tinnemaha
Joined: 23 Mar 2008 Posts: 3 Location: Central Coast of CA
Posted: Sun Aug 04, 2019 8:02 am Post subject: ADSB Antenna Location |
I fly a Series 5 tail dragger & have decided to upgrade my transponder to make the plane ADS-B Compliant; My existing GPS antenna is not WAAS so I've got to add a 2nd one; Where is the best place to mount it?
Grant Krueger
Northern CA
wa0ysf(at)gmail.com Guest
Posted: Sun Aug 04, 2019 8:39 am Post subject: ADSB Antenna Location |
I have mine mounted in the center of the skylight, beside the GPS antenna for my KLX-135A. I am using the Appero ESG transponder.
Harold McConnell
Kitfox 3, 582
NE North Dakota
Sent from Mail for Windows 10
Sent: Sunday, August 4, 2019 11:06 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: ADSB Antenna Location
Grant Krueger
Northern CA
grantbright(at)att.net Guest
Posted: Sun Aug 04, 2019 10:13 am Post subject: ADSB Antenna Location |
The GPS antenna needs a ground plane. We mounted ours 3 feet from the comm antenna, on the bottom on an aluminum plate secured with clamps, to the frame, tested out fine.
Safe flying,
Grant
Date: 8/4/19 12:37 PM (GMT-05:00)
Subject: RE: Kitfox-List: ADSB Antenna Location
Harold McConnell
Kitfox 3, 582
NE North Dakota
Subject: Kitfox-List: ADSB Antenna Location
Grant Krueger
Northern CA
Posted: Sun Aug 04, 2019 11:07 am Post subject: ADSB Antenna Location |
I should have said, the adsb antenna needs a ground plain because it transmits.
Sorry for the mistake.
Grant
Date: 8/4/19 2:11 PM (GMT-05:00)
Safe flying,
Grant
Harold McConnell
Kitfox 3, 582
NE North Dakota
Grant Krueger
Northern CA
Kellym
Posted: Sun Aug 04, 2019 4:17 pm Post subject: ADSB Antenna Location |
It depends what unit you install. If you do one of the uAvionics
products, either wingtip or tail, they include the GPS and you won't
need another antenna. Of course if you didn't install nav lights to
begin with, might be extra effort to run the power lead.
On 8/4/2019 11:11 AM, grantbright wrote:
| Quote: | The GPS antenna needs a ground plane. We mounted ours 3 feet from the
Safe flying,
Grant
Subject: RE: ADSB Antenna Location
Harold McConnell
Kitfox 3, 582
NE North Dakota
Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
Windows 10
*From: *Tinnemaha - <mailto:tinnemaha(at)hotmail.com>
*Sent: *Sunday, August 4, 2019 11:06 AM
*To: *kitfox-list(at)matronics.com <mailto:kitfox-list(at)matronics.com>
*Subject: *ADSB Antenna Location
to make the plane ADS-B Compliant;Â My existing GPS antenna is not WAAS
Grant Krueger
Northern CA
KCHD |
