BertBerry1(at)aol.com Guest
Posted: Sat Feb 03, 2007 8:51 am Post subject: Falcon Field Airport Mesa, Arizona |
Would anyone here happen to know anything about a Aero Commander that was abandoned at the Falcon Field Airport
Mesa, Arizona before being parted out?
I understand that before someone took it apart, a group of unknowns tied a rope to her and tried to make a glider out of the fuselage after the engines were taken out. Apparently it didn't go very well because it crashed into another aircraft on the field.
I was just wondering if anyone knew which aircraft it was.
Bert
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
cvcantwell(at)charter.net Guest
Posted: Sat Feb 03, 2007 6:00 pm Post subject: Falcon Field Airport Mesa, Arizona |
Bert: I salvaged N265X, a 680 that had been at Chander Field. Someone had taken a piece of hawser and tied it around the vertical fin and rudder and drug it around a bit. There was some wing tip and leading edge damage from hitting the tail of one of the Harpoons tied down close by. I had planned to rebuild her, but found so much corrosion and skin damage in the belly, that it wasn’t practical to even attempt it. We cut the fuselage right behind the contol columns, just in front of the wing and just aft of the wing. I brought home basically everything forward of the columns, the entire wing assembly and all of the control surfaces. I would like to sell the entire lot of parts as it looks like I will loosing my job and all probablity of owning a flyable Commander. I don’t have any pictures available right now, but can get some for anyone that is interested.
Craig [quote][b]
tylor.hall(at)sbcglobal.n Guest
Posted: Sat Feb 03, 2007 6:54 pm Post subject: Falcon Field Airport Mesa, Arizona |
Craig,Thank you for trying to save one.Do you have the engines and props?
Tylor Hall
On Feb 3, 2007, at 6:59 PM, cvcantwell(at)charter.net (cvcantwell(at)charter.net) wrote:
| Quote: | Bert: I salvaged N265X, a 680 that had been at Chander Field. Someone had taken a piece of hawser and tied it around the vertical fin and rudder and drug it around a bit. There was some wing tip and leading edge damage from hitting the tail of one of the Harpoons tied down close by. I had planned to rebuild her, but found so much corrosion and skin damage in the belly, that it wasn’t practical to even attempt it. We cut the fuselage right behind the contol columns, just in front of the wing and just aft of the wing. I brought home basically everything forward of the columns, the entire wing assembly and all of the control surfaces. I would like to sell the entire lot of parts as it looks like I will loosing my job and all probablity of owning a flyable Commander. I don’t have any pictures available right now, but can get some for anyone that is interested.
Craig | Quote: |
href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
Posted: Sun Feb 04, 2007 9:24 am Post subject: Falcon Field Airport Mesa, Arizona |
Tylor: Unfortunately the engines, props and all the radios and instruments were long gone before I bought her. I do have some GSO-480 parts that go with the stack...a supposed good case, oil sump, accessory case and a bunch of internal parts.
Someone offline asked me about the areas to be reskinned...basically everything from the nose gear doors to the taillight, from floor to floor and three of the tailcone skins...I could have done it, but would have put several thousand manhours into doing and it just wasn’t worth it.
Craig [quote][b]
BillLeff1(at)aol.com Guest
Posted: Sun Feb 04, 2007 8:59 pm Post subject: Falcon Field Airport Mesa, Arizona |
I have two props and one engine core for a 680E
Bill Leff
937-369-3334
Posted: Sun Feb 04, 2007 9:24 pm Post subject: Falcon Field Airport Mesa, Arizona |
Bill,Thanks for the information.
Now I need to find a 680E that is for sale.
I missed the one I was looking at.
Do you know of any?
Tylor Hall
On Feb 4, 2007, at 9:55 PM, BillLeff1(at)aol.com (BillLeff1(at)aol.com) wrote:
[quote] I have two props and one engine core for a 680E
Bill Leff
937-369-3334
| [b]
fritsabbing(at)yahoo.com Guest
Posted: Mon Feb 05, 2007 2:24 am Post subject: Falcon Field Airport Mesa, Arizona |
Hello Tylor,
You are looking for a 680E.
I thought you had one before?
I have one for sale N71DF not in annual present time
price around US$ 95.000
If interested, I like to hear.
regards,
Frits Abbing
--- Tylor Hall <tylor.hall(at)sbcglobal.net> wrote:
| Quote: | Bill,
Do you know of any?
Tylor Hall
> Bill Leff
> 937-369-3334
Never Miss an Email
Stay connected with Yahoo! Mail on your mobile. Get started!
http://mobile.yahoo.com/services?promote=mail
WINGFLYER1(at)aol.com Guest
Posted: Mon Feb 05, 2007 12:45 pm Post subject: Falcon Field Airport Mesa, Arizona |
I have a great 680 but may be interested in some parts and maybe all of what you have. How much for all of the 680? Gil
RnJThompson(at)aol.com Guest
Posted: Mon Feb 05, 2007 3:40 pm Post subject: Falcon Field Airport Mesa, Arizona |
I have a 0 time prop for a 680/680E plus complete hub assy, everything except blades as spares. Changed my 680E to Queen Air props. So anyone out there with the originals fitted can have them for a small fee.
Cheers
Richard
Posted: Mon Feb 05, 2007 8:18 pm Post subject: Falcon Field Airport Mesa, Arizona |
Fitz, give me a call, I have a customer for a 680E
Bill Leff
937-369-3334
