Guy Buchanan
Posted: Thu Feb 08, 2007 11:04 am Post subject: Rotax 582 Start Current |
The short question is: What is the approximate start current for a Rotax 582?
Why do I ask? Because today I fried the shunt on my 30A ammeter. This
shunt operates in line between the battery and starter.
I've noticed lately that starting has been slower and I attributed it
to lower battery capacity. Today I checked the voltage at 13.1V, then
tried starting. I got three very slow turn-overs followed by a click,
then nothing. It turns out the click was the shunt separating. I've
got probably 100 starts on this system over the last year. I did a
resistance check of the starter across the "big" wires and got only
0.3 ohms. Is it possible the starter is shorted? How can I tell if
the starter is bad? Do I dare simply attach the battery to the
starter directly to see if it works? I could also simply by-pass the
shunt to see if it works, then I could use the start switch. I'm
concerned, however, that if the starter is shorted I could blow the
battery. Is that a possibility?
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
NYTerminat(at)aol.com Guest
Posted: Thu Feb 08, 2007 1:04 pm Post subject: Rotax 582 Start Current |
Guy,
The wire to the starter motor should not go through the shunt, the load for everything else goes through the shunt.( ignition,lights,radios,flap motors,trim motors, etc.)
I am surprised that you were able to get any starts at all without blowing the shunt. If you want more info on wiring, go to the aeroelectric.com website.
Bob Spudis
N701ZX/CH-701/912uls
In a message dated 2/8/2007 2:06:19 P.M. Eastern Standard Time, bnn(at)nethere.com writes:
| Quote: | --> RotaxEngines-List message posted by: Guy Buchanan <bnn(at)nethere.com>
Guy Buchanan
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. = Use lities Day --> - NEW MATRONICS WEB FORUMS -
bsp; --> ======================
