michael(at)flightsked.com Guest
Posted: Thu Jan 25, 2007 12:47 pm Post subject: eyebrow |
Just recently finished the annual on my Tiger, and one of the scheduled items we accomplished at the same time was installing the AuCountry eyebrow I bought (at a really good price) at the AYA scholarship auction. The bottom line is that it is *so much better* than the old plastic that it replaces.
A few observations that you might find interesting…
<![if !supportLists]>- <![endif]>The new eyebrow sits at a slightly higher angle than the old one, which means that you have a little better visibility of the upper portion of the panel. For me, it’s angled pretty much perfectly, meaning that I only see the edge of the eyebrow when I glance down at the panel.
<![if !supportLists]>- <![endif]>The new brow seems to be at least as effective at blocking panel light from reflecting off the windscreen as the old one was. I’ve flown it through the first hour or so of darkness over San Diego, so it’s not quite as telling a test as flying in the middle of the night over the desert, but as I say, it seems to be fine.
<![if !supportLists]>- <![endif]>It looks a lot better than the old one. The lines are much cleaner, and the way that it curves down and back to the panel is more elegant than the way the old eyebrow tried to meet up with those two black plastic pieces on the cabin side. It’s covered with a good quality, matte-black, textured faux leather, and being a single piece of fiberglass (as opposed to the original’s two pieces of plastic screwed together) I think it will hold up better over time.
Lighting – deserves its own section.
When I read Gary’s description of how long it would take to install the new eyebrow, I figured I must be missing something. I was, and it’s the amount of work involved in mounting light fixtures to the underside of the eyebrow, wiring them in, and tapping in to the panel light circuit. The static line also needs to be relocated.
I suppose you could hack something together in less time, but what we did relocated the switch to eliminate the plastic side panel, spliced into the power supplied to the lighting bus off the dimmer, and laid everything out with the proper connectors and service loops in the wiring so you can conveniently remove and replace the eyebrow if/when you need to. A lot of this is done upside down and backwards, with your head gently cradled by the rudder pedals, so yeah, it takes some time.
The new eyebrow is capable of casting a lot more light on the panel than the old one, so Gary recommends placing it on a separate dimmer. I would agree – it overpowers the NuLites I have installed.
So, overall I’m very happy with the new eyebrow and if you’re thinking of cleaning up your panel, renewing your interior, etc it’s definitely worth doing. There’s more info available at http://www.aucountry.com/index_TG.html
Thanks to Gary and AuCountry for supporting the AYA by donating the eyebrow for auction, and thanks (for nothing) to Matt D who bid up the price just because he couldn’t bear seeing me get off too cheap
YMMV, no vested interest, just a satisfied customer.
Michael
Michael W. Meyer
Tiger N74086
Montgomery Field (KMYF)
San Diego, CA
| - The Matronics TeamGrumman-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
mattd(at)drahz.com Guest
aa1bflyboy(at)msn.com Guest
Posted: Thu Jan 25, 2007 2:06 pm Post subject: eyebrow |
What auction I must have missed that one. I'd have bid too. But then that
would have made Draz bid even more...
If I'm right I have no need to be angry;
If I'm wrong I have no right to be...
Steve Roberts - AA-1B N9664L (at) ILG
----Original Message Follows----
Reply-To: teamgrumman-list(at)matronics.com
Subject: Re: eyebrow
Date: Thu, 25 Jan 2007 16:44:14 -0500
Michael W. Meyer wrote:
Quote: |
J <http://www.aucountry.com/index_TG.html>
because he couldn't bear seeing me get off too cheap
but Michael - /It was for the* Children.*...Don't you care about the
*Children*/*/?
/*(it is my new technique to excuse anything - my former technique was to
immediately (and prematurely) invoke the Godwin principle by saying
something like:
/Yeah, well the *first* thing that the Germans did was confiscate
everybody's guns fairly priced airplane eyebrows/....)
mattd
p.s. Is it Friday yet?
Posted: Thu Jan 25, 2007 2:14 pm Post subject: eyebrow |
Ah OK that auction... Had to be there I guess... or read all of the original
email... Guess I gotta break down and buy me one of them sometime. 1st will
be the O320 though.
*Children*/*/?
something like:
mattd
GrummanDude
Posted: Fri Jan 26, 2007 12:08 am Post subject: eyebrow |
I installed one of my eyebrows in Bill Kelly's AA1C. It needs to be
trimmed to fit the location of the static line. Unlike the 4 place
Grumman, the static line isn't so easy to move in a 2 place Grumman.
Gary
PS, I think Mike was a bit amazed that it took all day to install the
eybrow. Lots of tedious this-n-that. I took a lot of pics and I'll be
adding them to my web site. I didn't . . . . . however, get a picture
of the final installation.
PPS, we also installed some drilled yokes (yolks, if you went to school
in California) in Mike's Plane. Got rid of a lot of wiring. Next, the
ADF is coming out. Then the back seat . . . .
_________________ Gary
AuCountry Aviation
Home of Team Grumman |
btemplin(at)templinelectr Guest
GrummanDude
Posted: Sat Jan 27, 2007 8:07 pm Post subject: eyebrow |
They run $300 without lights and $475 with lights and wiriing set up to
plug and play. By-the-way, it still takes 4 to 6 hours to install WITH
a pre-wired eyebrow.
AuCountry Aviation
