		steven.pitt2(at)ntlworld. Guest
				 Posted: Sat Feb 04, 2006 4:43 am    Post subject: Electrcal interference |
				Dear All
 I am just completing my panel and fired up everything (except engine) to check no sparks or failures.
 I have an electric turn coordinator and it is noticeable that I get the sound of the giro in my headset (most of it can be squelched out) but it is most noticeable when I hold a handheld radio inside or outside the aircraft (not plugged in to the aircraft electrics). Does anyone have a remedy / reason for this?
 Steve Pitt #403
				 Posted: Sat Feb 04, 2006 12:44 pm    Post subject: Electrcal interference |
				Hi! Stephen
 We have just had a long debacle on the Jabiru Engine forum about this
 problem. The final outcome was that if your Turn Co-ordinator has a
 Chinese motor in it there's no way you will get rid of the noise!(except
 buy a more up market piece of gear)
 I make do with a bog standard bubble turn and slip indicator.
 Bob Harrison G-PTAG Europa MKI/Jabiru 3300
		n3eu(at)comcast.net Guest
				 Posted: Mon Feb 06, 2006 6:11 am    Post subject: Electrcal interference |
				Steven Pitt wrote:
  	  | Quote: | 	 		   ...
  hold a handheld radio inside or outside the aircraft....
 The little motor in the TC is causing all that?  Perhaps
 it's defective; I don't think I could duplicate that
 phenomenon with my 18V portable power tools.
 Google up: ferrite core "noise suppressor"  You may have a
 charger for a consumer device with one of these around the
 wire.  Try popping off the suppressor and testing it on the
 14V and GND wire pair at the back of the gyro.
 Reg,
 Fred F.
		ami(at)mcfadyean.freeserv Guest
				 Posted: Mon Feb 06, 2006 3:25 pm    Post subject: Electrcal interference |
				I have that 'problem' on two aircraft. But in both instances the noise has
 been getting in directly to the microphone, possibly due to its frequency
 and being very directionally sourced from close to the pilot's microphone.
 You could disprove this theory by listening to the problem from outside of
 the cockpit with the door closed (and headsets on and on the ground!)
 Duncan McF.
