Fred.Stucklen(at)UTCPower Guest
Posted: Mon Jan 22, 2007 7:48 am Post subject: Tank Vent problem |
Lister,
I'd like to share with you a tank vent problem I had last weekend (1/20/07). I flew a 30 minute IFR ride, in light/moderate snow, from 44N to 7B6, landed, taxied to the hanger and parked the plane. As I was leaving the hanger, I happened to note that the left main tank area of the wing was deformed with notable inward scalloping…. Opening the tip tank cap, and allowing in some air, allowed the deformation to be reduced. I capped the tank prior to all the air being replaced, and then inserted some safety wire into the tip tank vent. This resulted in a "whoosh" of air into the tank. The vent was noticeable blocked with ice/snow… The OAT at altitude was 11*F...
Fortunately, the main tank deformation was not serious, and removing the vacuum allowed the tank to return to its original shape.
The plane specifics are: RV-6A Tip-up with Jon Johansson tip tanks. The tip tank vent (located at the wing tip) is the ONLY vent for BOTH tanks on each wing. I have 3/8" tubing between the main and tip tank. The original Van's vent on the main tank has been capped.
This situation could have resulted in an in-flight engine failure. Fortunately, the right tank vent was clear (but it could just as easily have been blocked since it saw the same flying conditions). And, fortunately, it was a short trip…..
THIS IS A SINGLE POINT FAILURE ISSUE WAITING FOR AN ACCIDENT! Van's tank venting design is somewhat tolerant of in-flight blockage due to the fact they are located near the cowl warm air exits. But, even without the tips tank issue (with vents on the wing-tips) the same vent blockage problem could happen to a standard tank configuration.
In researching other certified IFR aircraft, I found that the tanks are usually vented in multiple ways. In addition to the main tank vents, Pipers and Cessna's have gas caps that will allow the air to go in, but will not allow gas to exit. A multiple point failure would have to happen to get a starved engine due to lack of tank venting.
I am going to try modifying my tank caps to have the same feature. I figure a #70 drill hole through the cap (both pieces) with a plastic "flapper" over the hole on the inside surface (glued in place with ProSeal) should do the trick (maybe even a larger hole)…..
Any comments?
Fred Stucklen
RV-6A N926RV 703 Hrs [quote][b]
ronlee(at)pcisys.net Guest
Posted: Mon Jan 22, 2007 8:36 am Post subject: Tank Vent problem |
| Quote: | | One nit. I would call the possible result "fuel starvation" rather than engine failure. |
Why did you cap the original tank vents?
Ron Lee
phil(at)petrasoft.net Guest
Posted: Mon Jan 22, 2007 9:44 am Post subject: Tank Vent problem |
Okay, I'll bite. The little plastic flapper with Pro-seal idea makes me
nervous. I can see a small piece of plastic winding up somewhere in the
fuel system. If proper precautions are taken it might work okay, but be
sure that the solution is not worse than the problem.
The holes in the caps are going to let water in too. You need to deal
with that somehow.
Godspeed,
Phil Birkelbach - Houston Texas
RV-7 N727WB
http://www.myrv7.com
Stucklen, Frederic W UTPWR wrote:
Lister,
Any comments?
*Fred Stucklen*
*RV-6A N926RV 703 Hrs*
sisson(at)consolidated.ne Guest
Posted: Mon Jan 22, 2007 11:47 am Post subject: Tank Vent problem |
Just keep in mind that tank vents should not inhibit the ex-hale requirements of the air volume in the tank. My vents are close to static (perpendicular to longitudinal axis), No real need to point them forward as they very often are because they need to breath out when climbing. (Pitt’s point them backwards to keep bugs and debris from entering the vent system). If tanks are, let’s say half full of fuel and you are climbing, there is a lot of air expansion taking place and the vents are exhaling a lot of air.
Just things to keep in mind. The tanks need to breathe in when coming down and they need to breathe out when climbing. The fuller the tank will mean less air has to escape but as fuel is used up the air volume
Increases and so the greater need for a good vent.
My situation is like most RV’s. Low wing, pumped fuel.
Gravity flow systems will need its own study.
Just my own ideas.
Phil in Illinois
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Stucklen, Frederic W UTPWR
Sent: Monday, January 22, 2007 9:47 AM
To: RV-List(at)matronics.com
Subject: Tank Vent problem
Lister,
Any comments?
Fred Stucklen
RV-6A N926RV 703 Hrs | Quote: | | http://www.matronics.com/Navigator?RV-List | 01234
rv9jim(at)juno.com Guest
Posted: Mon Jan 22, 2007 11:52 am Post subject: Tank Vent problem |
Fred,
I built an Europa several years back and we also had a vent that
could be blocked with a bug (or mud dobber or-)or--- So the company had
the vent line drilled in the rear of the fitting with a .070 drill. this
way if the main vent got plugged, the rear facing drilled hole would
allow the tank to work with out stopping fuel. We had a single tank
inside the fuselage and it was important to keep it functioning. I am
going to back drill the fittings on my "9-A" so that should not happen to
me.
Jim Nelson
RV9-A FWF
Posted: Tue Jan 23, 2007 5:00 am Post subject: Tank Vent problem |
Done properly, there is little chance that the plastic flapper idea
on the gas can would result in something else ending up in the
fuel system. Even if it did fall off, there is little chance that it would
make it past the strainers in both the tip tank pickup or the main tank
pickup. And the hole would be to small (and restricted by the flapper)
to allow water in.
An examination of the Piper gas caps, and their lack of problems
might make you feel better about this idea....
Fred Stucklen
with that somehow.
Godspeed,
RV-7 N727WB
Posted: Tue Jan 23, 2007 5:08 am Post subject: Tank Vent problem |
Good points.
Fred Stucklen
RV-6A N926RV 703 hrs
they very often are because they need to breath out when climbing. (Pitt's
If tanks are, let's say half full of fuel and you are climbing, there is a
My situation is like most RV's. Low wing, pumped fuel.
Just my own ideas.
Phil in Illinois
