charlieray(at)optonline.n Guest
Posted: Tue Feb 27, 2007 4:18 pm Post subject: Glass for IFRGlass for IFR |
The G1000 beechcraft have no vacuum driven instruments. You have a battery backup attitude indicator and airspeed and altimeter.
lsbrv7a(at)yahoo.com Guest
Posted: Tue Feb 27, 2007 5:29 pm Post subject: Glass for IFRGlass for IFR |
I think the right answer is any pilot is in for a few moments of stress at minimum. I believe there was a study where there was an IMC system failure in a simulator. The results were that nearly everyone lost control within minutes. With system failure try to fly the airplane.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
My brother, IFR current, in IMC in a Cessna 414 cycled the prop heat and everything went blank. Total electrical failure. The plane stalled twice, bending the airplane. He said he was able to gain control and find a clear area only with the help of our Uncle Bob’s ghost, a B-25 pilot. A certified aircraft redundant systems. If you see a 414 with a tail out of wack and ripples in the skin it could be the one.
Do not archive.
Bruce Gray <Bruce(at)glasair.org> wrote: | Quote: | Have any of you thought of the alternator frying and in the process burning out the battery contactor and opps, no electro wizzies. Flip all the dead switches you want, no joy. Is there a reason why every certified installation of an EFIS in a GA airplane has a Vacuum Attitude Indicator, ASI, and Altimeter as the backup?
Or, you're flying along in solid IMC and the cockpit starts filling with smoke.
Think these equipment decisions through with care, your life is dependant on it.
Sherman Butler
RV-7a Wings
Idaho Falls
kahuna
Posted: Wed Feb 28, 2007 3:45 am Post subject: Glass for IFRGlass for IFR |
As a survivor of a dual efis (GRT & BMA), single lockup, IMC, 2000'agl
vectors to final approach, it was the a/p that broke the tie for me. One
said left turn, one said right. My GRT locked up frozen on the efis
screen in a turn. I was fortunate to have noticed the discrepancy.
Disorientation set in in about 1 second as soon as it was noticed. You
cant imagine the immediate brain confusion when the 2 EFIS's are not
agreeing in a big way. Turn on the a/p and sort it out. A/p says BMA
wins, and thats what I flew to the runway. It resulted in an emergency
firmware update the following day by GRT. Turns out the EFIS did not
like a GPS approach with no assigned runway in the database. Was a
software bug. Would have been easier if the screen had just gone blank,
but your don't get to choose your fail modes.
Also as a side note, had I of had 2 GRT's, they both would have locked
up and I'd of been on A/P alone. That would not have been fun, but
doable.
It can happen. I was happy that day I chose 2 different EFIS's. Probably
saved my butt.
Also, as was asked earlier on this thread, I have tested my Trio A/P in
many unusual attitudes, and it will right me from the most ridicules
attitudes every time.
Mike
panamared5(at)brier.net Guest
Posted: Wed Feb 28, 2007 4:48 am Post subject: Glass for IFRGlass for IFR |
At 03:04 PM 2/27/07, you wrote:
| Quote: | But I have *never* had an automobile
alternator fail, nor the associated equipment
The best car I have ever owned, and I mean that, I had to replace the
alternator three times (in 300,000 miles). I have also had to replace
alternators in other cars and I had to replace the alternator in my RV at
60 hours.
Food for thought!
Bob
Posted: Wed Feb 28, 2007 7:01 am Post subject: Glass for IFRGlass for IFR |
Bob wrote:
at 60 hours.
Food for thought!
Wow Bob, you surely get your money's worth out of your car!!! If you
got an average of 40MPH (the numbers are easier for an engineer!),
that's 7500 hours of driving! If the fourth one failed right now, you
got (on average) 1875 hours per alternator. Not too shabby. Now for
the failure modes ...... brushes wear, diodes fail, and bearings wear
out. With the exception of the brushes, the other failure modes are
easily detected ..... whine in the headsets (diodes) and slipping
alternator belt (bearings) before anything gets serious. You might
detect current fluctuations before the brushes give out entirely, but
you have to be looking at the gauge when it happens. Alternators rarely
croak because the windings fried. Regulators (the mechanical ones) used
to be a weak spot, but the solid state ones are pretty reliable. The
biggest difference between your airplane and a car is the load. Your
car alternator is sized close to the max load (which can be really high
... 50 amps isn't uncommon with all the stuff turned on) and your
airplane probably only draws ...... around 20 amps would be my guess
.... so there's less strain on the system. As avionics gets more
efficient things get even better.
More food on the table!
Linn
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Wed Feb 28, 2007 8:40 am Post subject: Glass for IFRGlass for IFR |
Mike,
Why would you put "do not archive" on this? This is important stuff. Please
reconsider.
Terry
Posted: Wed Feb 28, 2007 10:12 am Post subject: Glass for IFRGlass for IFR |
I thought the exact same thing. This is too important to leave out of
the archives.
Robin
kahuna
Posted: Wed Feb 28, 2007 10:17 am Post subject: Glass for IFRGlass for IFR |
OK...
Done.
Mike
PS. Feel free to do this anytime yourself on any post you read. Reply
back and take it out at your discretion.
Too bad we cant go back and put it in though:) waaayyy to many posters
do not understand the concept.
seiders(at)bellsouth.net Guest
Posted: Wed Feb 28, 2007 4:46 pm Post subject: Glass for IFRGlass for IFR |
Mike, I am very re-assured by my Trio A/P when in IMC. Did I miss
something on all this chatter about EFIS? Why not a vacuum system for
backup with a few steam gages? I like old school system of three
sources of support vs one (elec).
Dick
At 06:44 AM 2/28/2007, you wrote:
<mike.stewart(at)us.ibm.com>
doable.
saved my butt.
Mike
Bruce(at)glasair.org Guest
Posted: Wed Feb 28, 2007 6:06 pm Post subject: Glass for IFRGlass for IFR |
Keep your head down, we're realy swimming against the current here.
Bruce
www.glasair.org
sportav8r(at)gmail.com Guest
Posted: Wed Feb 28, 2007 6:55 pm Post subject: Glass for IFRGlass for IFR |
Fear not; we're just discussing ideas.
Why not vacuum? Weight, cost, lousy reliability come to mind. My
personal belief is you would typically overhaul (or experience
failure) of a vacuum system several times over before your properly
designed and installed electrical whizzies hiccoughed for the first
time.
IMO, of course.
-Bill B
Bruce
www.glasair.org
Posted: Wed Feb 28, 2007 7:33 pm Post subject: Glass for IFRGlass for IFR |
Granted. Of course vacuum systems can and do fail, but not likely at
the same time should you lose electrical power in IMC or otherwise.
Dick
time.
IMO, of course.
-Bill B
>Bruce
>www.glasair.org
Posted: Wed Feb 28, 2007 8:47 pm Post subject: Glass for IFRGlass for IFR |
Dick, IF it's true that electrical systems fail less often than vacuum
(and it may not be, but I believe it is), then it stands to reason
that a second electrical system might be a better backup than a vacuum
system, assuming independence of the two elec. systems.
That being equal or better, the other advantages then come to the
fore: economy, weight savings, perhaps ease of installation...
Additionally, I'm looking at this question in light of the reliability
and redundancy offered by a dual-EFIS dual-AHRS installation that
cross-checks for errors every few mS, and instantly flags any
conflict. My MEMS-gyro-based autopilot will tell me at a glance which
EFIS/AHRS is bad and needs to be powered down for the rest of the
flight. Such a system needs no vacuum backup, just a second source of
electromotive force. I know of no way to have an electronic and
a vacuum based system perform automatic, repetitive integrity
cross-checks on each other, so I'm a convert to the new glass systems.
To each his own. That's the "stream" you might be swimming against,
that Bruce referred to.
-Bill
Dick
>time.
>IMO, of course.
>-Bill B
>>Bruce
>>www.glasair.org
Posted: Wed Feb 28, 2007 9:16 pm Post subject: Glass for IFRGlass for IFR |
At what level of the data stream are you going to cross check? Most I've
seen only cross check the AHRS output. That still leaves all that
questionable code up to the display screen.
Bruce
www.glasair.org
Posted: Thu Mar 01, 2007 5:26 am Post subject: Glass for IFRGlass for IFR |
That would be a good question to put to GRT. I have yet to purchase my system.
These posts, and even the thread title, could stand a little trimming.
Bruce
www.glasair.org
n616tb(at)btsapps.com Guest
Posted: Thu Mar 01, 2007 6:47 am Post subject: Glass for IFRGlass for IFR |
I love all the whizzies we get these days but wouldn't be so sure about your
comment. My steam gauges have never rebooted, but my GX60 has done exactly
that a couple of times for unknown reasons. I would be pretty uncomfortable
if a single EFIS did this in the soup.
[quote] --
LloydDR(at)wernerco.com Guest
Posted: Thu Mar 01, 2007 8:20 am Post subject: Glass for IFRGlass for IFR |
They may not have rebooted, but if they are vacuum pump driven it is
just a matter of time before they start to lean unexpectedly. I have had
a pump fail, and several people at the local field have been deep into
the soup and had them fail. Guess what they are all switching to
Electric backup systems, being certified planes they have less options,
but they are getting away from vacuum pumps and the unexpected failures
associated with them.
Redundant electrical systems, with redundant EFIS systems from different
manufactures are the way to go. In reviewing Mike's incident it becomes
clear that two EFIS, from two manufactures, and a GOOD Autopilot are the
way to go to get triple redundancy.
Just my .02
Dan
N289DT RV10E
steve(at)newtech.com Guest
Posted: Thu Mar 01, 2007 9:29 am Post subject: Glass for IFRGlass for IFR |
Looks like the Experimental EFIS suppliers aren't the only ones with
software problems. Our newest fighter, the F-22, suffered EFIS meltdown
when it crossed the international date line. They had to be led back to
Hawaii VFR by the KC-135 tanker that was accompanying them. Wonder how
my GRT EFIS Sport will behave when it crosses the International Date
Line
he
Check out the article at:
http://www.aero-news.net/news/military.cfm?ContentBlockID=60af32fb-31c0-4162-b209-9bc791c5de0f&Dynamic=1
Steve Eberhart
RV-7A, starting to get serious about the panel
DO NOT ARCHIVE
Bruce Gray wrote:
Bruce
www.glasair.org
