Aileron Rigging Tip - Prevent Droopy Ailerons
Goto page Previous  1, 2
CJohnston(at)popsound.com
PostPosted: Mon Mar 19, 2007 12:42 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Hey all -
All this talk about ailerons has got me wondering if someone could
answer my previously (unanswered) question about how much downward throw
the ailerons have? I don't want anything very scientific like degrees
or anything. Just maybe a measurement from the trailing edge of the
aileron at full down deflection to the trailing edge of the flap with
the flap in the full up position. I'm still nervous about my rubbing
issue, and I'm nowhere near mounting the wings so that I can see if it
really is a problem. Could someone help me out?
Thanks!
cj
#40410
fuse
www.perfectlygoodairplane.net
jjessen
PostPosted: Mon Mar 19, 2007 1:32 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Not a service bulletin, but something that addresses the obvious rigging
issue. Best to have that change come out of Vans so it hits everyone.
deutscht(at)rhwhotels.com
PostPosted: Mon Mar 19, 2007 2:38 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Since I just finished rigging my controls in preparation for my first
flight I just had to go to the airport to check. What I found was my
ailerons were perfectly aliened with the elevator in the neutral
position and when going to full up elevator they raised approx 3/16" and
at full down elevator they also raised the same amount. Interesting. I
agree with Tim that is not a big cause for concern. If you rig with the
elevator at neutral you will be good to go.
Tim, do you have an accumulation of performance stats for the 10? If so
were can I find it?
Tom Deutsch, #40545
billderou(at)yahoo.com
PostPosted: Mon Mar 19, 2007 3:13 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Coincidentally, we have been adjusting the ailerons of the two RV-10's at Watsonville observing all that has been written. Has anyone noticed a change in handling characteristics or cruise speed improvements when making the adjustment between trailing edges flush on the ground vs flush in the air?
To quantify the adjustment (N939SB), it was one full turn of the rod end fitting will lift one aileron .25 inch.
Bill DeRouchey
N939SB, flying
billderou(at)yahoo.com (billderou(at)yahoo.com)
John Jessen <jjessen(at)rcn.com> wrote:
[quote]--> RV10-List message posted by: "John Jessen"
Tim Olson
PostPosted: Mon Mar 19, 2007 3:22 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Tom,
I still have this page posted from last year:
http://www.myrv10.com/performance/
I haven't uploaded the new one yet that will replace it, but I've wiped
the slate and intend to start over with the specs. Initially I had that
airspeed error that I didn't even know about (because I didn't test
for it), so my numbers were messed up....and I had to adjust them after
the fact. So I'm going to re-write the entire page and just start
logging some numbers on flights.
What I REALLY want to get is to have some other people, ONLY those
who've actually measured their airspeed indication error, shoot me
some of their specs over time too. That way we can kind of have a
good broad-based list of power settings and altitudes for people to
compare too, with various engines and props. Nobody's ever sent
anything yet though...and I don't want numbers that aren't fairly
complete.
So anyway, you'll see this page start fresh soon. I may have to
actually get out and see how fast it goes too, just to keep people
smiling about numbers. To date, I think the fastest I've let it
climb in speed is about 184 or 185kts TAS, but I'm not sure that it
was done yet.
Tim
were can I find it?
Tom Deutsch, #40545
markandangelasrv10(at)yah
PostPosted: Tue Mar 20, 2007 3:02 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
When I first saw this thread, it got me curious. Since I don’t even have the fuselage kit yet all I have to go from is what I can see in the plans.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
According to the pics on p.1 of sections 23, 39 & 44, the bottom of the control stick where the F-1064 aileron pushrod assembly attaches swings fore & aft through an arc when elevator input is put into the stick. This means the inboard end of the F-1064 moves fore & aft with elevator input. The outboard end of the F-1064 is fixed in the fore & aft direction. So, the farther the inboard end of the F-1064 moves away from the neutral point (this goes for either forward or rearward movement), the more the outboard end of the F-1064 is pulled inward.
Following the control linkages out to the ailerons, this translates to up aileron movement on both wings. So, it sounds like if the aileron neutral point was set with the stick full aft (or foreword) then that explains why they would then ‘droop’ when the stick is moved back to neutral.
Of course, that all sounds good in theory…
As Tom mentions, his ailerons move up with full stick motion fore or aft, which seems to support the theory. So, if someone really wants to isolate this and prove my theory, it seems the wing root farings can be pulled to check the outboard end of the F-1064 for inward travel with fore & aft stick movement. Anyone want to try it???
Tom Deutsch wrote:
--> RV10-List message posted by: "Tom Deutsch"
were can I find it?
Tom Deutsch, #40545
Mark Lanier
#519
www.lanier-rv10.com
Food fight? Enjoy some healthy debate
in the Yahoo! Answers Food & Drink Q&A. [quote][b]
Tim Olson
PostPosted: Thu Mar 22, 2007 4:24 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Chris,
I think I have what you need. My wife was nice enough to drive
out to the hanger and get the measurements because I've been too
busy to get there. I had her measure from the tip of the
aileron to the tip of the flap with the flaps up. The ailerons
deflect upwards about 4" even, and they deflect downwards about 3"
even. That should give you an idea of the total travel that you'll
get. Sorry it took so long....darn wife, you know, she just didn't
jump quick enough. When I say jump, I expect to hear "How High?".
(Just kidding...and DO NOT ARCHIVE or I may find myself living
at the hanger!) She's a good girl, that's for sure.
Chris Johnston wrote:
Hey all -
Thanks!
cj
#40410
fuse
Rick S.
PostPosted: Thu Mar 22, 2007 6:04 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
How come so many of us have asked before but now FINALLY an answer...AND you had to get your wife to do it!!!! Smile
Rick S.
40185
Rick S.
RV-10
40185
PostPosted: Thu Mar 22, 2007 6:17 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
We have two stock RV-10's out at Watsonville, CA: one with ailerons set trailing edges faired on ground, and one trailing edges faired in cruise. The adjustments to get from the lower to higher position is one full rod end turn per aileron or approx 1/4". Noticed that the aircraft with ailerons adjusted to faired in cruise (higher) required that the lower leading edge of the aileron begins to dip into the airstream suggesting that this is the max upper limit. Formation flying was used to determine speed differences by setting same power, fuel flow, & RPM.
Thinking about some very good input from others it would probably be wise to duct tape the elevators fair with the horizonal stab to create a proper origin and then set the ailerons. This would be best case for a forward CG (front seat occupants with little baggage) mission.
We installed markers to help measure elevator vs horizontal stab difference, added tuffs to flaps, ailerons, and wingtips.
Results were that in both cases the tuffs exitted the trailing edge parallel with the aileron chord. This would make sense since we were probably pitching the wing leading edge. The elevators were faired with the horizontal stabilizer in flight. And the RV10 with the upper aileron setting was "maybe 1 knot" faster.
Our conclusion was the speed difference was too small to be significant and could have been due to other causes. If I were to experiment with this further I would try a setting that the forward underside of the aileron fairs smooth with the wing when the elevator is taped to the horizon stab. This is probably somewhere between the settings tested.
Lessons learned:
1) Applying a lot of effort to aileron adjustment will probably not produce speed improvements.
2) Formation flying is great fun!
Bill DeRouchey
N939SB, flying
Tim Olson <Tim(at)MyRV10.com> wrote:
[quote]--> RV10-List message posted by: Tim Olson
Chris,
[quote] --> RV10-List message posted by: "Chris Johnston"
Hey all -
really [quote][b]
Tim Olson
PostPosted: Thu Mar 22, 2007 6:18 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
I've been afflicted with a disease caused by my lack of a kit
to work on. It's symptoms include laziness, apathy, weight
gain, and all sorts of nasty things, but on the upside, my
flying skills have improved because the disease causes a
high affinity to burning 100LL fuel. Pretty soon I'll need
to get me a tail kit or something before it does some
permanent damage.
Rick S. 40185
jesse(at)saintaviation.co
PostPosted: Fri Mar 23, 2007 5:04 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
To get true comparison you should now switch the ailerons to the opposite of where they are now and fly again. I know it’s a lot of work, but just think of the great formation flying you will get to experience again, and for the benefit or all to boot.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey
Sent: Thursday, March 22, 2007 10:17 PM
Subject: Re: Aileron Rigging Tip - Prevent Droopy Ailerons
Lessons learned:
Bill DeRouchey
N939SB, flying
Chris,
> Hey all -
> really
moons1999(at)yahoo.com
PostPosted: Fri Mar 23, 2007 7:28 am    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
If you really need some treatment for that disease, you can come to Texas and work on mine. Smile Once mine is up, I'm sure that some others could also supply doses of the "treatment".
--Shawn
40366 - Wings
MChase(at)gdatp.com
PostPosted: Thu Mar 29, 2007 12:44 pm    Post subject: Aileron Rigging Tip - Prevent Droopy Ailerons Reply with quote
Tim,
How about flying over to Vermont and working on my tailcone for a few hours and I will go flying for a change?
Michael Chase
General Dynamics Armament and Technical Products
802-657-6029 Office
802-922-5930 Cell
mchase(at)gdatp.com
This e-mail message (including attachments, if any) is for the sole use of the intended recipient(s) and may contain information that is private, confidential, or exempt from disclosure. Any unauthorized review, use, copying, printing, disclosure, retention, or distribution is strictly prohibited. If you are not the intended recipient, please contact the sender by reply to this e-mail, and delete all copies without disclosing this message to others. Thank you.
Sent by: owner-rv10-list-server(at)matronics.com
03/22/2007 10:23 PM Please respond to
rv10-list(at)matronics.com
To
rv10-list(at)matronics.com cc
Subject
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
permanent damage.
Rick wrote:
> --> RV10-List message posted by: Rick <ricksked(at)earthlink.net>
> Rick S. 40185
> do not archive
Page 2 of 2
