 170 hours when I find new
cool things. What you REALLY REALLY need to do is go
fly with someone who's really good with the Cheltons.
You'll walk away with your mouth open and jaw hanging down.
And I think you get more speed with 4 too, as long as
they're not fatties.
gear leg fairings.
HA!!!!! Now THAT I can absolutely buy into....that was so
painful to have to do the wheel and leg fairings after
first flight....it was just AWFUL. It would have seemed
much easier and quicker if I did it before I flew. Your
mental state changes drastically!
Thanks for the report Scott, I'm glad to see that I'm
not going down the path alone! Again, if you ever
want to chit-chat, you've got my number. Perhaps we'll
have to take a boring weekend and meet in the middle
somewhere soon. I learned the hard way though when
flying to Vegas that I really have no desire to ever
fly over Nebraska again....so let's plan a little
bit cooler route. (Sorry Dean, and you other
Nebraska-ins, but man, there's not much out there in
some places.)
Have fun!
ddddsp1(at)juno.com Guest
Posted: Thu Nov 09, 2006 2:19 pm Post subject: Thoughts after 35 hours |
NOTHING in Nebraska?...........I usually read these post and blow most of the snipes off....but not when you DIG on Nebraska. LOL. I will give both your families ROOM and BOARD if you meet in Grand Island, Nebraska to check each others planes. It is a 2.5 hour flight for Tim and a 3.8 hour flight(tailwind) for Scott to GI, NE. Plus 100LL is down to $3.17 per gal.
Scott, I put a nice bead of PROSEAL around the oil cooler flange as I did not like the tack welds on it either. I also put Proseal on the flange to seal/cushion it to the baffling. I love Proseal!!!!
OK, with Free room and board and cheap gas............is it more enticing to come to NE now TIM?
You guys still make me envious when you discuss your flying... BUT, 805HL will be flying with the best YUGO panel ever .....SOON.
Open invitation,
Dean 40449
________________________________________________________________________
Visit http://www.juno.com/value to sign up today!
jesse(at)itecusa.org Guest
Posted: Thu Nov 09, 2006 3:06 pm Post subject: Thoughts after 35 hours |
I know Nebraska is a little closer to the middle than central Florida, but the offer stands (the room and board offer) if you decide to meet here as well. And hey, the gas here is $3.10 and possibly dropping again in the next couple of days. $.07 cheaper gas and the enjoyment of flying an extra 3 hours each average (one way, of course). What could beat that?
That offer stands for anybody flying a -10 through here. We would love to look at your plane and put you up for a night.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ddddsp1(at)juno.com
Sent: Thursday, November 09, 2006 5:17 PM
Subject: Re: Thoughts after 35 hours
Open invitation,
Dean 40449
Visit http://www.juno.com/value to sign up today! | Quote: | | www.aeroelectric.com | 0123456789012345
-- Date: 11/9/2006
No virus found in this outgoing message.
11/9/2006
Posted: Thu Nov 09, 2006 6:07 pm Post subject: Thoughts after 35 hours |
Scott, (and all)...
I just wanted to let you know that regarding the baffle in front
of cylinders #1 and #2, I have taken some photos tonight and
updated the page at:
http://www.myrv10.com/N104CD/maintenance/20061022/index.html
You may want to take a peek before heading to the hanger again,
as I'm betting you can further improve your #1 and #2 cylinders.
are really nice.
gear leg fairings.
Scott Schmidt
Posted: Thu Nov 09, 2006 6:12 pm Post subject: Thoughts after 35 hours |
Hey Dean, I was wondering if you were going to catch that.
Yeah, it was boring and flat, but I'm not sure if that's what
it's like where you are located. It's close enough though to
make an easy stop, or whatever to meet up with Scott.
Looks like the gas prices are dropping from yours and Jesse's
replies. Gas at my airport only briefly went to $3.90 this
year, but quickly dropped back down to $3.20 where it has been
for a while. It's hard to actually believe you feel *good* when
you're *only* paying $3.20 per gallon....
I like your idea of proseal around that flange. It's not really
structural, but it should could easily help prevent it from
cracking the welds and falling off, so it's probably a great
idea for people to do.
I can't wait to hear when your first flight is coming. Shoot
an email as you have projected dates...if the weather is good
and I'm bored, it might make a good bit of entertainment to
come down there and watch.
ddddsp1(at)juno.com wrote:
| Quote: | NOTHING in Nebraska?...........I usually read these post and blow most
to $3.17 per gal.
Open invitation,
Dean 40449
Ray.R.Doerr(at)sprint.com Guest
Posted: Fri Nov 10, 2006 7:29 am Post subject: Thoughts after 35 hours |
I sent my baffle with the oil cooler ring on it to our local airport welder to weld the ring completely around the perimeter of it. There is no way it is coming apart now. Van's really needs to have this welded better.
Thank You
Ray Doerr
40250
N519RV Flying with 166 hours and still no paint or wheel pants. Just too much fun to fly.
jjessen
Posted: Fri Nov 10, 2006 7:59 am Post subject: Thoughts after 35 hours |
Anyone explain this to Van's?
John J
Posted: Fri Nov 10, 2006 12:36 pm Post subject: Thoughts after 35 hours |
I haven't said anything yet, but I will shoot them an e-mail.
Scott Schmidt
