		johnwigney(at)alltel.net Guest
				 Posted: Thu Feb 02, 2006 10:25 am    Post subject: Manifold pressure gauge |
				Dear Rotax enthusiasts,
 I have a 912S and Whirlwind hydraulic constant speed prop on my Europa
 XS and the combination works very well. My panel builder installed a
 manifold pressure gauge as requested but I have a problem. The gauge is
 a simple differential pressure gauge which measures the difference
 between ambient and the manifold pressure. It is calibrated such that
 when the engine is at rest or at full throttle (i.e. zero differential)
 the reading shows 29.9" Hg. This reading is the same at all altitudes so
 that at full throttle at 10,000 ft, the gauge still reads 29.9" Hg. When
 I close the throttle at any altitude, the gauge indicates reduced
 manifold pressure proportional to the throttle opening.
 I would like to change this to a gauge which indicates reduced full
 throttle manifold pressure with altitude. Looking through the catalogs,
 there are many 2 1/4" MP gauges available, some are identified as
 'altitude compensated'.  I am unsure if these are different to my
 existing gauge. My question is this:-
 Can anybody recommend and inexpensive 2 1/4" MP gauge (Supplier and
 Model no.) which will meet my needs?
 Thanks, John
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Thom Riddle
				 Posted: Fri Feb 03, 2006 5:22 am    Post subject: Manifold pressure gauge |
				John,
 It sounds to me like your Manifold Pressure gauge just needs to be
 hooked up correctly. It should connect to the intake manifold
 downstream from the carburetor and should NOT be comparing anything to
 anything else. It is an absolute pressure gauge. When the engine is not
 running it should read atmospheric pressure, 29.92" or whatever AWOS
 says is the current barometric pressure. When running it will read much
 lower. At idle it will be very low and at full power it should be up
 aroun 27-28" at low altitudes and decrease as you climb higher.
 Thom in Buffalo
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
