lock-wiring 912 sump banjo bolt
rowlandcarson(at)gmail.co
PostPosted: Sun Nov 18, 2018 10:31 am    Post subject: lock-wiring 912 sump banjo bolt Reply with quote
I’m about to adjust the position of the oil sump banjo on my 912S, as advised in the Europa FWF manual. I note that the head of the banjo bolt is drilled and so I will lock-wire it after re-positioning the banjo. But I can’t see any handy place nearby on which to anchor the lock-wire. Does anyone have any suggestions, or have I missed something really obvious? (quite likely!)
in friendship
Rowland
Richard Wheelwright
PostPosted: Sun Nov 18, 2018 11:59 am    Post subject: lock-wiring 912 sump banjo bolt Reply with quote
Hi Rowland
There should be a small hole along the sump seam close to the banjo. There is on my engine
Richard
in friendship
Rowland
Richard Wheelwright
G-IRPW
First Flight 24th July 2013
roddyeuropa(at)aol.com
PostPosted: Sun Nov 18, 2018 10:57 pm    Post subject: lock-wiring 912 sump banjo bolt Reply with quote
Hi Roland
Long wirelock up to the lower Jubilee clip that holds the oil tank onto its bracket works.
Roddy Kesterton
G-IKRK
Nigel Graham
PostPosted: Mon Nov 19, 2018 3:35 am    Post subject: Re: lock-wiring 912 sump banjo bolt Reply with quote
Richard is correct - in fact there are two holes !
 Filesize:  1.52 MB
 Viewed:  8244 Time(s)
Nigel Graham
PostPosted: Mon Nov 19, 2018 3:52 am    Post subject: Re: lock-wiring 912 sump banjo bolt Reply with quote
........................at the front, and one at the rear.
.... good recovery I thought Wink
 Filesize:  1.5 MB
 Viewed:  8232 Time(s)
Rowland_Carson
PostPosted: Mon Nov 19, 2018 3:31 pm    Post subject: Re: lock-wiring 912 sump banjo bolt Reply with quote
[quote="Richard Wheelwright"]
[/quote]
And there is on mine too! How did I miss that when I first looked???
Thanks for the advice and for not calling me an idiot!
in friendship
Rowland
PostPosted: Mon Nov 19, 2018 4:08 pm    Post subject: lock-wiring 912 sump banjo bolt Reply with quote
On 2018-11-19, at 23:31, Rowland_Carson <rowil(at)clara.net> wrote:
[snip]
Don’t know how the Matronics list still has that e-mail address - it stopped being used many years ago - so please don’t use it. It’s <rowlandcarson(at)gmail.com> to reach me now.
in friendship
Rowland
