bill(at)repucci.com Guest
Posted: Fri Jan 19, 2007 4:49 pm Post subject: No Title |
Larry,
Did you get my reply?
If not, here it is...
>Larry, (I can't reply to the list from this account, thus the private email.)
They are just braided stainless steel lines with the proper AN fitting (AN4). Nothing special, any speed shop should be able to create them.
I bought mine from http://www.bsrproducts.com/, which is a local company. Give them a call, 704-662-0901, tell them the size and length and they will have them out to you shortly. Ask them to pressure test the lines for you, that will save you a lot of time. The two longer lines you saw running down my gear legs and one 14" section for the peddles cost something like $57 +/-. (I reused one of the 12" lines on the other brake peddle and replaced the ones I made.) No more leaks of any kind.
BTW, Tad Sargent used the same time line inside his plane so he didn't have to bend anything.
Bill
-----Original Message-----
>From: Larry Rosen <LarryRosen(at)comcast.net (LarryRosen(at)comcast.net)>
>Sent: Jan 16, 2007 10:55 PM
>To: rv9-list(at)matronics.com (rv9-list(at)matronics.com)
>Subject: Re: RV9-List: Brake lines
>--> RV9-List message posted by: Larry Rosen <LarryRosen(at)comcast.net (LarryRosen(at)comcast.net)>
>Bill,
>Saw your photos here <http://www.repucci.com/bill/fuselage_pg3.html>.
>Do you have any specifics on the brake lines you used? Vendor,
>Manufacture, Model?
>Larry Rosen
>RV-10 N205EN (reserved)
>Bill Repucci wrote:
>> --> RV9-List message posted by: "Bill Repucci" <bill(at)repucci.com (bill(at)repucci.com)>
>> Good advice!
>> Realizing the brake lines on the -9A are different than on the -9 here
>> is my experience with the -9.
>> I did not like the idea of the loop around the brake so I elected to run
>> the hard line down the gear leg and transition to a 12" section of
>> stainless steel flex line. Look great, easy enough to do, etc. but...
>> The fairing would not fit over the union. So, off came those brake
>> lines and they were replaced with flex lines from the firewall down to
>> the brake. Much easier installation. I'll post pictures on my web site
>> in a few days. Busy with work right now.
>> Bill
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
