cowcam(at)pipcom.com Guest
Posted: Fri Feb 16, 2007 7:05 am Post subject: Engine storage |
Someone asked about anyone not having problems with unpickled engine. Several years ago I removed an 0360 Lycoming for an airframe re-build and left it hanging in a leaky barn. Everytime I walked by it I kicked myself for how I was treating it: no oil added anywhere and no plugs in the exhaust or intake. After maybe 4 years I decided that since I was going to sell the project it would best to send the engine into a shop to check for corrosion and top it. No problems anywhere.
I live in southern Ontario Can. so see a variety of weather.
Peter
| - The Matronics Engines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
kmodairy(at)centurytel.ne Guest
Posted: Fri Feb 16, 2007 10:12 am Post subject: Engine storage |
Thanks for the good news that not every engine goes bad. If I were to pull a jug which one would give the best view of the cam and would that screw up the ring seat for that cylinder, Thanks again
w_sweet(at)comcast.net Guest
Posted: Fri Feb 16, 2007 12:26 pm Post subject: Engine storage |
I had a maintenance shop look at my engine that was sitting for two years; they said to pull #1 and #4. That would allow to see all the cam lobes.
Wayne
Hopperdhh(at)aol.com Guest
Posted: Fri Feb 16, 2007 4:10 pm Post subject: Engine storage |
In a message dated 2/16/2007 1:13:59 PM Eastern Standard Time,
kmodairy(at)centurytel.net writes:
Thanks again
No, you don't have to unseat the rings. Put the piston at top center. Pull
the cylinder off far enough to just clear the wrist pin. Push the pin out and
leave the piston in the cylinder. This is a two man job. You will need help
getting the pin out, and also to help you to not drop the rod and mar the
case.
Dan Hopper
RV-7A
