berkut13(at)berkut13.com Guest
Posted: Fri Feb 16, 2007 8:54 pm Post subject: Com issues - resolved |
Well gang...it's fixed.
I added 150ohm resistors to all input audio leads into the panel.
Everything is living together quite nicely now. I guess something in the
combination was not playing well with the new radio.
However, there was one wild card that might also have something to do with
it. While I was removing, moving, installing, and re-installing the pins in
the 134's connector, one of the ground leads (mic I think) broke off a pin.
I was forced to strip and crimp a new molex pin on there and re-secure.
This was done in the same operation as the resistors. After all that, the
audio was loud and clear with all radios mixed in, regardless of the
combination. I'm not convinced this was the issue, since the radio did work
correctly by itself.
So...was it the resistors?...was it a bad ground?...was it a gremlin?
Personally, I don't care anymore...it's fixed!
Thanks for all the help, everyone. Nothing like beating your head against
the wall in a cold hangar.
James Redmon
Berkut #013 N97TX
http://www.berkut13.com
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Avionics-List |
douglist(at)macnauchtan.c Guest
Posted: Sat Feb 17, 2007 10:29 am Post subject: Com issues - resolved |
At 22:47 -0600 2/16/07, <berkut13(at)berkut13.com> wrote:
| Quote: | So...was it the resistors?...was it a bad ground?...was it a gremlin? Personally, I don't care anymore...it's fixed!
A flight instructor where I last did avionics for profit was also a personal boat enthusiast.
His expressed belief was "ALL electric problems in boats and automobiles are CAUSED by bad grounds."
After a couple of beers one night we agreed that airplanes should be included in the ALL part of that.
--> The best programming tool is a soldering iron <--
wjrhamilton(at)optusnet.c Guest
Posted: Sat Feb 17, 2007 11:17 pm Post subject: Com issues - resolved |
All,
Ain't that (almost) the truth.
If you look around the supply houses, on eBay from time to time, etc., you will find a set of the answers to clean contacts, including cleaning ring terminals.
They are a shaft that goes in a drill, the shank comes in #30, 40 etc., and has an abrasive bundle around the shank. The abrasive surfaces are arranged so that they scour the contact area. Haven't has a problem with a high resistance contact since I bought a set.
Sorry, no name on them.
Bill Hamilton
At 05:27 AM 18/02/2007, you wrote:
[quote]--> Avionics-List message posted by: Doug McNutt <douglist(at)macnauchtan.com>
- NEW MATRONICS WEB FORUMS -
http://forums.matronics.com
CONFIDENTIALITY & PRIVILEGE NOTICE
W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net.<wjrhamilton(at)optusnet.com.au> & <GlenalmondEngineering(at)Gmail.com> This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery.
If you have received this message in error, please notify us immediately to: Australia 61 (0)408 876 526
Dolores capitis non fero. Eos do.
