Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Fri Feb 02, 2007 5:08 am Post subject: Re: Mk 3 steel main gear legs |
Posted: Thu Feb 01, 2007 7:59 pm Post subject: Mk 3 steel main gear legs
Rex,
I have always used aluminum gear legs. I have bent one set in about 500
hours. Those were bent about 30 seconds after a rod bearing failed in a
582. I was over Tellico lake when the engine failed and used up all of my
excess air speed to clear a line of trees that was between me and the field
I was going to land in. After clearing the trees I was about 3 knots above
stall speed.....not enough to flare for a good landing.
Steven Green
Thanks Steve,
I'm getting old and confused. I believe that TNK supplied some steel legs for the Mark III a few years ago that were very soft and springy as compaired to the new ones; and for some reason I thought you had them.............I may be wrong about the legs also. Anyone know for sure?
Rex
Richard Pike
Posted: Fri Feb 02, 2007 6:17 am Post subject: Re: Mk 3 steel main gear legs |
They did sell springy ones. I have a set that I am saving for the time when I trash my aluminum gear legs.
Here is what they look like:
Richard Pike
MKIII N420P (420ldPoops)
96.75 KB |
465 Time(s) |
Posted: Fri Feb 02, 2007 7:43 am Post subject: Mk 3 steel main gear legs |
Rex & Richard
I have a set of those gear legs installed in my VW powered MKIIIc. They are
indeed springy. When you land hard with a bit too much airspeed you will
find yourself 10ft in the air with very little airspeed. A blast of power
fixes the next landing. These gear have I would guess the third most air
miles as any Kolb. I bought them from ??? in Hawaii. He sold them because
they were too springy. Personally I think they are just right. When everyone
at Oshkosh is grumbling about how rough the ground is I just say "is it? I
can't really tell".
There are two things I would recommend doing to the gear before installing
them. These are the same gear that the Old Kolb sold but they welded a steel
tube 6 to 8 inches long on the end to carry the bending load further up into
the landing gear sockets. I would weld that same tube on. The next thing
would be to bend the gear down a bit to make the wheels run more vertical
(is that camber?). They squat a bit when the plane is loaded.
Rick Neilsen
Redrive VW powered MKIIIc
Richard Pike
Posted: Fri Feb 02, 2007 7:49 am Post subject: Mk 3 steel main gear legs |
Thanks, appreciate it.
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
jindoguy(at)gmail.com Guest
Posted: Fri Feb 02, 2007 4:38 pm Post subject: Mk 3 steel main gear legs |
Colder than a well digger's knee caps here, I woosed out last night, but got a picture today. Still in TNK tape and factory insert up to here lines.
Rick
On 2/1/07, Denny Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)> wrote:[quote] Are "these"
68.11 KB |
427 Time(s) |
rowedenny(at)windstream.n Guest
Posted: Fri Feb 02, 2007 7:08 pm Post subject: Mk 3 steel main gear legs |
Are these set up for Matco brakes?
Denny Rowe
Posted: Fri Feb 02, 2007 8:05 pm Post subject: Mk 3 steel main gear legs |
Had to dig out my receipt to get the answer to this one. Yes, I really don't like Azusa brakes, although that's what's on my plane now.
Rick
On 2/2/07, Denny Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)> wrote:[quote] Are these set up for Matco brakes?
Denny Rowe
Posted: Sat Feb 03, 2007 6:27 am Post subject: Mk 3 steel main gear legs |
Richard,
E-mail me off list so I have your address and phone #, I am leaning toward buying your gear legs for spares but have to talk it over with my partner Jay first.
Denny
