frank goodnight
Posted: Wed Jan 14, 2015 6:56 am Post subject: Form blocks |
Making some form blocks and
have forgotten what angle to cut
the edges so the flanges will spring
back and end up at 90 degrees. Using
.025-- 6061T6. Would someone with
A better (younger) memory please
enlighten me. Thanks
Frank
frank goodnight
Posted: Wed Jan 14, 2015 7:27 am Post subject: Form blocks |
On Jan 14, 2015, at 8:52 AM, Frank <frank.goodnight(at)att.net> wrote:
| Quote: | Making some form blocks and
Frank
rickofudall
Posted: Sat Jan 17, 2015 7:42 am Post subject: Form blocks |
Frank, For the life of me I cannot find the little book on calculating spring back that I was given when I worked in the Cessna tooling machine shop years ago. My gut says that you need 4 degrees of compensation, but without my spring back and bend allowance book. I did find this:
http://www.custompartnet.com/calculator/bending-springback
Using their calculator it comes out to 2.3 degrees
Rick Girard
On Wed, Jan 14, 2015 at 8:52 AM, Frank <frank.goodnight(at)att.net (frank.goodnight(at)att.net)> wrote:
| Quote: | --> Kolb-List message posted by: Frank <frank.goodnight(at)att.net (frank.goodnight(at)att.net)>
Frank
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List
Believe those who are seeking the truth, doubt those who find it.
-Andre Gide
Richard Pike
Posted: Sat Jan 17, 2015 4:35 pm Post subject: Re: Form blocks |
From Tony Bingelis' book "Sportplane Construction Techniques."
158.58 KB |
7657 Time(s) |
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
frank goodnight
Posted: Wed Jan 21, 2015 8:25 am Post subject: Form blocks |
Thanks Richard,
I seem to remember seething about
7degrees.gues I will know soon as I cut one.
Frank
On Jan 17, 2015, at 9:41 AM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
[quote]Frank, For the life of me I cannot find the little book on calculating spring back that I was given when I worked in the Cessna tooling machine shop years ago. My gut says that you need 4 degrees of compensation, but without my spring back and bend allowance book. I did find this:
Rick Girard
-Andre Gide
ctric.com
| Quote: | www.buildersbooks.com
uilthelp.com
otstore.com
matronics.com/contribution
cs.com
