Posted: Tue Apr 24, 2018 9:55 am Post subject: Z-12 contactor failure |
At 11:15 AM 4/24/2018, you wrote:
. . . . Not wanting to venture into the dark side of some of these "conversations", I just want to relay what I have personally viewed on this subject of old switches and WD40.....
Some legacy Cessna switches were simple pull-push, like a Master. |
Geesh! That goes back aways. I think some of those
switches (automotive devices from the likes of
Cole-Hersee) were sill in production airframes
when I joined Cessna in '64. C-H still makes those
venerable devices.
[img]cid:.0[/img]
| Quote: | I have repaired 2 of them. If one is (very) careful bending the retaining tabs the switch can be worked apart and resealed. What I found in both was severely hardened original lubricate. Hardened to the point that if a piece gets into the contacts, it can cause a faults.
Cleaning with the usual sprays and re-lubing with modern electrical grease has fixed both and they are still working today.... but, it was the old lube that caused random failure. These were master switches. |
Yeah, fortunately the enclosure alloy would allow
opening and re-closing the tabs without fracture.
But I would have been hard pressed to 'sell off' the
procedure in a Service Parts Manual!
I do recall an 'approved' disassembly, refurbishment
and re-assembly of the OFF-L-R-BOTH-START switches
from Aircraft Spruce when the electrically destructive
nature of modern starter engagement solenoids was
discovered. And that was, as Barry intimated, an AD . . .
https://goo.gl/QV3gTF
About WD40, . . .I have used it on a lot to things, but this comment is about use on guns. I have pulled rifles from several years of storage and not been able to operate the bolt action. The one flaw I see with WD40 is that once the lighter carry fluids evaporate, it leaves a strong, thick film that can almost seize close fitting parts. Other than that issue, it does great duty as a penetrate and shield from water and rust. . . . |
Absolutely fine stuff . . . there are probably a half
dozen cans scattered around my shops and the truck-box.
Yes, I've seen the results of WD40 used to lubricate
Oilite bearings. They became clogged and totally
un-recoverable. Had to cut new ones from raw stock
on the lathe.
22.62 KB |
4951 Time(s) |
Posted: Tue Apr 24, 2018 10:08 am Post subject: Z-12 contactor failure |
| Quote: | Most devices give us advance clues as to their
distress before they fail outright. I suggest that
the FIRST time a switch, relay or contactor demonstrates
an electrical infirmity, it is time to replace it. |
Stubbed my toe here a bit. I do recall the electrical
failure of a mil-spec switch in the overhead panel
on a Beechjet. It was a spring-loaded, press-to-test
switch that was seldom used . . . and carried a tiny
fraction of rated current.
Yet, the switch had gone totally open . . .
The tech I was working with started the procurement
process for a new switch . . . which would have taken
several hours and exercised a lot of people. Pondering
the range of possible cause/effect I hypothesized that
the switch's failure may be the result of DISUSE.
The 10A rated, silver-cad contacts DEPEND on some degree
of electrical arc to burn away a thin film of corrosion.
So before he put the requisition into the slot, I
got a 5A, 30v constant current power supply from the lab
and connected it right across the switch such that
the 'failed' contacts provided a dead short on the
supply.
After a few dozen transitions of the switch, it became
conductive and demonstrated a very low on-resistance
(less than 10mv of drop at 5a). We were able to declare
the switch 'refurbished' and put the panel back together.
That particular application would have benefited from
gold-plated contacts on the switch. Such contacts are
designed for conductive longevity while working very low
or zero-current switching conditions.
skywagon
Posted: Tue Apr 24, 2018 10:35 am Post subject: Z-12 contactor failure |
Hi Bob,
Yes, you picked up on exactly the switches I was referring with my comments.
If you come across replacements, please put a P in your memory bank to let me know where to obtain.
Much appreciated. .
Dave
22.62 KB |
4950 Time(s) |
Posted: Tue Apr 24, 2018 11:22 am Post subject: Z-12 contactor failure |
At 01:34 PM 4/24/2018, you wrote:
Hi Bob,
Much appreciated. .
Dave
check through the offerings here
https://goo.gl/4r9M3x
you may find a suitable substitute if
not exact replacment. the switch
I illustrated is a Cole-Hersee 50047
which is probably available through a
Coll-Hersee dealer.
alec(at)alecmyers.com Guest
Posted: Tue Apr 24, 2018 4:13 pm Post subject: Z-12 contactor failure |
I lost track of which Bob was recommending annual WD-40 as a switch failure preventive prophylactic, and which Bob wasn’t.
Can someone advise?
On Apr 24, 2018, at 3:21 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
Hi Bob,
Much appreciated. .
Dave
Coll-Hersee dealer.
