Daniel.Snow(at)wancdf.com Guest
Posted: Thu Jan 25, 2007 10:44 am Post subject: Fix For Superior XP O-320 Engine - Carb Interference With Lo |
I was able to get Superior on the phone this morning and confirm that
there is indeed an interference problem between the MA-4-5 carburetor
and Van's cowls. They're accepting full responsibility and will be
shipping me a new Precision carb that is 1-1/2" shorter than the MA-4-5.
That should make the first engine run a little more interesting.
Daniel Snow
ssamps(at)gmail.com Guest
Posted: Thu Jan 25, 2007 11:47 pm Post subject: Fix For Superior XP O-320 Engine - Carb Interference With Lo |
Daniel - now I am confused! From what you say you are building an RV9A with an O-320 and the Marvel is the standard unit as VANS would ship only you got it from Superior. So why does that not work since it does work for VANS? I thought I had understood this!
Thanks, Steve.
On 25/01/07, Snow, Daniel A. <Daniel.Snow(at)wancdf.com (Daniel.Snow(at)wancdf.com)> wrote: [quote]--> RV-List message posted by: "Snow, Daniel A." < Daniel.Snow(at)wancdf.com (Daniel.Snow(at)wancdf.com)>
Daniel Snow
Posted: Fri Jan 26, 2007 5:09 am Post subject: Fix For Superior XP O-320 Engine - Carb Interference With Lo |
I think I saw yesterday that Precision Airmotive used to be Marvel. It
looks like Superior originally supplied me with a Precision MA-4-5 and
are going to replace it with a Precision MA-4-SPA which is 1-1/2"
shorter. I don't know the model carb that you would normally get from
Vans.
Daniel
Time: 11:47:39 PM PST US
Subject: Re: Fix For Superior XP O-320 Engine - Carb
Interference With
Lower Cowl
with
got
I
Thanks, Steve.
klwerner(at)comcast.net Guest
Posted: Fri Jan 26, 2007 9:34 am Post subject: Fix For Superior XP O-320 Engine - Carb Interference With Lo |
Daniel,
I may be incorrect, but I thought the MA-4-5 (deeper) is for O-360 engines, whereas the MA-4 (shallower) is for the O-320 engines? That's why Vans makes different depth cowlings (320 vs. 360), but that also makes and engine swap to 180hp difficult if you were to have started with the cowling for the O-320. If it were me I'd use the bigger cowling from the getgo regardless of engine choosen. Like I said, I may be totally off the deep end here, so please do not archive.
Vans.
Daniel
Posted: Sun Jan 28, 2007 10:02 am Post subject: Fix For Superior XP O-320 Engine - Carb Interference With Lo |
Daniel - I have a new Aerosport power XP O-320 and looged at the carb. Yes, it is the MA4SPA that you mentioned. I think that is the normal one yo uwill be pleased to know. Cheers, Steve.
On 26/01/07, Konrad L. Werner <klwerner(at)comcast.net (klwerner(at)comcast.net)> wrote: [quote] Daniel,
Vans.
Daniel
