motor mounts
Herbgh(at)nctc.com
PostPosted: Fri Jun 05, 2015 2:11 pm    Post subject: motor mounts Reply with quote
Talking to Travis...He indicated that motor mounts cost 45 bucks each..
$180 the set.
Here is my solution. I noticed that the Trike that I bought had the
two part rubber style...and having a box of those...I decided to make
use of them on the Firefly...Just a square of 6061 with 4 holes and a
large hole to accommodate the rubber through mount.... I have new ones
but managed to use some older ones , will change them out later on. Free
vs 180 bucks...I can handle that...
Frugal Herb
ps first pic shows the 503 mounted on a trike frame...second shows one
of the Firefly mounts...
 Filesize:  183.07 KB
 Viewed:  3784 Time(s)
 Filesize:  1.46 MB
ceengland7(at)gmail.com
PostPosted: Fri Jun 05, 2015 4:34 pm    Post subject: motor mounts Reply with quote
each.. $180 the set.
the two part rubber style...and having a box of those...I decided to
make use of them on the Firefly...Just a square of 6061 with 4 holes
and a large hole to accommodate the rubber through mount.... I have
new ones but managed to use some older ones , will change them out
later on. Free vs 180 bucks...I can handle that...
Frugal Herb
~3/8" bolts?
http://www.ebay.com/itm/250685285419?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Charlie
Herbgh(at)nctc.com
PostPosted: Fri Jun 05, 2015 4:53 pm    Post subject: motor mounts Reply with quote
7 dollars and change at Aircraft Spruce....37 and change for a set
including shipping...
> Frugal Herb
> one of the Firefly mounts...
~3/8" bolts?
Charlie
