wnorth(at)sdccd.edu Guest
Posted: Mon Jan 15, 2007 12:09 pm Post subject: aerobatics |
Well,
It has already been said, but let's take it from another angle.
There are only three bad things that can happen doing aerobatics, generally.
1. you hit the ground.
2. you rip the wings off and then hit the ground.
3. you unload the wings by entering a spin, then hit the ground.
As you can see, there's a common denominator here. In spite of the many
great stories of self learners as far as I know an instructor is one of the
best ways to learn how to avoid the above without killing yourself.
Disorientation and not following the plan is what causes the first. And
blowing a manuver is what causes the second and third. So I would recommend
you use an instructor to learn how to plan, how to reduce disorientation,
how to avoid the second and how avoid and recover from the third while being
totally disoriented and at any attitude.
Then learn how to do a roll.
I would also suggest you do this in a plane that has been fully vetted for
the intended manuvers.
As well you can probably see that the above applies to any form of flying so
this instruction is not just for the joy of doing aerobatics, it will make
you a safer pilot.
And finally, Duane Cole's book "Roll around a point" was a good read but I
must qualify that it was not the end all of teaching one on how to do a
roll.
W
shempdowling2(at)earthlin Guest
Posted: Mon Jan 15, 2007 4:57 pm Post subject: aerobatics |
I forgot if Vans put it in the plans or if I saw it in the rvator but
he explains how to do simple aerobatics in your rv.
Shemp
Wheeler North wrote:
Well,
you a safer pilot.
roll.
W
Posted: Mon Jan 15, 2007 5:23 pm Post subject: aerobatics |
In the builder's manual, allowed maneuvers, entry speeds, etc. are listed.
In an RVator 2-3 years ago, he went into the subject of self taught
aerobatics. The gist of the article was "It isn't recommended, but since
you're gonna do it anyway, here's some advice to reduce your chances of
getting killed."
KB
