Tim(at)MyRV10.com Guest
dlm46007(at)cox.net Guest
Posted: Mon Nov 13, 2006 7:15 am Post subject: Quadrant vs. Vernier Cables |
Aircraft Spruce. largest aluminum is about .25 and will have to be reamed.
the smaller size hole in steel fits the alternate air cable for the fuel
injection airbox. Haven't mounted the engine yet but the best format seems
to be an inverted triangle using the two outboard holes enlarged to contain
the center prepunched hole. alt air went into the pilot side top corner.
LloydDR(at)wernerco.com Guest
Posted: Mon Nov 13, 2006 7:47 am Post subject: Quadrant vs. Vernier Cables |
More food for thought on this, if you ever plan on flying formation,
Verniers are not allowed as they do not allow quick enough throttle
changes, you will have to use regular push pulls or the quadrant. This
was stated at the ground schools for the FFI.
I personally plan on formation with the Ohio Valley Rvators, so make the
best choice for the type of flying you plan on doing.
Dan
RV10E (N289DT)
jesse(at)itecusa.org Guest
Posted: Mon Nov 13, 2006 8:59 am Post subject: Quadrant vs. Vernier Cables |
I may have no clue what I am talking about, but I think the throttle is a
standard Push-Pull in this sense, since there is no button you push to move
it and you can't screw-unscrew to tweak the setting. The prop and mixture
are the Vernier Cables. Again, I am talking in the context that you just
wrote, not in the technical meaning of Push-Pull versus Vernier.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Posted: Mon Nov 13, 2006 9:32 am Post subject: Quadrant vs. Vernier Cables |
The reason I put it out there, is that several pilots came to the annual
FFI clinic and had vernier throttles, not just mixture and prop. The
ones that had this could not fly formation because they had the push
button to deal with. I was just posting the caveat for those that buy
the cables aftermarket because I have seen several RV's with vernier for
throttle.
Dan
jjessen
Posted: Mon Nov 13, 2006 9:36 am Post subject: Quadrant vs. Vernier Cables |
Actually, and I'd like to fly formation, I'm confused about this myself. I
want vernier, but aren't they technically push/pull? I'm missing something
here, and, yeah, I know it's a brain, but....need some edification. I did
look this up on the Van's site, and I have flown a C-182 a bunch with
Vernier controls, but I'm still confused given that if you have your hand on
the throttle knob, is it the pushing in of the little button that is the
no-no here?
John Jessen
#40328
Posted: Mon Nov 13, 2006 10:31 am Post subject: Quadrant vs. Vernier Cables |
Correct, what they do not want is you have to push something to get free
movement of the throttle, when aircraft are this close together small
changes make big results. What they do not want to have happen is a
mid-air collision based on the fact you could not retard the throttle
quick enough because your thumb or palm slipped from the button. When I
have observed others flying in the wingman position, the throttle
changes are occurring on a continual basis, and a vernier would quickly
become a safety of flight issue.
Remember, Stu put together the course and the FFI certification program,
presented it to the FAA, and is putting his name on the line for the
safety of all of us and our ability to fly in waivered air space. We
need to follow those rules, and be as safe as possible. It is not to say
a vernier on the throttle, in regular flight is any less safe, just that
it is not to be used for formation flying.
Dan
#40269
apilot2(at)gmail.com Guest
Posted: Mon Nov 13, 2006 11:09 am Post subject: Quadrant vs. Vernier Cables |
I guess there are some planes that a vernier throttle makes sense, but
for a long cross country machine that you want to operate as
efficiently as possible, after takeoff the only throttle use will be
for descent to landing...cruising at altitudes that power is either
controlled by rpm or mixture or both. I'm happiest with straight push
pull throttle and vernier mixture and vernier prop. I think the point
about verniers and formation flying is very valid. Wonder how the
Bonanza folks handle that issue for their OSH arrival. I know they
practice formation flying for that, but perhaps at greater spacing.
Seems like they are one of the more common vernier throttle equipped
birds.
Dan
#40269
jjessen
Posted: Mon Nov 13, 2006 11:11 am Post subject: Quadrant vs. Vernier Cables |
So if one has a non-verniered throttle that is push/pull, that would be
okay? And for those with quadrants, is there the Cherokee style (usually
non-effective or non-working for rentals at least) friction knob to make the
levers not move, or have they upgraded the design? I looked at the picture
on Van's and was not seeing the friction knob.
John Jessen
#40328
Posted: Mon Nov 13, 2006 12:04 pm Post subject: Quadrant vs. Vernier Cables |
Correct, if there is a friction lock it needs to be all the way loose
during formation flight. The ones who can explain this better are Stu
McCurdy, or Mike Stewart. They run the clinics and can answer the
questions better than I. I would also recommend you goto a clinic, as
they are great fun and can teach you allot, even if you do not choose to
fly formation, it is a great way to spend a weekend with fellow RV
flyers!
Dan
N289DT
AV8ORJWC
Posted: Mon Nov 13, 2006 12:14 pm Post subject: Quadrant vs. Vernier Cables |
I wanted to thank everyone for the spirited discussion and fresh
perspectives on my thread I started on Quadrant vs. Vernier.
It all helps as we watch homes floating away here in the soggy Pacific
NW - home of VANS.
John Cox
#40600
jjessen
Posted: Mon Nov 13, 2006 12:44 pm Post subject: Quadrant vs. Vernier Cables |
Dan, thanks. I absolutely look forward to attending one of the formation
clinics. And thanks for the advice. Good to know before hand.
John Jessen
Posted: Mon Nov 13, 2006 1:02 pm Post subject: Quadrant vs. Vernier Cables |
Well, not entirely true. Formation pilots with vernier throttles use a clip to hold the button in ..... disabling the vernier function.
Linn
Lloyd, Daniel R. wrote:
[quote] [quote]--> RV10-List message posted by: "Lloyd, Daniel R." <LloydDR(at)wernerco.com> (LloydDR(at)wernerco.com) More food for thought on this, if you ever plan on flying formation, Verniers are not allowed as they do not allow quick enough throttle changes, you will have to use regular push pulls or the quadrant. This was stated at the ground schools for the FFI. I personally plan on formation with the Ohio Valley Rvators, so make the best choice for the type of flying you plan on doing. Dan RV10E (N289DT) --
Posted: Mon Nov 13, 2006 1:51 pm Post subject: Quadrant vs. Vernier Cables |
Unless they have changed their thoughts since April, Mike and Stu will not let you do it, period. What pilots do on their own is their choice, but when flying formation it affects all in the flight. If that clip falls off when you are least expecting it there will be big problems.
Like I said before,Stu runs the program and he should be the one to talk to on this, I am still just a builder, and formation pilot wanna be.
Dan
N289DT
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of linn Walters
Sent: Monday, November 13, 2006 4:03 PM
Subject: Re: Quadrant vs. Vernier Cables
Linn
[quote][quote]--> RV10-List message posted by: "Lloyd, Daniel R." <LloydDR(at)wernerco.com> (LloydDR(at)wernerco.com) More food for thought on this, if you ever plan on flying formation, Verniers are not allowed as they do not allow quick enough throttle changes, you will have to use regular push pulls or the quadrant. This was stated at the ground schools for the FFI. I personally plan on formation with the Ohio Valley Rvators, so make the best choice for the type of flying you plan on doing. Dan RV10E (N289DT) --
Posted: Mon Nov 13, 2006 2:07 pm Post subject: Quadrant vs. Vernier Cables |
Good point. I've met them and attended their ground school. Safety is their primary concern .... as it should be. As I don't have an RV in which to fly formation, that issue hasn't come up before. There are other formation clinics for other aircraft types, and that comment came from one of those groups. Hopefully someone will get a position statement from Mike or Stu before they choose what may be the wrong path.
Linn ...... wanna be too!
[quote] Unless they have changed their thoughts since April, Mike and Stu will not let you do it, period. What pilots do on their own is their choice, but when flying formation it affects all in the flight. If that clip falls off when you are least expecting it there will be big problems.
Dan
N289DT
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of linn Walters
Linn
rvbuilder(at)sausen.net Guest
Posted: Mon Nov 13, 2006 2:37 pm Post subject: Quadrant vs. Vernier Cables |
Sounds like a good use of duct tape here. Hehe. Sorry, I'm getting punchy. Finally going to get my project up here from Texas next week. Going through some serious building withdrawal.
Michael
Sent: Monday, November 13, 2006 3:03 PM
Linn
sschmidt(at)ussynthetic.c Guest
Posted: Wed Nov 15, 2006 8:24 am Post subject: Quadrant vs. Vernier Cables |
I’m just catching up on some e-mails on the list but thought I would add one more comment in relation to the quadrant.
One thing that I recently realized that I like is how quickly you can look at it and determine settings. The quadrant is very visual. It is easy to scan during startup and landing to see if it is set up how you would like it.
With Vernier’s you really never know how far out the throttle is. How many times do you check to see if you are ¼” forward during priming and startup with a Vernier system? Plus it is really nice having the throttle a totally different shape so in emergencies or a quick go around it is easy to see and advance.
And I have no problem dialing in any egt setting I want. I was sold on Vernier’s and really doubted my decision early on but have been very happy with the quadrant.
Scott Schmidt
sschmidt(at)ussynthetic.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Monday, November 13, 2006 3:36 PM
Subject: RE: Quadrant vs. Vernier Cables
Michael
Linn
| Quote: | | --> RV10-List message posted by: "Lloyd, Daniel R." <LloydDR(at)wernerco.com> More food for thought on this, if you ever plan on flying formation,Verniers are not allowed as they do not allow quick enough throttlechanges, you will have to use regular push pulls or the quadrant. Thiswas stated at the ground schools for the FFI.I personally plan on formation with the Ohio Valley Rvators, so make thebest choice for the type of flying you plan on doing.DanRV10E (N289DT) | 0[quote]--
