		paul.mcallister
  Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
				 Posted: Wed Feb 01, 2006 7:05 pm    Post subject: Mounting 914 waste gate servo |
				Freg,
 I mounted mine on top of the tunnel, but I manufactured up some aluminum
 spacers and used through bolts.  If I was to do this over again, I would
 consider mounting the servo and the voltage regulator next to each other on
 the fire wall. I would then make a fiberglass cover for them and connect a
 cold air blast tube to the cover.  It would make to servo far more
 serviceable and free up space inside your instrument panel.
 Paul
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Ivor Phillips
				 Posted: Fri Feb 03, 2006 5:17 am    Post subject: Mounting 914 waste gate servo |
				Ferg
 I used slightly longer AN 3 bolts so i could put the ancor nuts inside the
 tunnel, Where in my opion they should be!
  	  | Quote: | 	 		   to mount the subject item on the 'tunnel top' with MS21047-4 anchor nuts
  On
  top (Manual accent)
  of the tunnel. I can't see why, since the servo would then depend on four
  3/32 inch rivets through the 1/8inch composite.
 Ivor
