What is this cheesy material in my oil cooler?
CharlieTango
PostPosted: Tue Jul 01, 2014 7:12 am    Post subject: What is this cheesy material in my oil cooler? Reply with quote
This CTSW has had high oil temps for the last 6 years. I sent the oil cooler to Hot Flush and after a bunch of metal this cheesy material started coming loose.
What is it?
 Filesize:  193.88 KB
 Viewed:  7071 Time(s)
rickofudall
PostPosted: Tue Jul 01, 2014 7:38 am    Post subject: What is this cheesy material in my oil cooler? Reply with quote
Looks like the result of water vapor distilling, for lack of a better description, out the parafins in the oil base stock and then baked hard. Used to happen all the time with Pennzoil back in the day.
Rick Girard
On Tue, Jul 1, 2014 at 10:12 AM, CharlieTango <ed.cesnalis(at)mammothlakesinsulation.com (ed.cesnalis(at)mammothlakesinsulation.com)> wrote:
--> RotaxEngines-List message posted by: "CharlieTango" <ed.cesnalis(at)mammothlakesinsulation.com (ed.cesnalis(at)mammothlakesinsulation.com)>
What is it?
http://forums.matronics.com/viewtopic.php?p=425840#425840
http://forums.matronics.com//files/cheesy_material_from_oil_cooler_848.jpg
nes-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
MS -
e -
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
williamtsullivan(at)att.n
PostPosted: Tue Jul 01, 2014 8:46 am    Post subject: What is this cheesy material in my oil cooler? Reply with quote
  I have no idea what it is, but save it and weigh it on a fine scale- like a reloading scale.  Then when you find out what it is, you can weigh the new part and find out how much might still be in there. I once had some red plastic like that clog up a hydraulic system. It turned out to be part of a sight indicator on the oil filter. It had cracked, and somebody pushed the red indicator back into the hole, and screwed a plug in on top of it. The pump chewed it up, and it jammed the hydraulic system valves. We kept cleaning the system, saving parts and weighing them, and comparing against a new part.
Bill Sullivan
On Tue, 7/1/14, CharlieTango <ed.cesnalis(at)mammothlakesinsulation.com> wrote:
Subject: What is this cheesy material in my oil cooler?
Date: Tuesday, July 1, 2014, 11:12 AM
posted by: "CharlieTango" <ed.cesnalis(at)mammothlakesinsulation.com>
What is it?
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
BARRY CHECK 6
PostPosted: Wed Jul 02, 2014 1:00 pm    Post subject: What is this cheesy material in my oil cooler? Reply with quote
Did you know that many drones are powered by a Rotax engine?
On Tuesday, July 1, 2014, william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)> wrote:
--> RotaxEngines-List message posted by: william sullivan <[url=javascript:;]williamtsullivan(at)att.net[/url]>
                                                        Bill Sullivan
On Tue, 7/1/14, CharlieTango <[url=javascript:;]ed.cesnalis(at)mammothlakesinsulation.com[/url]> wrote:
 To: [url=javascript:;]rotaxengines-list(at)matronics.com[/url]
 posted by: "CharlieTango" <[url=javascript:;]ed.cesnalis(at)mammothlakesinsulation.com[/url]>
 What is it?
               -Matt
 Dralle, List Admin.
le, List Admin.
Sent from Gmail Mobile
