Building Coax
Paul Valovich
PostPosted: Thu Jan 10, 2019 6:31 am    Post subject: Building Coax Reply with quote
When building a coax cable can I use a male D-sub pin instead of the pin supplied in the connector bag?
Tried to crimp those pins with a D-sub crimper and it didn’t go well. I now have extra connectors with no pins.
echristley(at)att.net
PostPosted: Thu Jan 10, 2019 7:27 am    Post subject: Building Coax Reply with quote
You could use a piece of clipped off a paperclip if you could get it to stick. The problem is reliability.
Those pins are designed to "click" inside the connector, or be seal with a silicone o-ring. Until moisture seeps in, just leaving the center wire sticking out will work just as well as the crimped pin. Getting the connector to go together without bending the center wire and destroying the connection . . let's say I've done it, but don't really want to do it again.
I'm pretty sure you can get just the pins fairly cheap.
On Thursday, January 10, 2019, 9:32:33 AM EST, Valovich, Paul <pvalovich(at)dcscorp.com> wrote:
PostPosted: Thu Jan 10, 2019 8:38 am    Post subject: Building Coax Reply with quote
the connectors are cheap.
https://tinyurl.com/yd4z7gta
throw the first one away and start over.
Mauledriver(at)nc.rr.com
PostPosted: Thu Jan 10, 2019 9:43 am    Post subject: Building Coax Reply with quote
On 1/10/2019 9:30 AM, Valovich, Paul wrote:
<![endif]--> <![endif]-->
I had a similar situation.  I substituted a D-sub pin and it seems to have worked well.
With that said, I'm ordering some extra pins for my remaining orphan plugs per Bob's post.
Question: What is one supposed to crimp those pins with?  The D-sub crimper?
www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
rick(at)beebe.org
PostPosted: Thu Jan 10, 2019 10:36 am    Post subject: Building Coax Reply with quote
There is, of course, a specialty crimper. The ratchet crimper I have has small holes for crimping the pin and then a larger hole to crimp the ferrule. Something like https://tinyurl.com/y7tv4jzl
--Rick
PostPosted: Thu Jan 10, 2019 10:57 am    Post subject: Building Coax Reply with quote
The tool you crimped the hex-sleeve should
have a die for pins
[img]cid:7.1.0.9.0.20190110124906.05e98e10(at)aeroelectric.com.0[/img]
See https://tinyurl.com/y7to3wnb
 Filesize:  66.92 KB
 Viewed:  6975 Time(s)
PostPosted: Thu Jan 10, 2019 11:03 am    Post subject: Building Coax Reply with quote
NOT A GOOD IDEA. The pin retaining mechanism
for these two technologies could not be more
different. Further, the d-sub pin o.d. is
0.040" while the BNC pin o.d. is 0.052"
NOT a good match.
scuperhead
PostPosted: Thu Jan 10, 2019 11:20 am    Post subject: Building Coax Reply with quote
Hi Bob,
Could you remove me from the email notification portion of the list?
Thank you,
Craig Schulze
From: <owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)> on behalf of "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Reply-To: <aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)>
Date: Thursday, January 10, 2019 at 11:02 AM
Subject: Re: Building Coax
NOT a good match.
Blue Skies,
Craig
PostPosted: Fri Jan 11, 2019 9:53 am    Post subject: Building Coax Reply with quote
  NOT a good match.
I'll get that fixed!  Thanks as always.
