		tinnemaha
  Joined: 23 Mar 2008 Posts: 3 Location: Central Coast of CA
				 Posted: Sun Aug 04, 2019 8:02 am    Post subject: ADSB Antenna Location |
				I fly a Series 5 tail dragger & have decided to upgrade my transponder to make the plane ADS-B Compliant;  My existing GPS antenna is not WAAS so I've got to add a 2nd one; Where is the best place to mount it?
   Grant Krueger
  Northern CA
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		wa0ysf(at)gmail.com Guest
				 Posted: Sun Aug 04, 2019 8:39 am    Post subject: ADSB Antenna Location |
				I have mine mounted in the center of the skylight, beside the GPS antenna for my KLX-135A.  I am using the Appero ESG transponder.
 Harold McConnell
 Kitfox 3, 582
 NE North Dakota
 Sent from Mail for Windows 10
 Sent: Sunday, August 4, 2019 11:06 AM
 To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
 Subject: ADSB Antenna Location
 Grant Krueger
 Northern CA
		grantbright(at)att.net Guest
				 Posted: Sun Aug 04, 2019 10:13 am    Post subject: ADSB Antenna Location |
				The GPS antenna needs a ground plane. We mounted ours 3 feet from the comm antenna, on the bottom on an aluminum plate secured with clamps, to the frame,  tested out fine.
 Safe flying,
 Grant
 Date: 8/4/19  12:37 PM  (GMT-05:00)
 Subject: RE: Kitfox-List: ADSB Antenna Location
 Harold McConnell
 Kitfox 3, 582
 NE North Dakota
 Subject: Kitfox-List: ADSB Antenna Location
 Grant Krueger
 Northern CA
				 Posted: Sun Aug 04, 2019 11:07 am    Post subject: ADSB Antenna Location |
				I should have said,  the adsb antenna needs a ground plain because it transmits.
 Sorry for the mistake.
 Grant
 Date: 8/4/19  2:11 PM  (GMT-05:00)
 Safe flying,
 Grant
 Harold McConnell
 Kitfox 3, 582
 NE North Dakota
 Grant Krueger
 Northern CA
		Kellym
				 Posted: Sun Aug 04, 2019 4:17 pm    Post subject: ADSB Antenna Location |
				It depends what unit you install. If you do one of the uAvionics
 products, either wingtip or tail, they include the GPS and you won't
 need another antenna. Of course if you didn't install nav lights to
 begin with, might be extra effort to run the power lead.
 On 8/4/2019 11:11 AM, grantbright wrote:
  	  | Quote: | 	 		   The GPS antenna needs a ground plane. We mounted ours 3 feet from the
  Safe flying,
  Grant
  Subject: RE: ADSB Antenna Location
  Harold McConnell
  Kitfox 3, 582
  NE North Dakota
  Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
  Windows 10
  *From: *Tinnemaha - <mailto:tinnemaha(at)hotmail.com>
  *Sent: *Sunday, August 4, 2019 11:06 AM
  *To: *kitfox-list(at)matronics.com <mailto:kitfox-list(at)matronics.com>
  *Subject: *ADSB Antenna Location
  Grant Krueger
  Northern CA
KCHD |
