New Andair Fuel Valve.
zackrv8
PostPosted: Thu Aug 17, 2006 4:26 pm    Post subject: New Andair Fuel Valve. Reply with quote
Guys,
At Oshkosh, I ordered the new Andair valve (FS20X7) (http://www.andair.co.uk/system/index.html) for my RV10. When I got home, I read Tim Olson's site and the problems he had with clearance with the male AN fittings. So, I sent an email to Andy and told him of the clearance problem on the RV10 with that valve.
I was expecting him to send me a valve with female ends on it so that I could put my own 90 degree el's on it. Instead, he sent me this. Check out the pics below.
Zack
 Filesize:  39.85 KB
 Viewed:  989 Time(s)
 Filesize:  44.16 KB
 Viewed:  1009 Time(s)
 Filesize:  40.63 KB
 Viewed:  937 Time(s)
 Filesize:  42.14 KB
 Viewed:  949 Time(s)
RV8 #80125
RV10 # 40512
carl.froehlich(at)cox.net
PostPosted: Thu Aug 17, 2006 5:04 pm    Post subject: New Andair Fuel Valve. Reply with quote
What part number goes with this?
Carl
Tim(at)MyRV10.com
PostPosted: Thu Aug 17, 2006 5:18 pm    Post subject: New Andair Fuel Valve. Reply with quote
Zack, the photos didn't come through. You may want to try again
or I can post photos if nothing else works. Just to clarify
though, the FS20X7 I don't think was the part I used...if I
remember right. I think that was the new Y oriented valve,
right?
Good luck, you'll like the Andair valves.
Tim
zackrv8 wrote:
Guys,
Zack
Neal George
PostPosted: Thu Aug 17, 2006 5:34 pm    Post subject: New Andair Fuel Valve. Reply with quote
Carl -
The complete part number for the valve pictured is FS20X7T
FS = Fuel Selector
20 = line diameter in 1/2-mm increments (10mm is about 3/8" or AN6)
X = Male AN6 outlet fitting. Female outlet would be "F"
T = 90-deg elbow AN6 inlet fittings. Or "M" for male, "F" for female.
Neal E. George
2023 Everglades Drive
Navarre, FL 32566
Home - 850-515-0640
Cell - 850-218-4838
Carl
Neal George
PostPosted: Thu Aug 17, 2006 5:45 pm    Post subject: New Andair Fuel Valve. Reply with quote
Tim -
You used a FS20X3M.
Neal E. George
Navarre, FL 32566
Home - 850-515-0640
Cell - 850-218-4838
Just to clarify though, the FS20X7 I don't think was the part I used...
Tim
Tim(at)MyRV10.com
Ooops, I didn't see the attachment links. Yeah, those new
90 degree fittings were just coming out but AFTER I got my
valve. Those are definitely much nicer than what I had to
deal with. I don't know how much more space you get on the
180 degree valve, but on that valve, it would be fantastic.
You're on the right track for sure.
zackrv8 wrote:
Guys,
Zack
http://forums.matronics.com//files/dsc05666_742.jpg
http://forums.matronics.com//files/dsc05665_474.jpg
http://forums.matronics.com//files/dsc05656_278.jpg
http://forums.matronics.com//files/dsc05659_993.jpg
rvbuilder(at)sausen.net
PostPosted: Thu Aug 17, 2006 5:56 pm    Post subject: New Andair Fuel Valve. Reply with quote
Yep, that's the best one to use from Andair at the moment. It's more
aesthetically pleasing with the "Y" configuration and much easier to get
lines attached. Check out various entries (at):
<http://www.mykitlog.com/users/category.php?user=msausen&project 2&cate
gory=1703>
Michael Sausen
-10 #352
zackrv8
PostPosted: Thu Aug 17, 2006 6:07 pm    Post subject: Re: New Andair Fuel Valve. Reply with quote
Carl
Carl,
My invoice says Part No. FS20X7-T
Zack
RV8 #80125
RV10 # 40512
