JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Sun Aug 16, 2015 6:10 am Post subject: Bending copper (bus) bar |
Hi Guys
I'll be using the almost (standard) method for connecting the battery contactor to starter contactor on a Rv9a with copper bar, also using a lighter gauge copper bar from the live feed to the ammeter shunt, this requires a bend in the copper bar: should copper bar be bent cold or with heat applied
Posted: Sun Aug 16, 2015 8:07 am Post subject: Bending copper (bus) bar |
At 09:10 AM 8/16/2015, you wrote:
| Quote: | --> AeroElectric-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com>
Hi Guys
I'll be using the almost (standard) method for connecting the battery contactor to starter contactor on a Rv9a with copper bar, also using a lighter gauge copper bar from the live feed to the ammeter shunt, this requires a bend in the copper bar: should copper bar be bent cold or with heat applied |
What are the dimensions of the "bar"?
I usually make such parts from 0.06 to 0.09
material and just bend it cold over a not-sharp
radius . . . ~ 1/8"
Bob . . . [quote][b]
stuart(at)stuarthutchison Guest
Posted: Sun Aug 16, 2015 8:33 am Post subject: Bending copper (bus) bar |
If you bend thin material once with a blunt radius, say 1/8”, then cold is fine. If you do more bending it will work harden and may crack under stress and vibration. In difference to steel, annealing copper is achieved by heating to cherry hot and quenching in water or oil.
| Quote: | On 16 Aug 2015, at 18:10, JOHN TIPTON <jmtipton(at)btopenworld.com> wrote:
Hi Guys
http://forums.matronics.com/viewtopic.php?p=446020#446020
Posted: Sun Aug 16, 2015 8:34 am Post subject: Bending copper (bus) bar |
If you bend thin material once with a blunt radius, say 1/8�, then cold is fine. If you do more bending it will work harden and may crack under stress and vibration. In difference to steel, annealing copper is achieved by heating to cherry hot and quenching in water or oil.
Cheers, Stu
Hi Guys
JOHN TIPTON
Posted: Sun Aug 23, 2015 6:13 am Post subject: Re: Bending copper (bus) bar |
The copper bar is 2mm (0.08inch) - so bend cold over a not too sharp (vice) edge
Bob (and all)
