Tow Bars
jeff(at)rmmm.net
PostPosted: Mon Feb 12, 2007 11:15 am    Post subject: Tow Bars Reply with quote
Hi All,
I have been thinking of ways to manufacture a tow bar for my tri-gear.
I am trying to avoid the lock on type that would produce a hole in the
wheel fairing. I've been thinking of the lift type used on tail wheels.
Interested in hearing what other tri-gears have used other than pulling
on the prop base. Any Ideas would be greatly appreciated.
Jeff Roberts
N128LJ Gold Rush. 70 hours & looking forward to warmer days.
steven.pitt2(at)ntlworld.
PostPosted: Tue Feb 13, 2007 9:04 am    Post subject: Tow Bars Reply with quote
Jeff
I would be interested in your deliberations. The course that I am thinking of pursuing involves the front axle bolt with shims to allow for a hooked tow bar. Andy Draper helped draw up a set of ''washers'' to act as the shims but I have not constructed them yet. My system would mean that the axle bolt would protrude through the nose fairing - but as I have not fitted it yet it is not currently an issue.
Steve Pitt G-SMDH
Will be at Sun'n'Fun all week. See you there.
s.vestuti(at)virgin.net
PostPosted: Wed Feb 14, 2007 12:03 pm    Post subject: Tow Bars Reply with quote
hi, istead of a standard "bolt" ,what about a hardened steel rod threaded at both ends which would finish flush with the outside of the spat, it would be HOLLOW at both ends to a depth of about 3/4" to accept the fork,
im sure if enogh builders ordered one it would be worth while constructing,
steve vestuti #573
Visit - www.EuropaOwners.org
PostPosted: Wed Feb 14, 2007 12:44 pm    Post subject: Tow Bars Reply with quote
Sounds good - I am not enough of an engineer to create these things but
having read that one should not move an aircraft by its propeller once you
have a VP or C/S unit I wonder how others are coping.
Keep me posted.
Steve Pitt G-SMDH
jeff(at)rmmm.net
PostPosted: Wed Feb 14, 2007 3:20 pm    Post subject: Tow Bars Reply with quote
Steve,
I would may be a taker on that if it comes up.
Jeff
N128LJ
accept the fork,
constructing,
steve vestuti #573
Jeff Roberts
RMMM
Roberts Marketing & Media Management
615-355-7575 Office
615-406-8651 Cell
alan(at)kestrel-insurance
PostPosted: Wed Feb 14, 2007 7:19 pm    Post subject: Tow Bars Reply with quote
Hi Steve
I would be in the market for one of these also.
Alan
PostPosted: Thu Feb 15, 2007 11:40 am    Post subject: Tow Bars Reply with quote
OK, i will ring the PFA here in the UK to get their verbal opinion B4 i go any further,
steve #573
