Herbgh(at)nctc.com Guest
Posted: Fri Jun 05, 2015 2:11 pm Post subject: motor mounts |
Talking to Travis...He indicated that motor mounts cost 45 bucks each..
$180 the set.
Here is my solution. I noticed that the Trike that I bought had the
two part rubber style...and having a box of those...I decided to make
use of them on the Firefly...Just a square of 6061 with 4 holes and a
large hole to accommodate the rubber through mount.... I have new ones
but managed to use some older ones , will change them out later on. Free
vs 180 bucks...I can handle that...
Frugal Herb
ps first pic shows the 503 mounted on a trike frame...second shows one
of the Firefly mounts...
183.07 KB |
3735 Time(s) |
1.46 MB |
3735 Time(s) |
ceengland7(at)gmail.com Guest
Posted: Fri Jun 05, 2015 4:34 pm Post subject: motor mounts |
On 6/5/2015 5:10 PM, Herb wrote:
each.. $180 the set.
the two part rubber style...and having a box of those...I decided to
make use of them on the Firefly...Just a square of 6061 with 4 holes
and a large hole to accommodate the rubber through mount.... I have
new ones but managed to use some older ones , will change them out
later on. Free vs 180 bucks...I can handle that...
Frugal Herb
~3/8" bolts?
http://www.ebay.com/itm/250685285419?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Posted: Fri Jun 05, 2015 4:53 pm Post subject: motor mounts |
7 dollars and change at Aircraft Spruce....37 and change for a set
including shipping...
On 06/05/2015 07:36 PM, Charlie England wrote:
> Frugal Herb
> one of the Firefly mounts...
~3/8" bolts?
