dav1111(at)cox.net Guest
Posted: Tue Feb 27, 2007 5:33 am Post subject: Glass for IFRGlass for IFR |
Nice panel. I have a stupid question, if you're flying along in solid
IMC
and all of a sudden one of your EFIS says you're turning right and the
other
says you're turning left, on which one do you bet your life?
Bruce
www.glasair.org
You immediately turn on your autopilot which is independent of the GRT EFIS and after the autopilot levels the airplane you turn off the bad EFIS.
Russ Daves
N710RV - First Flight 7/28/06
Bruce(at)glasair.org Guest
Posted: Tue Feb 27, 2007 7:37 am Post subject: Glass for IFRGlass for IFR |
Now that's scary!
Bruce
www.glasair.org
jjessen
Posted: Tue Feb 27, 2007 8:44 am Post subject: Glass for IFRGlass for IFR |
Guys. We the uninitiated, need to know why something is scary or why something is cool. Thanks.
John Jessen
RV-10 emp
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bruce Gray
Sent: Tuesday, February 27, 2007 7:33 AM
To: rv-list(at)matronics.com
Subject: RE: Glass for IFRGlass for IFR
Now that's scary!
Bruce
www.glasair.org
LloydDR(at)wernerco.com Guest
Posted: Tue Feb 27, 2007 9:01 am Post subject: Glass for IFRGlass for IFR |
This is also how I have it setup in my plane, if there is a conflict between the Chelton and the Dynon, Engage the sorcerer and turn off the offending equipment.
Dan
N289DT
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Russell Daves
Sent: Tuesday, February 27, 2007 8:31 AM
Subject: Re: Glass for IFRGlass for IFR
IMC
other
Bruce
www.glasair.org
Russ Daves
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
Posted: Tue Feb 27, 2007 9:03 am Post subject: Glass for IFRGlass for IFR |
Why is triple redundancy scary? You would also have the virtual panel in a hand held GPS as a 4th backup.
Just how far do you want to take it? You can spend as much or as little as you want.
Dan
N289DT
Sent: Tuesday, February 27, 2007 10:33 AM
Now that's scary!
Bruce
www.glasair.org
sbuc(at)hiwaay.net Guest
Posted: Tue Feb 27, 2007 9:29 am Post subject: Glass for IFRGlass for IFR |
Bruce Gray wrote:
If I was flying in IMC with my dual-glass plane and there was a
conflict, I wouldn't have to worry about turning on the autopilot.
It would have already been on since entering IMC.
With the new solid-state coupled autopilots, I don't see a need for much
hand flying in IMC. Seems the FAA has *finally* come around to a similar
position as it pertains to IFR training and their new emphasis on
teaching autopilot operation.
Sam Buchanan
Bruce
www.glasair.org
Posted: Tue Feb 27, 2007 9:47 am Post subject: Glass for IFRGlass for IFR |
Have any of you thought of the alternator frying and in the process burning out the battery contactor and opps, no electro wizzies. Flip all the dead switches you want, no joy. Is there a reason why every certified installation of an EFIS in a GA airplane has a Vacuum Attitude Indicator, ASI, and Altimeter as the backup?
Wait you say, I have a duel bus/battery power distribution system and that won't happen. It's happened. The last one I read about was an Airbus loosing all, and I mean ALL, power in the the cockpit. Total dark panel. The only thing left was that little 2.5 inch backup Jet Attitude Gyro and a flashlight. (as an asside, what's the reboot time for your EFIS systems if you have an electrical hiccup? Can you fly without it for 3-4 minutes, IMC, in turblance?)
Or, you're flying along in solid IMC and the cockpit starts filling with smoke. Smells like an electrical fire but no breakers have tripped. What do you do? Kill the master switch? But you need the EFIS to keep the right side up. Keep the electrical system operable and hope you can get on the ground before something more serious happens?
Think these equipment decisions through with care, your life is dependant on it.
Bruce
www.glasair.org
Posted: Tue Feb 27, 2007 9:50 am Post subject: Glass for IFRGlass for IFR |
I think the FAA emphasis is on reducing pilot workload and using all
available tools to do so. What would you do in your airplane if you had an
electrical fire?
Bruce
www.glasair.org
bo124rs(at)hotmail.com Guest
Posted: Tue Feb 27, 2007 10:03 am Post subject: Glass for IFRGlass for IFR |
| Quote: | From: "Bruce Gray" <Bruce(at)glasair.org>
I on the other hand see that as comforting. My glass setup has just that
style autopilot redundancy. IMC, there ya go George, fly on.
Dana Overall
Richmond, KY i39
RV-7 slider, Imron black, "Black Magic"
O 360 A1A, C/S C2YK-1BF/F7666A4
http://rvflying.tripod.com/blackwing1.jpg
Don’t miss your chance to WIN 10 hours of private jet travel from Microsoft®
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Tue Feb 27, 2007 10:39 am Post subject: Glass for IFRGlass for IFR |
I would make an emergency descent and land ASAP. Glass or steam gauge. I will have at least once source of attitude reference that is completely independent of the airplane electrical system. It will not be vacuum.
David Maib
40559
QB wings
On Feb 27, 2007, at 11:49 AM, Bruce Gray wrote:
--> RV-List message posted by: "Bruce Gray" <Bruce(at)glasair.org (Bruce(at)glasair.org)>
electrical fire?
Bruce
www.glasair.org
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
sportav8r(at)gmail.com Guest
Posted: Tue Feb 27, 2007 10:40 am Post subject: Glass for IFRGlass for IFR |
On 2/27/07, Bruce Gray <Bruce(at)glasair.org> wrote:
electrical fire?
Bruce
I'd radio my final instructions to my next of kin: get a mean lawyer
and sue the ever-loving stuffin's out of the companies that
manufactured the fuses and wire in the plane, because that simply
cannot occur unless _they_ made a _big_ mistake.
Actually, I'd roll over and go back to sleep, knowing I was dreaming,
since electrical fires don't happen in properly designed and built
cockpits, for the reason given above. But I might worry a little
that, once asleep again, I'd return to dreaming about "dark and stormy
night" scenarios. It's more likely I'd have dreams about vacuum
system failures, because they are much more likely.
Put another way, Bruce, I think if your question was posed on the
AeroElectric list, you'd eventually hear that your time could be
better spent worrying about a prop bolt failure than about the
disastrous failure of a properly-designed and built electrical system
in an OBAM aircraft, given the statistical likelihood of each. I
believe Bob N. is right about that. You are welcome to differ, but
"please bring data."
-Stormy
who has "no problem" with triple-redundancy; it's good in avionics and
it's good in DC power distribution
Drink the KoolAid, Bruce Resistance is futile.
Actually, it's volts/amperes, but that's not important right now...
khorton01(at)rogers.com Guest
Posted: Tue Feb 27, 2007 10:41 am Post subject: Glass for IFRGlass for IFR |
On Tue, 27 Feb 2007 07:31:22 -0600
"Russell Daves" <dav1111(at)cox.net> wrote:
| Quote: | Nice panel. I have a stupid question, if you're flying along in solid
IMC
other
Bruce
www.glasair.org
If you are counting on this plan to work, you might want to see how well your autopilot handles when you engage it during an unusual attitude. Maybe it'll do OK, but I suspect it won't do so well from anything more than minor unusual attitudes. If your autopilot isn't up to the task, it is better to find that out on a nice blue sky day than to make this discovery after you end up in an unusual attitude due to an EFIS that has lost its way.
Kevin Horton
jjessen
Bruce, these are good points, but we do have all electric GA IFR aircraft being built. I believe the Columbia is one such, with full redundancy. Perhaps many builders are not including the full redundancy, and that is something to consider. But, I think it's fair to say that GA manufacturers are trying hard to get vacuum out of their lexicon. >From their website:
Redundant Electrical Systems - Other modern aircraft advertise being “all-electric”, however the dual electrical systems on Columbia aircraft are fully-redundant. The critical difference between dual and redundant is that many aircraft with dual electrical systems have a lesser back-up electric system that cannot operate all standard systems. Consequently, the pilot is forced to make critical decisions to shed power, pull breakers and/or run a partial panel. The second electrical system on Columbia aircraft is a fully redundant system equal in every way to the other system. Thus either electrical system on a Columbia aircraft can start the aircraft and run all standard systems independent of the other electrical system. Dual 60 amp alternators, dual 15 amp hour batteries, dual busses and dual wiring harnesses ensure that an electrical emergency will not force the pilot to shed power, pull breakers, turn off critical standard systems or fly a partial panel in the event of an electrical emergency. Safety by Design - Not by Default.
Sent: Tuesday, February 27, 2007 9:46 AM
Bruce
www.glasair.org
Posted: Tue Feb 27, 2007 10:45 am Post subject: Glass for IFRGlass for IFR |
The way you respond to this is that my engine is electrically dependant so I can not kill the master, but I do have redundant busses and I can kill the avionics buss. My dynon is battery powered, the 496 is battery powered, and so is the portable Icom radio. So I can still stay up right, navigate, and communicate. The engine is on the e-buss and so is the prop controller, and will last more than 1 hour on this battery, which can be parallel, prior in the circuit to the avionics master, with the other battery to extend the flight if necassary. Other than that we get into sky is falling routine and if you are that paranoid you should not be flying single engine IFR in the first place.
IMHO
Dan
N289DT
Sent: Tuesday, February 27, 2007 12:46 PM
Bruce
www.glasair.org
Posted: Tue Feb 27, 2007 10:46 am Post subject: Glass for IFRGlass for IFR |
| Quote: | Or, you're flying along in solid IMC and the cockpit starts filling with
side
up.
Uh, rely on the internal Dynon backup battery............................
Dana Overall
Richmond, KY i39
The average US Credit Score is 675. The cost to see yours: $0 by Experian.
http://www.freecreditreport.com/pm/default.aspx?sc=660600&bcd=EMAILFOOTERAVERAGE
dan(at)rvproject.com Guest
Posted: Tue Feb 27, 2007 11:15 am Post subject: Glass for IFRGlass for IFR |
Anybody else have a Garmin handheld with their "simulated panel" interface?
It's actually pretty darn reliable! Definitely hope I never have to rely on
that, but at a minimum it can be an additional data point in the scan.
)_( Dan
rocketbob(at)gmail.com Guest
Posted: Tue Feb 27, 2007 12:21 pm Post subject: Glass for IFRGlass for IFR |
You know, it never ceases to amaze me how complicated the average RV builder nowadays can make their airplane. Dual, triple, quadruple EFIS'es, dual batteries, dual alternators, etc. I once asked a guy who had such stuff in his airplane what he was supposed to do if the main battery shorted, and how you would isolate it. The response I got was, well you pull this breaker, no wait, that's not right, you pull this one, then, ummm pull this one. I think... Hmmm... To see panel bling in an RV with a fixed-pitch prop boggles my mind even more!
As Dan has pointed out, the Garmin simulated panel works amazingly well. A Garmin 396 is as close to an EFIS as I will ever need in any airplane I build, along with old school no-bling round instruments. Just my $.02. I'll have less $$ in my F1 than many RV builders have in their panel alone, with just as much panel functionality. Gotta put my kids thru college someday.
Bob Japundza
RV-6 flying F1 under const.
Posted: Tue Feb 27, 2007 12:40 pm Post subject: Glass for IFRGlass for IFR |
Right on, if you can't fly your airplane with the master switch off, you're not doing something right.
Bruce
www.glasair.org
jpl(at)showpage.org Guest
Posted: Tue Feb 27, 2007 1:07 pm Post subject: Glass for IFRGlass for IFR |
I think some bling makes sense. Because these are experimental
aircraft, I think some sort of engine monitor is a pretty good idea.
If you're going to do that, then something like dual-Dynons seems a
pretty logical choice. You end up with a very pleasant panel to fly
at a fairly reasonable cost.
A lot of us really don't want to put vacuum instruments into our
panel. Vacuum pumps fail. But I have *never* had an automobile
alternator fail, nor the associated equipment. I don't even take
particularly good care of my cars, and my current car has 170k miles
on it and is 12 years old.
Something to wonder -- what is the cost of a vacuum pump as compared
to a second (small) alternator and related goodies? Is swapping out
that alternator for a backup electrical system really adding anything
to the cost? I don't know, as i haven't priced it.
If the guy you talked to didn't know how to isolate his battery, that
means he didn't have things labeled clearly. It doesn't indicate a
flaw in the overall plan so much as a detail to consider. It's a
good question and one that any pilot should be able to answer before
hitting Start.
My panel will be such that a single failure in the clouds leaves me
enough system to find an airport.
-Joe
On Feb 27, 2007, at 2:21 PM, Bob J. wrote:
| Quote: | You know, it never ceases to amaze me how complicated the average
Bob Japundza
Posted: Tue Feb 27, 2007 1:33 pm Post subject: Glass for IFRGlass for IFR |
Bruce Gray wrote:
electrical fire?
Bruce
www.glasair.org
This is a different question than the one you first posed.
You first asked "if you're flying along in solid IMC and all of a sudden
one of your EFIS says you're turning right and the other says you're
turning left, on which one do you bet your life?"
In my opinion the replies about letting the autopilot break the tie are
valid.
But you have now raised a different, unrelated question concerning an
electrical fire. Granted, ANY fire while airborne is potentially deadly
and one of our worse fears. But, with good wiring architecture the odds
of an electrical fire are very low, probably much lower than the odds I
will wad up the plane in a landing accident.
What does concern me greatly, however, is how many pilots think they can
hand fly their RVs in the crud on partial panel (airspeed, altimeter,
turn coordinator) while being stressed out with an inflight emergency. I
think the chances of surviving that scenario are very low but the odds
can be greatly improved by providing redundant, independent electrical
flight instruments (EFIS, autopilot, etc) that have the capability of
providing quality flight info.
Sam Buchanan
Bruce Gray wrote:
> Now that's scary!
Sam Buchanan
> Bruce
> www.glasair.org
