gerf(at)gerf.com Guest
Posted: Mon Jan 22, 2007 6:46 pm Post subject: Fuel collecting in bottom of FAB |
I was busy climbing out of the pattern this morning when I began to smell fuel inside the cabin. First glitch that's caused me to do a 180 and get straight back on the ground, nervously fingering the fuel shut off.
Fuel is collecting in the bottom of the FAB (AFP fuel injection, vertical induction on an Aerosport IO-320). Talking to Don at AFP its normal to have a little fuel dribble back down the intake pipes as the injector lines get heated up after shutdown - only place for the fuel to go is the cylinder head and down the intake tubes.
Any of you guys out there running the AFP setup on an IO-320 ? Have you had similar experiences ? Did you fit a drain tube to the bottom of the FAB to dump the excess overboard ? I see some (Dan C) fitting a "sniffle valve" on the bottom of the IO-360, doesn't seem to be an option on the IO-320.
g
dbris200(at)sbcglobal.net Guest
Posted: Tue Jan 23, 2007 8:15 am Post subject: Fuel collecting in bottom of FAB |
So why did you smell fuel on climb out? I can't see why shutdown would
have anything to do with fumes in the cockpit when flying.
Dave
Gerry Filby wrote:
| Quote: | I was busy climbing out of the pattern this morning when I began to
shut off.
g
Posted: Tue Jan 23, 2007 8:48 am Post subject: Fuel collecting in bottom of FAB |
This is still an open question - my original supposition was that the fuel that was collecting after shutdown was leaking out of the drain hole in the bottom of the FAB and soaking into the bottom of the cowling. During climbout the exhausts would warm up the cowling and the fuel evaporates. Others have commented that this is not likely the source of the odor and have relayed experiences when the tanks are overfull and the sun warms them up - fuel gets into the vent line which can lead to odor in the cabin
Posted: Tue Jan 23, 2007 9:03 am Post subject: Fuel collecting in bottom of FAB |
I have seen minor weeps around the fuel selector valve. This causes a noticeable smell in the cockpit. The quantity of fuel is very small, not even a drop or two, but it does catch your attention.
Is there any chance that your cockpit fuel smell is caused by a leak inside the cockpit, rather than something in front of the firewall?
KB
> shut off.
Posted: Tue Jan 23, 2007 10:20 am Post subject: Fuel collecting in bottom of FAB |
Absolutely possible (although I have already searched around the fuel selector and high pressure pump). Since I've reached the 10 hour mark on the engine and airframe I'm going to take the opportunity this weekend to repeat my condition inspection and make sure that nothing has rattled loose.
g
[quote]--
jfogarty(at)tds.net Guest
Posted: Tue Jan 23, 2007 10:58 am Post subject: Fuel collecting in bottom of FAB |
Guys, what do we use to seal all the fittings in the RV from the pitot tube, fuel lines, brake line, etc? Thanks.
Jim Fogarty
Posted: Tue Jan 23, 2007 12:51 pm Post subject: Fuel collecting in bottom of FAB |
Also check the tanks themselves for seepage as that smell will get into
the cockpit too. Take a close look at the bottom of the wings towards
the root for blue stains.
Dave
has rattled loose.
g
panamared5(at)brier.net Guest
Posted: Wed Jan 24, 2007 5:03 am Post subject: Fuel collecting in bottom of FAB |
I sometimes have this problem of smelling fuel in the cockpit, but I
concluded it was from expansion of the fuel in the tanks and fuel being
forced out of the fuel vents. My theory is that at high AOA the fuel vapor
flows toward the cockpit air vents and there you have it.
I know during acro maneuvers I lose some fuel through the vents. I use
Lemon Pledge to clean my airframe and aviation fuel removes it. This gives
an interesting pattern on wing and fuselage.
Anyway just my theroy.
Bob
lhelming(at)sigecom.net Guest
Posted: Wed Jan 24, 2007 7:55 pm Post subject: Fuel collecting in bottom of FAB |
I smelled fuel in the cockpit when first getting into the plane. It turned
out to be a very slow leak at the wing root. It was too slow of a leak at
first to be seen on the hangar floor. I kept looking inside the fuselage
for the source but could not find it. I tightened the fitting in the wing
root which was wet to the touch and no more smells. Larry in Indiana
