Dodgy Tacho?
MJKTuck(at)cs.com
PostPosted: Thu Feb 01, 2007 7:50 pm    Post subject: Dodgy Tacho? Reply with quote
Hi Folks,
I have noticed on some flights (but not all) that I can be happily flying along at 5,000 rpm when the UMA analogue tacho pointer catches my eye as it drops to maybe 3,000 rpm., hovers for a bit, moves around a bit, then resumes back where it should be. Of course the engine carries on working just fine while all this is going on. I was planning on installing a UMA LED digital tacho thinking it maybe the instrument. It could I suppose be the sensor at the engine end.
Any thoughts on what it might be - and anyone had any experience with the UMA LED 2 1/4 in. digital tacho? Any other recommendations out there - needs to be 2 1/4 inch dia. instrument though.
Martin Tuck
N152MT
Wichita, Kansas [quote][b]
