Bending copper (bus) bar
JOHN TIPTON
PostPosted: Sun Aug 16, 2015 6:10 am    Post subject: Bending copper (bus) bar Reply with quote
Hi Guys
I'll be using the almost (standard) method for connecting the battery contactor to starter contactor on a Rv9a with copper bar, also using a lighter gauge copper bar from the live feed to the ammeter shunt, this requires a bend in the copper bar: should copper bar be bent cold or with heat applied
John
PostPosted: Sun Aug 16, 2015 8:07 am    Post subject: Bending copper (bus) bar Reply with quote
At 09:10 AM 8/16/2015, you wrote:
--> AeroElectric-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com>
Hi Guys
What are the dimensions of the "bar"?
I usually make such parts from 0.06 to 0.09
material and just bend it cold over a not-sharp
radius . . . ~ 1/8"
Bob . . . [quote][b]
stuart(at)stuarthutchison
PostPosted: Sun Aug 16, 2015 8:33 am    Post subject: Bending copper (bus) bar Reply with quote
If you bend thin material once with a blunt radius, say 1/8”, then cold is fine. If you do more bending it will work harden and may crack under stress and vibration. In difference to steel, annealing copper is achieved by heating to cherry hot and quenching in water or oil.
On 16 Aug 2015, at 18:10, JOHN TIPTON <jmtipton(at)btopenworld.com> wrote:
Hi Guys
John
http://forums.matronics.com/viewtopic.php?p=446020#446020
PostPosted: Sun Aug 16, 2015 8:34 am    Post subject: Bending copper (bus) bar Reply with quote
If you bend thin material once with a blunt radius, say 1/8�, then cold is fine. If you do more bending it will work harden and may crack under stress and vibration. In difference to steel, annealing copper is achieved by heating to cherry hot and quenching in water or oil.
Cheers, Stu
Hi Guys
John
JOHN TIPTON
PostPosted: Sun Aug 23, 2015 6:13 am    Post subject: Re: Bending copper (bus) bar Reply with quote
The copper bar is 2mm (0.08inch) - so bend cold over a not too sharp (vice) edge
Bob (and all)
John
