Ultralight Callsign
Goto page Previous  1, 2, 3  Next
jim
PostPosted: Wed Feb 14, 2007 9:17 pm    Post subject: Ultralight Callsign Reply with quote
How much fuel could you stuff into that 12" boom? I figure nearly 100
gallons. Although I think I'd go for at least the O320.
Get it registered with the EAA as I have mine now even though its FAT I
feel
I needed something to announce my Approach /Departure and any other
movements
I had to do around any airports Just seemed to make things safer in my
mind
But I am going to be getting N numbered this spring as I have been
taking
Ground school lately and I will be getting legal after 16 years of flying
I
guess my free flying time is about to end
Hey then mabe I can build me a 4 place Kolb with a 12 inch tail boom tube,
Aluminum wings,O235 Might have to call it a John Hauck Special for the
long
cross countrys Wududa You Guys think? ...... LOL....... I just might be
serious,
ask my friends
Original Firestar E008EB
Ellery
Jim
N. Idaho
jim
PostPosted: Wed Feb 14, 2007 9:26 pm    Post subject: Ultralight Callsign Reply with quote
BEAUTIFUL PICTURE !!!! Wow, that would make a GREAT postcard.
I thought about using my FF s/n as part of the call sign, but I'd rather
not have anything traceable to me.
This is off the original topic, but . . .
Controlled airspace does not imply a tower. The Coeur d'Alene, Idaho
(KCOE) airport is uncontrolled (i.e., no tower), but has surface Class E
airspace within 5sm (to provide separation protection for the instrument
approaches). Outside 5sm it becomes Class E airspace above 700 AGL, and
eventually uncontrolled airspace. As I read the regs I cannot fly into
that airspace in an ultralight unless I contact Spokane Approach Control.
Talking to local UL pilots, NOBODY contacts RAPCON. If they have a radio
they will do as GA pilots do -- tune in the CATF and make their calls.
I was at the Spokane FSDO (FAA) office a few weeks ago and asked them
about this. The "Operations" guy there said the Surface Class E was not
active unless it was IFR so during VFR the floor of the Class E airspace
over KCOE was 700 AGL. I had never seen this in the regs. I thought
surface class E was always there. I told him that seemed unsafe if the
regs would force me to fly below 700AGL over an airport which would
interfere with traffic. He then backed down saying he didn't know
anything about ultralights.
As you know, VFR GA pilots have no requirement to contact ATC in Class E
airspace. It seems odd that the regs would require UL pilots to do this,
but this is what the regs appear to say.
The bottom line: I don't know for sure and it appears the FAA doesn't
either.
14feb07
Jim,
My FireFly was regestered with the EAA. They gave
the plane E005CB as a reg. number. I have it on the
tube in front of the tailfeathers in 4" numbers. As an
ultralight I stay away from controled airspace, so I
don't talk to the tower... But while on the radio to
broadcast my intentions at uncontroled airports and
CTAF I use "Ultralight Five Charlee Bravo".
Attached is a photo shot from a Caravan at 7,000ft.
It shows east Maui... the Hana airport, Hana bay and
above the clouds the summit of Haleakala (10,000 ft.)
Aloha,
Henry
Henry Voris
P.O.Box 1194
Kula,Hawaii 96790
henry_voris(at)yahoo.com
808-878-2443
Jim
N. Idaho
Dave Bigelow
PostPosted: Thu Feb 15, 2007 1:57 am    Post subject: Re: Ultralight Callsign Reply with quote
Since the early 80's when I first started carrying a hand held VHF radio in ultralights, I have used the station license of the radio for a call sign. I'm always Ultralight 10U no matter what model ultralight I'm flying.
Even though the regulations don't address it specifically, aircraft other than certified GA aircraft usually use the type aircraft rather than the manufacturor in the call sign. For instance, a Phoebus sailplane will always call himself "Sailplane 90WS" rather than "Phoebus 90WS". A Grob motor glider will call himself "Motor Glider 90WS" rather than "Grob 90WS". Usually, I hear experimental aircraft using the call sign "Experimental 90WS", rather than including a manufacturor's name (like Kolb).
After registration, I plan on calling myself "Light Sport 90WS" (actual numbers will be the registration numbers). My guess is that once the light sport category becomes popular, they will shorten that to "Sport 90WS". Probably during initial contact with tower, the best would be to use "Light Sport 90WS Experimental".
Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E
jbhart(at)onlyinternet.ne
PostPosted: Thu Feb 15, 2007 5:15 am    Post subject: Ultralight Callsign Reply with quote
At 08:52 PM 2/14/07 -0800, you wrote:
>> § 103.17 Operations in certain airspace.
>> No person may operate an ultralight vehicle within
>> Class A, Class B, Class C, or Class D airspace or
>> within the lateral boundaries of the surface area of
>> Class E airspace designated for an airport unless
>> that person has prior authorization from the ATC
>> facility having jurisdiction over that airspace.
>> The required authorization is required to be
>> obtained while the ultralight is still on the ground
>> and the ATC Facility contacted will give specific
>> instructions to the ultralight vehicle operator.
The above makes no requirement to obtain authorization while still on the
ground.
Jim,
Am I missing something here?
For the last several years I have been flying into tower controlled airports
for fly ins. I always used a cell phone to call before leaving the ground.
I have never been denied permission to land. I told them I was a red Kolb
FireFly, I would explain my route, and we would agree on a holding pattern
within sight of the tower until they could pick me up. I told them I could
hear them on the radio but due to the open cockpit they would not be able to
understand any thing I said. They always picked me up right away and phased
me in between other air craft. On one trip they called me several times on
the way to ask where I was. They phrased the questions so I could use PTT
clicks to answer yes or no.
To get back out, I tail along with someone who has a good radio, or I use my
cell phone.
The main thing is to not tie up the runways. I fly to the ramp or cruise
taxi.
Jack B. Hart FF004
Winchester, IN
Thom Riddle
PostPosted: Thu Feb 15, 2007 5:36 am    Post subject: Ultralight Callsign Reply with quote
Arty,
I've been doing the same with our Allegro 2000 (not experimental) ,
that is, using the prefix Light Sport. Initially when I used Allegro
as a prefix there was nearly always a pause then a question asking for
clarification of type in a perplexed tone of voice. Once I started
using Light Sport the questions have diminished greatly. Sometimes I
get questions out of curiosity about the make but no more confusion
about type or category. I'm still waiting on the FAA to come up with a
4 digit code for the type. I've been asked this before by ATC and I
tell them we are still waiting on the FAA for the assignment.
FYI - FAA assigned codes for aircraft can be found here
http://www.faa.gov/ATPUBS/CNT/5-1.htm
Thom in Buffalo
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
jindoguy(at)gmail.com
PostPosted: Thu Feb 15, 2007 5:56 am    Post subject: Ultralight Callsign Reply with quote
On first call to ground or tower, I was taught use the type and registration, i.e. "Cessna 7568 Tango", all acknowledgements would then be shortened to 68 Tango. When riding in the back of my buddies LongEZ, the first call was "Experimental 455 Zulu Delta" and all acknowledgements were 4 Zulu Delta. The only time I was ever asked for more information was when requesting flight following. The controllers at Whidbey Island NAS always asked "68 Tango, say aircraft type". "68 Tango is a Cessna 182".
During one particularly dead evening as my date and I were coming back from a late dinner in Friday Harbor, I got a chance to chat with the controller a bit. He said it was their practice to assign transponder codes that reflected aircraft type, so they would know speed range, and direction of travel. Does this correspond to the experience of you ex ATC guys?
At the Arlington Airshow the controllers in the temporary tower expect you to call ahead from a predetermined point. That was the only time they wanted to hear from aircraft. After that, the practice was don't call us, tower will call you, and no acknowledgement was wanted, other than follow their instructions.
Rick
On 2/15/07, Jack B. Hart <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)> wrote:
--> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)>
--> Kolb-List message posted by: "Jim Dunn" < jim(at)tru-cast.com (jim(at)tru-cast.com)>
ground.
Jim,
cell phone.
taxi.
Jack B. Hart FF004
Winch=================== ef="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.co===================== =========
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
Richard Pike
PostPosted: Thu Feb 15, 2007 7:00 am    Post subject: Ultralight Callsign Reply with quote
Yep. Used it all the time. Or at least whenever I was working a homebuilt.
Here is part of the FAA manual that describes what you are looking for.
http://www.faa.gov/ATpubs/CNT/5-3.htm
It is a system whereby ATC knows what you are and how fast you are on a flight plan.
HXA is a homebuilt experimental with a cruise speed of less than 100 knots. Kolbs fall into this category.
HXB is for humebuilts flying between 100 & 200 knots, HXC is homebuilts flying faster than 200 knots.
If your Kolb has transponder with mode C, then you are a HXA/A.
Now you know exactly what to put down when you file your next IFR flight plan for your Firestar...
Richard Pike
MKIII N420P (420ldPoops)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
PostPosted: Thu Feb 15, 2007 7:31 am    Post subject: Ultralight Callsign Reply with quote
Richard:
Canada wants the designator when you file VFR. They use the same one
as the US.
PS: I also used my FCC radio license for my call sign when flying the
Firestar. For got the numbers, but the prefix was N.
Richard Pike
PostPosted: Thu Feb 15, 2007 9:34 am    Post subject: Ultralight Callsign Reply with quote
Actually, if you ask approach or even center for flight following, those are
the same designators thye use also.
I was just being facetious about filing IFR in a Kolb.
Or at least I hope I was...
But if we stay on this list long enough, probably someone will come up with
an IFR certified Kolb. <gag>
Richard Pike
Richard Pike
Kingsport, TN 3TN0
PostPosted: Thu Feb 15, 2007 9:42 am    Post subject: Ultralight Callsign Reply with quote
up with
| Richard Pike
Richard:
I know one Kolb pilot you will not have to worry about flying a Kolb
aircraft IFR. For that matter, I seldom fly at night anymore.
Usually, only if I get caught out before I make my next landing.
DO NOT ARCHIVE
Russ Kinne
PostPosted: Thu Feb 15, 2007 10:50 am    Post subject: Ultralight Callsign Reply with quote
OK I'll bite. What does LEBTF stand for?
I confess I don 't know. I can imagine some great ones tho.
And please remember that great non-cuss-phrase,
On Feb 14, 2007, at 11:14 PM, Larry Cottrell wrote:
<lcottrell(at)fmtcblue.com>
John Williamson
PostPosted: Thu Feb 15, 2007 12:43 pm    Post subject: Re: Ultralight Callsign Reply with quote
This gets to be a little long, but some clarifications are in order:
-- Shall: means a procedure is mandatory.
-- Should: means a procedure is recommended.
-- May: means a procedure is optional.
-- Will: means futurity, not a requirement for the application of a procedure.
“I use “Experimental 381PM “, Then after first call.... I use ... One ,Poppa, Mike”
*** ATC specialists may initiate abbreviated call signs of other aircraft by using the prefix and the last three digits/letters of the aircraft identification after communications are established. The pilot may use the abbreviated call sign in subsequent contacts with the ATC specialist.
“On first call to ground or tower, I was taught use the type and registration, i.e. “Cessna 7568 Tango”, all acknowledgements would then be shortened to 68 Tango. When riding in the back of my buddies LongEZ, the first call was “Experimental 455 Zulu Delta” and all acknowledgements were 4 Zulu Delta.”
“P.S. So many experimentals do not have recognizable manufacturer names to GA pilots, so my instructor told me just to say “Experimental Two Two Six Niner Juliet” rather than “Aventura Two Two Six Niner Juliet Experimental”... and that’s what I did in a variety of Class D and Class C airspaces, and every pattern, and I never, ever had anyone—pilot or ATC—suggest it was wrong or should be different. And it was/is a WHOLE lot simpler, too. So, that’s typically what I use now, even when I fly an ultralight.”
*** Civil aircraft pilots should state the aircraft type, model or manufacturer's name, followed by the digits/letters of the registration number.
“HOWEVER - almost no one outside the ultralight arena knows what a MaxAir Drifter is, so it doesn’t tell them anything about my speed in the pattern, which is a key factor in separation at non-towered airports. I land at 35 -38 mph.”
“Generally you’d say “Maxair” or “Drifter” but not both... but most of the experimental guys I know would just identify as “Experimental one-niner-six-four-Charlie”. If the tower needs to know more they’ll ask.”
*** Using MaxAir or Drifter and your number is the correct callsign. The word “Experimental” as the prefix in a callsign is never correct.
“For Experimental or E-LSA, Kolb would not be the manufacturer unless Elmer Kolb built and N-numbered your aircraft. Technically the builder is the person that assembled it. Also, don’t include the model in the call sign. You never hear Cessna 182 147PG as a callsign, it would be Cessna
147PG.”
*** Aircraft type, model or manufacturer's name has been accepted by the FAA to include the Kit Manufacturer name and the precedence is in http://www.faa.gov/airports_airtraffic/air_traffic/publications/atpubs/CNT/5-2.htm
“I’ve never heard that. As I’ve always understood it, “prior authorization” can be obtained while airborne, as long as you contact ATC before entering their airspace. Do you have a cite for the ground contact requirement?”
*** AIR TRAFFIC CLEARANCE- An authorization by air traffic control for the purpose of preventing collision between known aircraft, for an aircraft to proceed under specified traffic conditions within controlled airspace. The pilot-in-command of an aircraft may not deviate from the provisions of a visual flight rules (VFR) or instrument flight rules (IFR) air traffic clearance except in an emergency or unless an amended clearance has been obtained. Additionally, the pilot may request a different clearance from that which has been issued by air traffic control (ATC) if information available to the pilot makes another course of action more practicable or if aircraft equipment limitations or company procedures forbid compliance with the clearance issued. Pilots may also request clarification or amendment, as appropriate, any time a clearance is not fully understood, or considered unacceptable because of safety of flight. Controllers should, in such instances and to the extent of operational practicality and safety, honor the pilot’s request. 14 CFR Part 91.3(a) states: “The pilot in command of an aircraft is directly responsible for, and is the final authority as to, the operation of that aircraft.” THE PILOT IS RESPONSIBLE TO REQUEST AN AMENDED CLEARANCE if ATC issues a clearance that would cause a pilot to deviate from a rule or regulation, or in the pilot’s opinion, would place the aircraft in jeopardy.
*** I don’t have any citation of the “ground contact requirement” except for common sense. I wouldn’t fly up to an area and hope to be able to contact a controlling facility whose receiver might be a long way for my little radio to reach.
“You can get authorization by radio to deviate from the transponder/mode C requirement for Class B & C. If you don’t have a radio it would have to be from the ground. If you don’t have a Xpdr/mode C installed, it can be 1 hour prior (either by air or on the ground).”
*** There ia a big difference between asking for “Prior Authorization” and a “Deviation”. Since an Ultralight is not an airplane, and FAR 91 does not apply, it can’t be granted a “deviation”, an ATC facility does have the ability to “Authorize” it to perform a specific action.
*** ATC authorized deviations. Requests for ATC authorized deviations must be made to the ATC facility having jurisdiction over the concerned airspace within the time periods specified as follows:
(1) For operation of an aircraft with an operating transponder but without operating automatic pressure altitude reporting equipment having a Mode C capability, the request may be made at any time.
(2) For operation of an aircraft with an inoperative transponder to the airport of ultimate destination, including any intermediate stops, or to proceed to a place where suitable repairs can be made or both, the request may be made at any time.
(3) For operation of an aircraft that is not equipped with a transponder, the request must be made at least one hour before the proposed operation.
“As I read the regs I cannot fly into that airspace in an ultralight unless I contact Spokane Approach Control. Talking to local UL pilots, NOBODY contacts RAPCON. If they have a radio they will do as GA pilots do—tune in the CATF and make their calls.”
*** Doing what the other fellow is doing wrong, doesn’t make it right.
“The “Operations” guy there said the Surface Class E was not active unless it was IFR so during VFR the floor of the Class E airspace over KCOE was 700 AGL.”
*** Your “Operations guy” needs to read the regs. Surface Based Class E airspace is as charted and always there. The big difference between that airport in Class E airspace as opposed to Class G airspace is the weather requirements to operate VFR.
§ 71.71 Class E airspace.
§ 91.127 Operating on or in the vicinity of an airport in Class E airspace.
§ 91.155 Basic VFR weather minimums.
Class E: Less than 10,000 feet MSL... 3 statute miles... 500 feet below, 1,000 feet above, 2,000 feet, 2,000 feet horizontal from clouds.
Class G:1,200 feet or less above the surface (regardless of MSL altitude) (with Exceptions) …… 1 statute mile.... Clear of clouds.
“It is a system whereby ATC knows what you are and how fast you are on a flight plan. HXA is a homebuilt experimental with a cruise speed of less than 100 knots. Kolbs fall into this category. HXB is for humebuilts flying between 100 & 200 knots, HXC is homebuilts flying faster than 200 knots. If your Kolb has transponder with mode C, then you are a HXA/A.”
*** An excellent explanation! The HXA, HXB and HXC are ICAO designations recognized worldwide for a homebuilt aircraft that hasn’t had a Type Designation applied for and assigned.
I could keep going but I’m getting tired. The regs aren’t that hard to read. Just remember that they are what they read and we can’t interpret them to what is convenient, or to match what you are or have been doing.
John Williamson
Arlington, TX
Kolbra, 912ULS, 1640 hours
http://home.tx.rr.com/kolbrapilot
David.Lehman
PostPosted: Thu Feb 15, 2007 1:04 pm    Post subject: Ultralight Callsign Reply with quote
John, you're obviously doing your homework, so I might have missed something...
Experimental Operation Limitations, IAW FAA Order 8130.2F, must contain the line item, "The pilot in command of this aircraft must notify air traffic control of the experimental nature of this aircraft when operating into and out of airports with an operational control tower. When filing IFR, the experimental nature of this aircraft must be listed in the remarks section of the flight plan "...
DVD
On 2/15/07, John Williamson <kolbrapilot1(at)comcast.net (kolbrapilot1(at)comcast.net)> wrote: [quote]--> Kolb-List message posted by: "John Williamson" < kolbrapilot1(at)comcast.net (kolbrapilot1(at)comcast.net)>
"I use "Experimental 381PM ", Then after first call.... I use ... One ,Poppa, Mike"
"On first call to ground or tower, I was taught use the type and registration, i.e. "Cessna 7568 Tango", all acknowledgements would then be shortened to 68 Tango. When riding in the back of my buddies LongEZ, the first call was "Experimental 455 Zulu Delta" and all acknowledgements were 4 Zulu Delta."
"P.S. So many experimentals do not have recognizable manufacturer names to GA pilots, so my instructor told me just to say "Experimental Two Two Six Niner Juliet" rather than "Aventura Two Two Six Niner Juliet Experimental"... and that's what I did in a variety of Class D and Class C airspaces, and every pattern, and I never, ever had anyone—pilot or ATC—suggest it was wrong or should be different. And it was/is a WHOLE lot simpler, too. So, that's typically what I use now, even when I fly an ultralight."
"HOWEVER - almost no one outside the ultralight arena knows what a MaxAir Drifter is, so it doesn't tell them anything about my speed in the pattern, which is a key factor in separation at non-towered airports. I land at 35 -38 mph."
"Generally you'd say "Maxair" or "Drifter" but not both... but most of the experimental guys I know would just identify as "Experimental one-niner-six-four-Charlie". If the tower needs to know more they'll ask."
*** Using MaxAir or Drifter and your number is the correct callsign. The word "Experimental" as the prefix in a callsign is never correct.
"For Experimental or E-LSA, Kolb would not be the manufacturer unless Elmer Kolb built and N-numbered your aircraft. Technically the builder is the person that assembled it. Also, don't include the model in the call sign. You never hear Cessna 182 147PG as a callsign, it would be Cessna
147PG."
*** Aircraft type, model or manufacturer's name has been accepted by the FAA to include the Kit Manufacturer name and the precedence is in http://www.faa.gov/ATPUBS/CNT/5-1.htm .
"I've never heard that. As I've always understood it, "prior authorization" can be obtained while airborne, as long as you contact ATC before entering their airspace. Do you have a cite for the ground contact requirement?"
*** AIR TRAFFIC CLEARANCE- An authorization by air traffic control for the purpose of preventing collision between known aircraft, for an aircraft to proceed under specified traffic conditions within controlled airspace. The pilot-in-command of an aircraft may not deviate from the provisions of a visual flight rules (VFR) or instrument flight rules (IFR) air traffic clearance except in an emergency or unless an amended clearance has been obtained. Additionally, the pilot may request a different clearance from that which has been issued by air traffic control (ATC) if information available to the pilot makes another course of action more practicable or if aircraft equipment limitations or company procedures forbid compliance with the clearance issued. Pilots may also request clarification or amendment, as appropriate, any time a clearance is not fully understood, or considered unacceptable because of safety of flight. Controllers should, in such instances and to the extent of!
operational practicality and safety, honor the pilot's request. 14 CFR Part 91.3(a) states: "The pilot in command of an aircraft is directly responsible for, and is the final authority as to, the operation of that aircraft." THE PILOT IS RESPONSIBLE TO REQUEST AN AMENDED CLEARANCE if ATC issues a clearance that would cause a pilot to deviate from a rule or regulation, or in the pilot's opinion, would place the aircraft in jeopardy.
*** I don't have any citation of the "ground contact requirement" except for common sense. I wouldn't fly up to an area and hope to be able to contact a controlling facility whose receiver might be a long way for my little radio to reach.
"You can get authorization by radio to deviate from the transponder/mode C requirement for Class B & C. If you don't have a radio it would have to be from the ground. If you don't have a Xpdr/mode C installed, it can be 1 hour prior (either by air or on the ground)."
*** There ia a big difference between asking for "Prior Authorization" and a "Deviation". Since an Ultralight is not an airplane, and FAR 91 does not apply, it can't be granted a "deviation", an ATC facility does have the ability to "Authorize" it to perform a specific action.
"As I read the regs I cannot fly into that airspace in an ultralight unless I contact Spokane Approach Control. Talking to local UL pilots, NOBODY contacts RAPCON. If they have a radio they will do as GA pilots do—tune in the CATF and make their calls."
*** Doing what the other fellow is doing wrong, doesn't make it right.
"The "Operations" guy there said the Surface Class E was not active unless it was IFR so during VFR the floor of the Class E airspace over KCOE was 700 AGL."
*** Your "Operations guy" needs to read the regs. Surface Based Class E airspace is as charted and always there. The big difference between that airport in Class E airspace as opposed to Class G airspace is the weather requirements to operate VFR.
"It is a system whereby ATC knows what you are and how fast you are on a flight plan. HXA is a homebuilt experimental with a cruise speed of less than 100 knots. Kolbs fall into this category. HXB is for humebuilts flying between 100 & 200 knots, HXC is homebuilts flying faster than 200 knots. If your Kolb has transponder with mode C, then you are a HXA/A."
*** An excellent explanation! The HXA, HXB and HXC are ICAO designations recognized worldwide for a homebuilt aircraft that hasn't had a Type Designation applied for and assigned.
I could keep going but I'm getting tired. The regs aren't that hard to read. Just remember that they are what they read and we can't interpret them to what is convenient, or to match what you are or have been doing.
John Williamson
Arlington, TX
Kolbra, 912ULS
http://home.comcast.net/~kolbrapilot1
ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw
Dennis.Kirby(at)kirtland.
PostPosted: Thu Feb 15, 2007 2:16 pm    Post subject: Ultralight Callsign Reply with quote
"jim" wrote: << When calling tower or Approach in an "N" numbered
aircraft you might use a callsign like "Experimental 3252Y", but what
about an Ultralight? What should I use for a callsign? >>
Jim, and Kolbers -
You are correct: The FAA requires that we incorporate the term
"Experimental" in the callsign of our N-numbered homebuilt aircraft.
But despite the fact that our Kolb 2-seaters are definitely not
ultralights, the perception amongst most other general aviation pilots
is, Kolbs are "ultralights." (As well as all the other similar light
sport aircraft in this category, such as Challengers, Rans', Titans,
etc.)
I don't know how many times I've been flying around my home airport
(doing pattern work, say), then land, and after shutting down, engage in
a conversation with one of the other local pilots that usually begins
like this: "Wazzat you in that there ultralight that just landed?"
Aarghh! These guys are idiots! I feel like saying, "Can't you see
there are TWO seats in my airplane?! Can't you tell that this 600 pound
machine is more that TWICE the allowable size of any ultralight?"
I was in the airport pattern once and was following a Skyhawk in for
landing. So I announced, "Experimental Kolb, niner three delta kilo, on
left downwind, number two, following the Cessna, for landing runway
nine." In spite of my clear identification of my aircraft, the 172
pilot came right back with, "Roger, I got the ultralight in sight."
(Idiots, I tell ya.)
Point is, most non-ultralight and non-light sport aircraft people see
all our Kolbs (and anything else smaller than a Cessna or Piper) as
simply "ultralights." It seems like all the recent hype about Sport
Pilot and LSA has been completely ignored by most "conventional" GA
pilots.
So, if you can't beat 'em, join 'em. For the sake of clarity, I now
just identify myself as, "Ultralight three delta kilo." Degrading, yes
- but at least now all the other miscreant pilots know who's talking.
(Sighhh ...)
Dennis Kirby
Mark-III, 912, and disgusted with a few ignorant GA pilots, in
Cedar Crest, NM
John Williamson
PostPosted: Thu Feb 15, 2007 3:01 pm    Post subject: Re: Ultralight Callsign Reply with quote
Hi Dennis and All,
When others don't know the rules/regs/recommended practices, (aka idiots), we can't stoop to their level.
Being a pilot is serious and requires us to maintain a professional/correct attitude and presence all the times. If you have to educate the unknowing, by all means do so.
If you operate by the rules nobody can fault you. The ATC folks of the FAA are the only FAA types that are really there "To help Us." Even some of them have to be brought up to speed on the correct phrasology at time.
John Williamson
Arlington, TX
jim
PostPosted: Thu Feb 15, 2007 3:29 pm    Post subject: Re: Ultralight Callsign Reply with quote
If you are N numbered I would not use the term "Ultralight". Ultralights are required to avoid N-numbered aircraft. If they think you're an Ultralight they might expect you to get out of their way. I would stick with "Experimental xyz" or Experimental Kolb xyz".
I think a glider pilot touched on this briefly, but if you are a special category (glider, amphib, float plane, etc.), that should also be included in your initial call. E.g., "Amphib experimental 33254".
Dennis.Kirby(at)kirtland. wrote:
"jim" wrote: <<
When calling tower or . . . For the sake of clarity, I now
Jim
N. Idaho
Richard Pike
PostPosted: Thu Feb 15, 2007 5:03 pm    Post subject: Ultralight Callsign Reply with quote
Don't give in. Years ago in my N-numbered Hummer, I was on short final for
VJI and some moron in a C182 looked right at me (eye contact) and pulled out
in front of me, (Part 103 ultralights have to yield to everybody, this was
an u/l unfriendly field, and he was making a point) forcing me to make a
stressful go around.
You better believe that I got on the frequency big time. Memory is not too
precise anymore, but it was to the effect of -
"Cessna departing Highlands, say your call sign"
"Highlands unicom, do you know the N-number of the Cessna 182 that taxied
out a minute ago? Because he just pulled out in right in front of
Experimental 02Papa when I was on short final, and I want to make a report
about a near mid-air to flight standards."
The silence was deafening - but I bet he didn't do it again.
On the other hand, if I had called myself an ultralight when I was on base
leg turning final, I wouldn't have had a leg to stand on. Moral vectories
are not anything like legal ones.
Richard Pike
Richard Pike
Kingsport, TN 3TN0
PostPosted: Thu Feb 15, 2007 5:16 pm    Post subject: Ultralight Callsign Reply with quote
on base
vectories
| Richard Pike
Richard:
It is still a matter of good sense and each pilot clearing each other.
A good pilot does not pull out in front of another "object" , UL, Exp,
GA, or whatever. It is a matter of common horse sense.
I'll yield to any other aircraft that wants to push his way in, same
as automobiles, and rude folks on the sidewalk.
Russ Kinne
PostPosted: Thu Feb 15, 2007 5:52 pm    Post subject: Ultralight Callsign Reply with quote
Right on, John.
When I'm flying and there's any kind of in-air conflict, my response
is "you win" and take immediate evasive action. We can work it out
later if we're both alive. Works for me.
on base
vectories
| Richard Pike
Richard:
PostPosted: Thu Feb 15, 2007 5:54 pm    Post subject: Ultralight Callsign Reply with quote
Richard,
My interpretation has been that all of these rules between aircraft and
ultralight vehicles apply while both are in the air. If I am in the pattern
and some one calls in with intent to land, I go spend a few minutes out of
the way. But if I am on final and some one starts to taxi out, I do not
break off. If they don't or appear not to see me, I go around. Most get
stopped just at the edge of the runway. I land just beyond them and turn
off and taxi by them on the grass so that I don't hold them up by landing at
mid field and wait at a turn around.
Jack B. Hart FF004
Winchester, IN
Page 2 of 3
