zackrv8
Posted: Thu Aug 17, 2006 4:26 pm Post subject: New Andair Fuel Valve. |
Guys,
At Oshkosh, I ordered the new Andair valve (FS20X7) (http://www.andair.co.uk/system/index.html) for my RV10. When I got home, I read Tim Olson's site and the problems he had with clearance with the male AN fittings. So, I sent an email to Andy and told him of the clearance problem on the RV10 with that valve.
I was expecting him to send me a valve with female ends on it so that I could put my own 90 degree el's on it. Instead, he sent me this. Check out the pics below.
Zack
39.85 KB |
987 Time(s) |
44.16 KB |
1007 Time(s) |
40.63 KB |
935 Time(s) |
42.14 KB |
948 Time(s) |
_________________ RV8 #80125
RV10 # 40512 |
carl.froehlich(at)cox.net Guest
Posted: Thu Aug 17, 2006 5:04 pm Post subject: New Andair Fuel Valve. |
What part number goes with this?
Carl
Tim(at)MyRV10.com Guest
Posted: Thu Aug 17, 2006 5:18 pm Post subject: New Andair Fuel Valve. |
Zack, the photos didn't come through. You may want to try again
or I can post photos if nothing else works. Just to clarify
though, the FS20X7 I don't think was the part I used...if I
remember right. I think that was the new Y oriented valve,
right?
Good luck, you'll like the Andair valves.
zackrv8 wrote:
Guys,
Zack
Neal George
Posted: Thu Aug 17, 2006 5:34 pm Post subject: New Andair Fuel Valve. |
Carl -
The complete part number for the valve pictured is FS20X7T
FS = Fuel Selector
20 = line diameter in 1/2-mm increments (10mm is about 3/8" or AN6)
X = Male AN6 outlet fitting. Female outlet would be "F"
T = 90-deg elbow AN6 inlet fittings. Or "M" for male, "F" for female.
Neal E. George
2023 Everglades Drive
Navarre, FL 32566
Home - 850-515-0640
Cell - 850-218-4838
Carl
Neal George
Posted: Thu Aug 17, 2006 5:45 pm Post subject: New Andair Fuel Valve. |
Tim -
You used a FS20X3M.
Neal E. George
Navarre, FL 32566
Home - 850-515-0640
Cell - 850-218-4838
Just to clarify though, the FS20X7 I don't think was the part I used...
Ooops, I didn't see the attachment links. Yeah, those new
90 degree fittings were just coming out but AFTER I got my
valve. Those are definitely much nicer than what I had to
deal with. I don't know how much more space you get on the
180 degree valve, but on that valve, it would be fantastic.
You're on the right track for sure.
zackrv8 wrote:
rvbuilder(at)sausen.net Guest
Posted: Thu Aug 17, 2006 5:56 pm Post subject: New Andair Fuel Valve. |
Yep, that's the best one to use from Andair at the moment. It's more
aesthetically pleasing with the "Y" configuration and much easier to get
lines attached. Check out various entries (at):
<http://www.mykitlog.com/users/category.php?user=msausen&project 2&cate
gory=1703>
Michael Sausen
-10 #352
zackrv8
Posted: Thu Aug 17, 2006 6:07 pm Post subject: Re: New Andair Fuel Valve. |
| carl.froehlich(at)cox.net wrote: | What part number goes with this?
Carl
Carl,
My invoice says Part No. FS20X7-T
Zack
RV10 # 40512 |
