instructions mono trailer
josok-e(at)ukolo.fi
PostPosted: Sun Jan 21, 2007 9:07 am    Post subject: instructions mono trailer Reply with quote
Hi all.
Bought my mono trailer second hand. Now i would like to know how the fuse is supposed to stay upright. Maybe i figured it out, but i might be wrong. Are there instructions out there somewhere?
Kind regards,
Jos Okhuijsen
Visit - www.EuropaOwners.org
scrimm
PostPosted: Sun Jan 21, 2007 9:58 am    Post subject: instructions mono trailer Reply with quote
Jos,
I haven't seen any directions before, and would love to find some.
With that said. The ramp for the monowheel when in the up/retracted
position goes over the outside of the landing gear frame assembly and holds
the airframe upright. What you should be aware of is depending on how you
secure the ramp in the up position can vary the angle in which the airframe
is positioned. I use chain the secure the ramp in the upright position and
turn buckles to tighten up the chain. If I don't make sure I tighten the
turnbuckles equally I will get the fuselage setting on the trailer at an
angle. Depending on the degree of angle, when traveling down the road, the
rocking of the airframe may cause it to come in contact with the rear wing
support. This in turn can cause damage to the airframe.
Because it takes 2 people as a general rule (unless you have a trailer
winch) to push the aircraft onto the trailer, I made a ramp that lessens the
angle of the ramp that is on the trailer. It is a wooden ramp that they
trailer ramp rest on to lengthen the ramp and lessen the angle. With this
done I can push the aircraft on the trailer by myself with my wife only
having to hold the wings level.
Steve
N42AH
Flying and For Sale
Steve Crimm
N42AH
carl(at)flyers.freeserve.
PostPosted: Sun Jan 21, 2007 10:25 am    Post subject: instructions mono trailer Reply with quote
A further complication with the tailer is that the mono tyre is narrower
than the channel it sits in. If the tyre isnt centred in the channel, the
fuselage will still lean to one side when trailering. This cant be corrected
by adjusting the turnbuckles of the ramp support bars.
Easiest solution is to bond plywood strips to the sides of the wheel channel
(only at the bottom where the wheel sits) so that the tyre is a snug fit and
centred in the channel.
Also if the ramp is taken up too far or/ and the tyre is under inflated, the
top of the ramp floor (in the raised position) will rub against the upper
portion of the swinging arm causing wear and possible weakening of the
undercarriage. A strip of tufnol or rubber should reduce the possibility of
this happening.
CP
G-LABS
96victor(at)gmail.com
PostPosted: Sun Jan 21, 2007 10:28 am    Post subject: instructions mono trailer Reply with quote
Hi Jos
Mine came from the factory sans instructions. I have increased the diameter of the wheel so the ramp would not go up enough to put the aircraft on. If you have a larger wheel than that originally supplied, email me off board and I will tell you my solution.
Tom Friedland N96V
On 1/21/07, josok <josok-e(at)ukolo.fi (josok-e(at)ukolo.fi)> wrote: [quote]--> Europa-List message posted by: "josok" <josok-e(at)ukolo.fi (josok-e(at)ukolo.fi)>
Hi all.
ami(at)mcfadyean.freeserv
PostPosted: Sun Jan 21, 2007 1:40 pm    Post subject: instructions mono trailer Reply with quote
<<.... if the ramp is taken up too far ... the
portion of the swinging arm .... >>
I thought it had been 'designed' that way, as one means of stopping the
fuss. from falling over. But agree that it may damage the swing arm, or
LG01.
Duncan McF.
PostPosted: Sun Jan 21, 2007 1:41 pm    Post subject: instructions mono trailer Reply with quote
fus. from falling over. But agree that it may damage the swing arm, or
LG01.
Duncan McF.
PostPosted: Sun Jan 21, 2007 1:42 pm    Post subject: instructions mono trailer Reply with quote
LG01.
Duncan McF.
scrimm
PostPosted: Sun Jan 21, 2007 2:00 pm    Post subject: instructions mono trailer Reply with quote
I may be confused, which is most of the time, but the only way I can keep the airframe secure in the vertical position is with the ramp in the up position sliding over the swing arm. I have a fat wheel that is a nice fit in the bottom section but that alone would never hold the airframe vertical.
Steve Crimm
N42AH
josok-e(at)ukolo.fi
PostPosted: Sun Jan 21, 2007 2:20 pm    Post subject: instructions mono trailer Reply with quote
Happy that i am not the only one confused. I've seen monowheels with scratches on the top side of the swing arm, and thought it to be caused by the ramp, locked up position. On the trailer i have, the ramp does not reach high enough to grab the swing arm, not with with the original adjustment. I have not raised the tailwheel yet, maybe that just makes the ramp grab. But clamping the the tyre alone does not hold the fuse vertical, not when forces are exited anyhow. Who resolves the puzzle?
Kind regards,
Jos Okhuijsen
NevEyre(at)aol.com
PostPosted: Sun Jan 21, 2007 2:43 pm    Post subject: instructions mono trailer Reply with quote
Hi Jos,
Do you have the engine installed yet?
With the weight of the engine, the suspension is compressed, and the swinging arm will be captured by the ramp.
The rod ends on the ramp tie rods can be adjusted to raise or lower the height of the ramp, to suit.
Tufnel shims on the inside of the ramp will prevent marking the swinging arm [ don't paint the arm].
Tufnel or plywood blocks on the bottom of the ramp, will keep the tyre in the centre.
Cheers,
Nev.
grahamsingleton(at)btinte
PostPosted: Sun Jan 21, 2007 4:18 pm    Post subject: instructions mono trailer Reply with quote
Jos
the gear leg is supposed to sit in the channel section that holds the
wheel on the trailer. Trouble is it tends to bounce and when it does it
will hit the wings. I always use a luggage strap over the fuselage just
in front of the screen. That holds it firmly in the channel
Graham
Steve
N42AH
Flying and For Sale
josok-e(at)ukolo.fi
PostPosted: Sun Jan 21, 2007 4:19 pm    Post subject: instructions mono trailer Reply with quote
Thanks Nev,
Yes, the engine is on, and i expected things to happen as you describe, but it did not. The plane which used this trailer before must have been quite a bit heavier. Will adjust the rod ends then.
Kind Regards,
Jos Okhuijsen
PostPosted: Wed Jan 24, 2007 7:13 am    Post subject: instructions mono trailer Reply with quote
LG01.
Duncan McF.
gavanne(at)iconz.co.nz
PostPosted: Wed Jan 24, 2007 1:05 pm    Post subject: instructions mono trailer Reply with quote
It’s a good idea to shape and bond a piece of neoprene rubber to the top of
the wing supports to fit snugly against the sides of the fuselage!!!! A
bit of old redux will do it
Gavin Lee.....#355
