rayeaker(at)gmail.com Guest
Posted: Wed Jun 07, 2017 5:45 am Post subject: SL-70 Install /Configuration issues -> Installation Manual |
I found what appears to be a 2003 manual that does not mention the R version.
http://rv7-a.com/manuals/SL40Comm_InstallationManual.pdf
Per this manual, you should be using the following RS232 settings:
9600, 8, 1, None
On Wed, Jun 7, 2017 at 8:30 AM, Ralph E. Capen <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:
| Quote: | --> Avionics-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)>
Working on an installation/configuration issue related to my SL-70.
The latest Installation Manual I have is dated October 1999 and does not reference how to enable the EXTended mode or that it is available. It is available in the software in my SL-70 and I have been provided instructions to successfully enable the EXTended mode - but I would like to know if there are any other differences outlined in a later manual. Software currently in the SL-70 is MICR 015 and FPGA 1.1 from the set-up screen and offers the EXTended mode option in the configuration. Does anyone out there have a later version of the SL-70 Installation Manual?
I want to make sure it is working properly while helping my ADSB equipment vendor! The SL-70 Installation Manual references the Altitude message only. I have the SL-70R manual dated September 2003 and there are enough
differences that I am confident it does NOT fully apply to the SL-70! The SL-70R Installation Manual references the EXTended mode and "Mode" messages that are transmitted when the EXTended mode is enabled...hopefully, this info is also present in a later version of the SL-70 Installation Manual.
Does anyone out there know how to 'capture' the RS-232 data as it is transmitted from the SL-70 in a readable format? I have a serial port on my computer connected to the TX pin from the SL-70 and set to 1200, 8, 1, N in HYPERTERM (old Windows software). It does capture the 'bursts' of data but the results are unintelligible on the software screen. The SL-70 Install Manual gives me a good idea about what I 'should' be seeing. Maybe I need special settings or special software!
Any help or suggestions greatly appreciated!
Ralph Capen
r> nics-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Avionics-List
WIKI -
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Posted: Wed Jun 07, 2017 6:44 am Post subject: SL-70 Install /Configuration issues -> Installation Manual |
Oooops!!!!
I would still expect you want to use 9600 for baud, since most Garmin equipment uses that speed.
On Wed, Jun 7, 2017 at 10:28 AM, Ralph E. Capen <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:
[quote]--> Avionics-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)>
Thanks - that is a manual for the SL-40 comm radio - not the SL-70 Transponder...I grabbed it anyway though!
Dave Burnham
Joined: 04 Jul 2011 Posts: 6 Location: Huntsville, AL
Posted: Wed Jun 07, 2017 6:54 am Post subject: SL-70 Install /Configuration issues -> Installation Manual |
Ralph,
Here is the install info from 2003.
Got SL70R sitting in a box if needed.
Dave Burnham
N64FN
On Wed, Jun 7, 2017 at 9:28 AM, Ralph E. Capen <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:
sl70-install-rev0a.pdf |
481.84 KB |
883 Time(s) |
sl70-op-rev0.pdf |
352.98 KB |
1112 Time(s) |
sl70R-ins_560-0408-01.pdf |
444.23 KB |
2281 Time(s) |
_________________ DJB - RV64FN |
