				 Posted: Sat Feb 04, 2006 2:44 am    Post subject: Voltage Regulator Failure |
				Tim, I had similar problems with my rectifierlast year, completely cured by
 replacing it, but you may find the message below of help. Afraid I was too
 keen to get back flying to follow the diagnostic advice! Regards, David
 Joyce, G-XSDJ
				 Posted: Sat Feb 04, 2006 3:07 am    Post subject: Voltage Regulator Failure |
 Joyce, G-XSDJ
 Joyce, G-XSDJ
		rholder(at)avnet.co.uk Guest
				 Posted: Sat Feb 04, 2006 3:08 am    Post subject: Voltage Regulator Failure |
				David Joyce wrote:
  	  | Quote: | 	 		   Tim, I had similar problems with my rectifier last
  year, completely cured by replacing it, but you may
  find the message below of help. Afraid I was too keen
  	  | Quote: | 	 		   Regards, David Joyce, G-XSDJ
 For a scientific person that wasn't very logical ! What if
 replacing the rectifier/regulator (RR) didn't cure it ?
 What (and this is what happened to me) the replacement was
 faulty ?
 The possible problem areas are
 Stator
 Stator wiring to RR
 RR
 Control wire to RR
 Battery wire to RR
 Earth wire to RR
 And the problem needs to be identified ! Bob's guidance is
 spot on !
 If it is actually the RR then there are two possibilities
 1. A component has actually failed  or
 2. The soldering of a component has failed (a dry joint)
 In the case of 1. the charge will stop and it won't
 re-start. In the case of 2. it may restart and work
 intermittently.
 The soldering is a bit wild in there, but the continual
 heating up in use under the cowling and cooling on
 shutdown is a recipe for dry joints if the job wasn't done
 well in the first place.
 My replacement was faulty (the ammeter vibrated between 1
 and 10 amps 5 times a second at and above 5000 rpm). It
 has been returned for the supplier to test and replace.
 My old intermittent failing RR was attacked with a
 soldering iron to clean up three possible dry joints and
 has been refitted. It worked but the wx has been so bad I
 haven't had the chance to test it for long enough to
 determine whether I have fixed it. I am not optimistic but
 pigs might fly one day.
 Did you keep your old RR as a spare (it works sometimes -
 which is better than one that doesn't work at all !) ?
 If you have it but don't want it would you donate it to me
 ?   For research !
 Best wishes
 Richard Holder
 G-OWWW High Cross.
				 Posted: Sat Feb 04, 2006 3:21 am    Post subject: Voltage Regulator Failure |
 Joyce, G-XSDJ
 Joyce, G-XSDJ
 Joyce, G-XSDJ
 Joyce, G-XSDJ
				 Posted: Sat Feb 04, 2006 3:35 am    Post subject: Voltage Regulator Failure |
 Joyce, G-XSDJ
 Joyce, G-XSDJ
 Joyce, G-XSDJ
 Joyce, G-XSDJ
 Joyce, G-XSDJ
 Joyce, G-XSDJ
 Joyce, G-XSDJ
 Joyce, G-XSDJ
				 Posted: Sat Feb 04, 2006 3:51 am    Post subject: Voltage Regulator Failure |
 Joyce, G-XSDJ
 Joyce, G-XSDJ
 Joyce, G-XSDJ
 Joyce, G-XSDJ
