CharlieTango
Joined: 23 Jan 2008 Posts: 3 Location: Mammoth Lakes, California
Posted: Tue Jul 01, 2014 7:12 am Post subject: What is this cheesy material in my oil cooler? |
This CTSW has had high oil temps for the last 6 years. I sent the oil cooler to Hot Flush and after a bunch of metal this cheesy material started coming loose.
What is it?
193.88 KB |
7177 Time(s) |
rickofudall
Posted: Tue Jul 01, 2014 7:38 am Post subject: What is this cheesy material in my oil cooler? |
Looks like the result of water vapor distilling, for lack of a better description, out the parafins in the oil base stock and then baked hard. Used to happen all the time with Pennzoil back in the day.
Rick Girard
On Tue, Jul 1, 2014 at 10:12 AM, CharlieTango <ed.cesnalis(at)mammothlakesinsulation.com (ed.cesnalis(at)mammothlakesinsulation.com)> wrote:
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
 - Groucho Marx
Posted: Tue Jul 01, 2014 8:46 am Post subject: What is this cheesy material in my oil cooler? |
I have no idea what it is, but save it and weigh it on a fine scale- like a reloading scale. Then when you find out what it is, you can weigh the new part and find out how much might still be in there. I once had some red plastic like that clog up a hydraulic system. It turned out to be part of a sight indicator on the oil filter. It had cracked, and somebody pushed the red indicator back into the hole, and screwed a plug in on top of it. The pump chewed it up, and it jammed the hydraulic system valves. We kept cleaning the system, saving parts and weighing them, and comparing against a new part.
Bill Sullivan
On Tue, 7/1/14, CharlieTango <ed.cesnalis(at)mammothlakesinsulation.com> wrote:
Subject: What is this cheesy material in my oil cooler?
To: rotaxengines-list(at)matronics.com
Date: Tuesday, July 1, 2014, 11:12 AM
--> RotaxEngines-List message
posted by: "CharlieTango" <ed.cesnalis(at)mammothlakesinsulation.com>
What is it?
http://forums.matronics.com/viewtopic.php?p=425840#425840
http://forums.matronics.com//files/cheesy_material_from_oil_cooler_848.jpg
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
BARRY CHECK 6
Posted: Wed Jul 02, 2014 1:00 pm Post subject: What is this cheesy material in my oil cooler? |
Did you know that many drones are powered by a Rotax engine?
On Tuesday, July 1, 2014, william sullivan <williamtsullivan(at)att.net (williamtsullivan(at)att.net)> wrote:
| Quote: | --> RotaxEngines-List message posted by: william sullivan <[url=javascript:;]williamtsullivan(at)att.net[/url]>
Bill Sullivan
On Tue, 7/1/14, CharlieTango <[url=javascript:;]ed.cesnalis(at)mammothlakesinsulation.com[/url]> wrote:
To: [url=javascript:;]rotaxengines-list(at)matronics.com[/url]
posted by: "CharlieTango" <[url=javascript:;]ed.cesnalis(at)mammothlakesinsulation.com[/url]>
What is it?
-Matt
Dralle, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
Sent from Gmail Mobile
