FloScan Sensors
rlborger(at)mac.com
PostPosted: Wed Jan 31, 2007 9:09 am    Post subject: FloScan Sensors Reply with quote
Europaphiles:
On the FloScan website:
http://www.floscan.com/html/blue/index.php
Is a link to their Aviation usage page:
http://www.floscan.com/html/blue/aviation.php
Where the FloScan 200 series is advertises for aviation use.
Lots of good information on their web site about installation, etc.
Good building and great flying,
Bob Borger
johnwigney(at)alltel.net
PostPosted: Thu Feb 01, 2007 9:40 am    Post subject: Floscan sensors Reply with quote
Dear Europaphiles,
For interest, the fuel flow option on the Grand Rapids EIS #2004 <
http://www.grtavionics.com/model_2004.htm > uses a Floscan 201B sensor.
I have found it to be very accurate - usually within 0.1 gal on the
totaliser when I fill the tank. However, it is important to provide a
straight length of hose before the sensor to eliminate turbulence. I
also found that a damper is essential to smooth out flow/pressure pulses
from the fuel pump. Matt Dralle at Matronics sells a very nice item, see
< http://www.matronics.com/fuelchec/dampener.html > . I made my damper
for almost nothing using a tee and a length of fuel hose in a u-tube
arrangement which traps air below a plugged end fitting.
Cheers, John
