Posted: Sat Feb 04, 2006 2:44 am Post subject: Voltage Regulator Failure |
Tim, I had similar problems with my rectifierlast year, completely cured by
replacing it, but you may find the message below of help. Afraid I was too
keen to get back flying to follow the diagnostic advice! Regards, David
Joyce, G-XSDJ
Posted: Sat Feb 04, 2006 3:07 am Post subject: Voltage Regulator Failure |
Joyce, G-XSDJ
Joyce, G-XSDJ
rholder(at)avnet.co.uk Guest
Posted: Sat Feb 04, 2006 3:08 am Post subject: Voltage Regulator Failure |
David Joyce wrote:
| Quote: | Tim, I had similar problems with my rectifier last
year, completely cured by replacing it, but you may
find the message below of help. Afraid I was too keen
| Quote: | Regards, David Joyce, G-XSDJ
For a scientific person that wasn't very logical ! What if
replacing the rectifier/regulator (RR) didn't cure it ?
What (and this is what happened to me) the replacement was
faulty ?
The possible problem areas are
Stator
Stator wiring to RR
RR
Control wire to RR
Battery wire to RR
Earth wire to RR
And the problem needs to be identified ! Bob's guidance is
spot on !
If it is actually the RR then there are two possibilities
1. A component has actually failed or
2. The soldering of a component has failed (a dry joint)
In the case of 1. the charge will stop and it won't
re-start. In the case of 2. it may restart and work
intermittently.
The soldering is a bit wild in there, but the continual
heating up in use under the cowling and cooling on
shutdown is a recipe for dry joints if the job wasn't done
well in the first place.
My replacement was faulty (the ammeter vibrated between 1
and 10 amps 5 times a second at and above 5000 rpm). It
has been returned for the supplier to test and replace.
My old intermittent failing RR was attacked with a
soldering iron to clean up three possible dry joints and
has been refitted. It worked but the wx has been so bad I
haven't had the chance to test it for long enough to
determine whether I have fixed it. I am not optimistic but
pigs might fly one day.
Did you keep your old RR as a spare (it works sometimes -
which is better than one that doesn't work at all !) ?
If you have it but don't want it would you donate it to me
? For research !
Best wishes
Richard Holder
G-OWWW High Cross.
Posted: Sat Feb 04, 2006 3:21 am Post subject: Voltage Regulator Failure |
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Posted: Sat Feb 04, 2006 3:35 am Post subject: Voltage Regulator Failure |
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Posted: Sat Feb 04, 2006 3:51 am Post subject: Voltage Regulator Failure |
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
Joyce, G-XSDJ
