garrys(at)tampabay.rr.com Guest
Posted: Sun Feb 25, 2007 10:38 am Post subject: Nose Gear Intersection Leg Fairing |
Vans has recently offered a nose gear leg to cowl intersection fairing. I purchased one for my RV 7A and am left scratching my head as to how this should be installed such that I can still remove the lower cowl. Has anyone on the list installed one of these, or alternatively have they built one from scratch? How did you attach this fairing?
Garry Stout
Odessa FL
[quote] [b]
ronlee(at)pcisys.net Guest
Posted: Sun Feb 25, 2007 12:17 pm Post subject: Nose Gear Intersection Leg Fairing |
| Quote: | Vans has recently offered a nose gear leg to cowl intersection fairing.
Mine is attached with three smallish screws on each side along the main
body and one at the aft
end.
This message was sent using Endymion MailMan.
http://www.endymion.com/products/mailman/
matthew(at)n523rv.com Guest
Posted: Sun Feb 25, 2007 4:33 pm Post subject: Nose Gear Intersection Leg Fairing |
What's the quality of the nose gear fairing? I ordered the main gear intersection fairings and they were pretty darn poor quality IMHO.
Matthew
RV-9A :: N523RV
www.n523rv.com
Posted: Sun Feb 25, 2007 5:58 pm Post subject: Nose Gear Intersection Leg Fairing |
Rick Galati
Joined: 10 Jan 2006 Posts: 91 Location: Lake St. Louis MO.
Posted: Mon Feb 26, 2007 12:53 pm Post subject: Nose Gear Intersection Leg Fairing |
My high quality Bob Snedaker (Fairings-etc.) upper nose gear intersection fairing is held in place by 2 #6 screws. The nutplates are attached to bits of aluminum attached to the lower cowl. The fairing sits in a recess of built-up filler producing a smooth transition with the lower cowl. To remove the lower cowl, I just remove the 2 screws holding the fairing in place and let the fairing slide down and out of the way on the leg fairing.
http://img232.imageshack.us/img232/9435/uppernosegearlegfairingxc6.jpg
Rick Galati RV-6A "Darla"
Dale Ensing
Posted: Tue Feb 27, 2007 4:34 am Post subject: Nose Gear Intersection Leg Fairing |
Rick,
Your nose gear intersection fairing appears to fit the gear leg fairing much better then mine. On mine, the intersection fairing opening (Fairings-etc) is wider than the gear leg fairing (Van's). Did you do anything to make this a better fit?
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Rick Galati
Posted: Tue Feb 27, 2007 5:12 am Post subject: Nose Gear Intersection Leg Fairing |
Dale,
The intersection fairing is wider than the gear leg fairing. I would suppose it is designed that way to avoid almost certain chafing as the nose gear flexes quite a bit fore and aft depending upon the varying weight and load conditions imposed upon it.
Rick,
Dale Ensing
