Weld-on 10 & crazing
Goto page Previous  1, 2
msausen
PostPosted: Fri Sep 12, 2008 6:13 am    Post subject: Weld-on 10 & crazing Reply with quote
42
msausen
PostPosted: Fri Sep 12, 2008 6:18 am    Post subject: Weld-on 10 & crazing Reply with quote
http://www.lpaero.com/documentation.html
Michael
rene(at)felker.com
PostPosted: Fri Sep 12, 2008 6:27 am    Post subject: Weld-on 10 & crazing Reply with quote
64 scary...
I don't know the new ones.....I was a 316, little missiles and then went to BIG missiles.....but our age shows by the AFSC's we remember.....
Rene' Felker
RV-10 N423CF Flying
801-721-6080
pcasson(at)sasktel.net
PostPosted: Fri Sep 12, 2008 6:59 am    Post subject: Weld-on 10 & crazing Reply with quote
Vern,
I had the same problem when I installed my windshield. Decided it was going
to be far easier to replace the windshield right away and risk having
problems after fairing and paint and glad I did. When I started knocking
the bad windshield out it cracked quite readily from those crazed areas.
Based on talks with a buddy of mine who's blown several of bubble canopies
we suspect the "problem" windshields are being blown at a slightly lower
temperature or are being allowed to cool faster after blowing.
Perry Casson
C-FMHP
chuck(at)chuckdirect.com
PostPosted: Fri Sep 12, 2008 8:52 am    Post subject: Weld-on 10 & crazing Reply with quote
I've used rubbing alcohol on an RV9A (three years old) and my almost finished RV10. Haven't had a problem yet.
Chuck
planesmith(at)hotmail.com
PostPosted: Fri Sep 12, 2008 10:48 am    Post subject: Weld-on 10 & crazing Reply with quote
I did get an answer from the tech group at IPS the makers of Weld-On10 about possible repairs. They don't recommend using Weld-On 3 ( a capillary action cement) for surface cracks/crazing as it can make the cracks worse. Only other idea they had was try removing the cracks mechanically with something like Micro-Mesh or leave them alone.
So there you have the options:
 1. Leave them alone
 2. Try buffing them out
 3. Replace the window
Again I would like to thank everyone for their thoughts and encouragement.
vern
> Date: Fri C 12 Sep 2008 08:57:15 -0600
Subject: Weld-on 10 & crazing
--> RV10-List message posted by: Perry Casson <pcasson(at)sasktel.net>
Vern C
Perry Casson
C-FMHP
Get more out of the Web. Learn 10 hidden secrets of Windows Live. Learn Now [quote][b]
John Ackerman
PostPosted: Fri Sep 12, 2008 11:28 am    Post subject: Weld-on 10 & crazing Reply with quote
I'd be exceptionally cautious about using this site as a guide for
what to put on my windshield:
http://www.ridoutplastics.com/plexiglas-chemical-resistance.html
For example, they rate ammonium hydroxide as "excellent".
John
Not sure exactly what type of "plastic" our windows are made of, but
the list at the link below gives the effects of using various
solvents/substances on acrylic plexiglass and I figure ours is
pretty close. It's a pretty inclusive list, and I used it as a
guide for figuring out what substances to avoid (anything with an
"N" in both columns). Isopropyl alcohol is not so good. Ethyl
alcohol is better if you can find it without any additives.
pascal(at)rv10builder.net
PostPosted: Fri Sep 12, 2008 2:21 pm    Post subject: Weld-on 10 & crazing Reply with quote
Sorry to hear of your crazing Vern.
I appreciate this thread and the responses on what to do and not do to install the windows without crazing or other issues it will serve me well when I go to do them myself.
Thanks all for the insight!
Pascal
Sent: Friday, September 12, 2008 11:47 AM
Subject: RE: Weld-on 10 & crazing
1. Leave them alone
vern
Date: Fri, 12 Sep 2008 08:57:15 -0600
Vern,
Perry Casson
C-FMHP
Get more out of the Web. Learn 10 hidden secrets of Windows Live. [url=http://windowslive.com/connect/post/jamiethomson.spaces.live.com-Blog-cns!550F681DAD532637!5295.entry?ocid=TXT_TAGLM_WL_getmore_092008]Learn Now[/url] [quote]
daveleikam(at)wi.rr.com
PostPosted: Fri Sep 12, 2008 7:03 pm    Post subject: Weld-on 10 & crazing Reply with quote
Sounds like good info Mike, thanks for posting.
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
johngoodman
PostPosted: Sat Sep 13, 2008 5:38 am    Post subject: Re: Weld-on 10 & crazing Reply with quote
Ah, a fellow Hitchhiker....
msausen wrote:
42
Peter.James(at)sprint.com
PostPosted: Sun Sep 14, 2008 8:03 am    Post subject: Weld-on 10 & crazing Reply with quote
Hello fellow -10r’s,
I think there has been way too much made of gluing in windows, crazing, alternative glues, etc. I was scared to death to do mine after all the posts. It was a learning process, but didn’t go nearly as bad as I expected ….. So here is what I did – take it or leave it:
True: Weld-on is some of the gooiest stuff I have ever worked with…worse than pro-seal. The big problem is that it likes to ‘string’…and it gets everywhere…just like pro-seal, it can jump 10 feet
Put the window where you want it. Drill holes and cleco and fender washer the window in place. This does NOT put a lot of pressure on the window. It DOES allow the window to spring out to the exact shape of the canopy. This is a GOOD thing.
Draw a line with one of your kids Crayola washable markers (fine line) on the inside.
Take the window out. Use Black electrical tape to seal the window up to the Crayola marker line. Get the seal nice and smooth and nice and tight to the line.
Then come back over the electrical tape with BLUE tape.  It doesn’t have to get right to the edge of the electrical tape, but pretty close.  I might even consider a second layer of blue tape. Do the same thing on the outside of the window…right out to the edge. IMPORTANT: Also blue tape a couple of layers on the outside of the fuselage around the window well. This will be important to keep the Weld-on off the fuselage as you glue the windows in.  YES – blue tape is expensive – but don’t scrimp here. Get a 2 or 3” wide band of tape around the wells.
Sand the inside flange with sandpaper – clean with ISOPROPYL alcohol from the DRUG STORE – get the purest stuff they have. Remember not to leave it open as I it will absorb moisture from the air.  I’m not sure that it matters in this case, but I like the stuff to be as potent as possible for future uses.
To glue in the window have 2 buddies over to help! One will be inside the plane, the other on the outside.
Smear the mixed Weld-on 10 on the flange. Mine was somewhat runny…. It will try and run on you. MOVE FAST!!! Mine set in FAR less than the 20 minute pot-life it is supposed to have.
Gently set the window in place. DO NOT PRESS IT IN! If you do, the glue will squeeze out when you press in, the window will then ‘spring’ back to the cleco and fender washers – leaving a big air pocket where the glue squeezed out. Some of this is just plain going to happen. I will talk about that later. Have Buddy number 2 start clecoing and fender washering the window. Hit the four corners, and a few other places, then grab pliers, clecos, and washers and get them in. Don’t delay. You want time to clean up and work with this stuff before it sets.
The glue is going to be a mess! Have blue shop towels and a couple of plastic resin spreaders handy. I took a couple spreaders to my band saw and cut a couple of varying widths.. These are plastic and won’t scratch the window. The also are stiff enough to scrape the excess glue off. Buddy number 1 will be inside, scraping any excess off as it squeezes out.  If you don’t have someone inside, this stuff will drip on you fuselage interior and won’t be easy to clean up or sand off later.
If you did a good job of taping, you will be scraping the extra glue off the BLUE TAPE – inside and out. Keep in mind, on the outside, you will have to scrape around the clecos and fender washers.  Get the bulk off quickly.
Next – again, moving very fast – pull the first layer of blue tape off. This will get the bulk of extra glue off and away from the plane. Have a big waste basket or paper bag nearby…because just like pro-seal – this stuff can jump 10 feet and get on anything and everything. On the outside of the plane, you will have your extra buddy pull a cleco – you pull the tape past the hole, then have him put the cleco right back in. It should now be setting on the second layer of tape, or the electrical tape.
Go all the way around the windows, cleaning, peeling a layer of tape, cleaning, peeling a layer of tape. By the time you are done, the glue will be VERY solid. It won’t be impossible to get off, but it won’t be easy. I then used a metal square tip knife, to get the final remnants off the window on the inside and outside of the fuselage.
By using clecos and fender washers, the clamp force is regulated or eliminated if the window has sprung up to ‘meet’ the fender washer. I did not get ANY crazing at all…not even one place. My result was not perfect. I learned the lesson of pushing the window in too far, having it spring back, and leave a big air pocket the hard way on the first window. I later came back with a tiny drill….used a light and drilled two holes, then used a syringe with no needle to fill the sir pockets with weld-on. (I have extra weld-on since I had some that had expired and I ordered fresh for the main process.)
The cleco holes are now filled with epoxy and the high strength West Systems Adhesive filler. You will never know that there was a hole there.
My results are not perfect, but they are not bad. The real key is to move fast. We did this on a warm summer evening…and the Weld-on went to set in a real hurry.
These are my experiences – you can use them – laugh at them – or ignore them. I just know that it worked pretty well for my building team. I’d be happy to answer any questions as this one of the most intimidating steps in the whole kit.
Pete #40100 – plan to have it Osh next year.
AV8ORJWC
PostPosted: Sun Sep 14, 2008 8:26 am    Post subject: Weld-on 10 & crazing Reply with quote
Congrats on your success. Looking forward to seeing it at OSH '09.
John Cox
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James, Peter [SD]
Sent: Sunday, September 14, 2008 8:59 AM
Subject: Re: Weld-on 10 & crazing
[quote] [/b][/b][/b][/b]http://www.matronics.com/Navigator?RV10-List[/b]http://forums.matronics.com[/b]http://www.matronics.com/contribution [b]
DLIUDVINAITIS(at)AOL.COM
PostPosted: Sun Sep 14, 2008 9:24 am    Post subject: Weld-on 10 & crazing Reply with quote
HEY PETE,
SOUNDS LIKE YOU HAD VERY GOOD EXIPERENCE, MAY BE YOU CAN LET US KNOW WHAT CLEANER OR PREPING YOU USED BEFORE INSTALLING YOUR WINDOWS? I'M REAL CLOSE TO INSTALLING MY WINDOWS. THANKS
DAVE LUDD
NJ #40466
In a message dated 9/14/2008 11:04:45 A.M. Central Daylight Time, Peter.James(at)sprint.com writes:
="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com.
speckter(at)comcast.net
PostPosted: Sun Sep 14, 2008 10:24 am    Post subject: Weld-on 10 & crazing Reply with quote
IMHO you do not want to clean your windows prior to install. Leave the protective film on all but the working edge and prep only the working edge. If you clean the whole window you risk contaminating the edge with things that reduce the adhesion. I would think this is true no matter if you use weld-on, epoxy sikaflex or what ever. Most cleaners leave behind some residue, and I never wanted to chance that it would effect the bond.
Gary Specketer
40274 Flying
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLIUDVINAITIS(at)aol.com
Sent: Sunday, September 14, 2008 1:24 PM
HEY PETE,
DAVE LUDD
NJ #40466
="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List.matronics.com/">http://forums.matronics.com://www.matronics.com/contribution">http://www.matronics.com/contribution
5
PostPosted: Sun Sep 14, 2008 10:57 am    Post subject: Weld-on 10 & crazing Reply with quote
Could a product like this
http://www.intropc.com/item-25742-3m-auto-glass-urethane-windshield-adhesive-medium-viscosity-3m8693.html
be used to install the windows?
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
Tim Olson
PostPosted: Sun Sep 14, 2008 4:04 pm    Post subject: Weld-on 10 & crazing Reply with quote
That is an EXCELLENT write-up Peter. The drilling holes thru the
windshield shouldn't be an issue they way you did it, and it is
another good way you can hold it all together. Like Gary commented,
as far as cleaning before installing, I don't know that it's really
a big necessary thing...but even though I personally avoided IPA
for the wipe, I don't think a quick wipe of it would affect anything
either if it evaporates right away. You're right though...the glue
is a pain mainly because it's quick-set and stringy, but it certainly
works fine for putting the windows in...and doing it how you did it
with helpers is a perfect way to go. It's just great to have them
in and done!
on the inside.
tight to the line.
quickly.
tape.
PostPosted: Sun Sep 14, 2008 7:02 pm    Post subject: Weld-on 10 & crazing Reply with quote
Yes C a very nice write up.
To add to Tim & Gary's comments about cleaning the bonding surface C  I found this quote in Lancair's manual:
DON'T: Clean plexglass window with rubbing alcohol in the bonding areas after sanding. The plexiglass may absorb the rubbing alcohol if sanded. Never clean the edges. The edges are rough and may absorb the rubbing alcohol.
The correct method of cleaning the plexiglass window is to first clean the (unsanded) bonding surface with rubbing alcohol. Apply with a soft cloth such as a T-shirt. Sand the bonding areas thoroughly so no glossy areas remain. Using high pressure air or clean cloth C remove the dust from the surface. Don't touch the bonding surface proir to bonding.- Lancair Legacy manual
It's been five days since gluing the windshield in and now I'm getting crazing/surface cracks C on the glue joint C where I didn't use clamps:( But only on the windshield not the other windows (go figure.)
Did I mess-up? I think so. Is there some additional issue with internal stress in the window? Who knows. I do know the window is coming out for replacement.
Thanks again for the support C
Vern Smith (#324)
Date: Sun C 14 Sep 2008 19:01:52 -0500
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
windshield shouldn't be an issue they way you did it C and it is
another good way you can hold it all together. Like Gary commented C
as far as cleaning before installing C I don't know that it's really
a big necessary thing..but even though I personally avoided IPA
for the wipe C I don't think a quick wipe of it would affect anything
is a pain mainly because it's quick-set and stringy C but it certainly
in and done!
James C Peter [SD] wrote:
> Hello fellow -10r’s C
Page 2 of 2
