n801bh(at)netzero.com Guest
Posted: Sat Jan 13, 2007 10:11 am Post subject: Cracked canopy |
On a flight around the patch with a hangar mate in his RV-6 yesterday the canopy cracked while we were taxing out. Taxiway was a little rough for built up ice and the temp was -2f. About halfway to the active we heard a pop and noticed the rear portion of the canopy had a 3 inch crack going bothways from the center stiffener, this was 5" or so rearward of the place where the top mates with the front windshield. He is getting stuff together to replace the thing but not looking forward to the VERY lengthy process. Since he doesn't like puters I have two questions for you guys that I will relay back to him.
Is there any product that can be squirted, injected, packed or by whatever means,,, into the crack to glue it back together till he gets the repair done???
He tells me the canopy comes in a complete section, he fitted it so that it fit perfectly all the way around and then cut the in half at the like Vans calls for. Has anybody ever replaced just the back half by making a template of the bad section?? or will he need to go through the entire whole canopy thing??
thanks in advance,
Ben Haas
N801BH
www.haaspowera========================sp; - The = the many List utilities such as t================================================sp; - NEW p;content now also available via the Web&n=======================================
n616tb(at)btsapps.com Guest
Posted: Sat Jan 13, 2007 10:38 am Post subject: Cracked canopy |
A friend cracked his canopy up in the front windscreen area. He had a local plexi repair guy come out and do a repair. They inject something in there and buff it, etc. It looked pretty good except the area was such that it had a little blur in it. His was in a terrible spot for that but on top might be OK. I would certainly look into that before replacing the canopy… Yuck.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of n801bh(at)netzero.com
Sent: Saturday, January 13, 2007 12:09 PM
To: rv-list(at)matronics.com
Subject: RE: Cracked canopy
thanks in advance,
Ben Haas
N801BH
www.haaspowera========================sp; - The = the many List utilities such as t=======================sp; - NEW p;content now also available via the Web&n=======================================
| Quote: | | http://www.matronics.com/Navigator?RV-List | 01234
gert.v(at)sbcglobal.net Guest
Posted: Sat Jan 13, 2007 10:50 am Post subject: Cracked canopy |
U know, those may be questions best asked to folks like Todd's Canopees....
I believe Todd has supplied on request partial canopees when one end had
a defect after blowing.
n801bh(at)netzero.com wrote:
the repair done???
thanks in advance,
Ben Haas
N801BH
Pursuant to US Code, Title 47, Chapter 5, Subchapter II, '227,
any and all nonsolicited commercial E-mail sent to this address
is subject to a download and archival fee in the amount of $500
US. E-mailing denotes acceptance of these terms.
rv7(at)b4.ca Guest
Posted: Sat Jan 13, 2007 10:59 am Post subject: Cracked canopy |
On 10:09 2007-01-13 "n801bh(at)netzero.com" <n801bh(at)netzero.com> wrote:
| Quote: | Has anybody ever replaced just the back
through the entire whole canopy thing?? thanks in advance,
If he does end up needing (or just wanting) to replace the whole thing,
point him to the Matronics Wiki on glueing the canopy instead.
http://www.matronics.com/wiki/index.php/Gluing_Your_Canopy
Glueing will bond the canopy in place without placing any localized
stresses on the plexi like you will get with screws/rivets.
-Rob
N122RL(at)aol.com Guest
Posted: Sat Jan 13, 2007 11:07 am Post subject: Cracked canopy |
Had the same thing happen to my 6-A two years ago in the same place. I glued the crack back together with some glue I got from ca. I then put a 1 in. backup along the inside of the crack. Have been waiting for the right time to replace the canopy. I can check to see what the stuff is that I used if you like, It really works great.
Bob Lau 6-A 800 hrs.
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Sat Jan 13, 2007 11:32 am Post subject: Cracked canopy |
Here's an item from the RV list archives about repairing canopy cracks.
There are lots more in there, but this should get you started.
Terry
Match: #15 Message: #102802 Date: Dec 10, 2002 From: Jeff Point
<jpoint(at)mindspring.com> Subject: Re: Canopy crack
Chris,
I have a nearly identical crack in mine near the forward end of the
skirt (on a tip up though) which happened while drilling. I stop
drilled it, used Weldon 3 injected with a medical syringe (it is watery
thin) and let it cure. Then I filled the stop-drill hole with epoxy,
let that cure, and sanded it flush, then used Micro Mesh to fix the
plexi. Turned out, well, not perfect, but not too bad, and better than
a new canopy. A better solution (which I considered but abandoned) may
have been to find or make a plug of plexi for the hole and glue it in
with Weldon, then sand it flush.
I played around quite a bit with the Weldon and scrap plexi. Based on
my very un-scientific testing, it seems that the joint is about 50-75%
as strong as unbroken plexi, judging by the force required to re-break
the fused piece. Pretty amazing stuff. Never did try disolving plexi
shavings though. Certainly I have plenty of them after cutting and
drilling the canopy. I have 99.5% of the one quart can left, and you're
welcome to it if you don't feel like waiting for AC$.
Jeff Point
Posted: Sat Jan 13, 2007 11:35 am Post subject: Cracked canopy |
n801bh(at)netzero.com (n801bh(at)netzero.com) wrote:
Is there any product that can be squirted, injected, packed or by whatever means,,, into the crack to glue it back together till he gets the repair done??? | Go to a sign shop and buy a can of glue for acrylic. It's like water, and you will have good luck using a diabetic syringe to administer it to the crack. Use just a little bit and it'll weep along the crack.
He tells me the canopy comes in a complete section, he fitted it so that it fit perfectly all the way around and then cut the in half at the like Vans calls for. Has anybody ever replaced just the back half by making a template of the bad section?? or will he need to go through the entire whole canopy thing?? | Sorry, can't help with that one. One of two ain't bad!!!
linn
thanks in advance,
Ben Haas
N801BH
[url=http://www.haaspowera========================sp; - The = the many List utilities such as t================================================sp; - NEW p;content now also available via the Web&n=======================================]www.haaspowera========================sp; - The = the many List utilities such as t================================================sp; - NEW p;content now also available via the Web&n=======================================[/url]
jeffpoint
Posted: Sat Jan 13, 2007 2:15 pm Post subject: Cracked canopy |
Terry beat me to it, but I was going to recommend Weld-on 3. It's
available from Spruce or other suppliers. It's watery thin, wicks into
the crack and sets up very strong. Terry quoted my old post with more
details.
Jeff Point
RV-6 flying
RV-8 tail kit
Milwaukee
_________________ Jeff Point
RV-6
Milwaukee WI |
jpleasants(at)bellsouth.n Guest
Posted: Mon Jan 15, 2007 10:28 am Post subject: Cracked canopy |
Ben:
As a temporary fix (until a more permanent one), I know of airplanes with cracks in the windshield, still flying.
First, stop drill the crack,
put a row of 1/16 holes on each side of the crack, about 3/8 inch apart and 1/4 from the crack.
Lace with safety wire, so that it looks like a shoe lace on each side.
Apply silicone sealant on both sides of the windshield (filling the holes).
It'll last for years if necessary.
YMMV
Jim Pleasants
Posted: Mon Jan 15, 2007 1:25 pm Post subject: Cracked canopy |
Sorry Jim, but this repair will be as ugly as it gets!You did good with the 'stop drill the cracks', but after that wick some weldon (3, I think) down the crack and it'll glue it back together. I cracked my canopy on the Pitts doing a rather violent outside snap, and when I tried to line it up to put the glue on, the piece cracked completely out. I taped the piece back in as best I could and used the acrylic glue. Been that way for about 9 years now. I'm just too cheap to buy a new one!!!
Linn
Jim Pleasants wrote:
[quote] Ben:
YMMV
Jim Pleasants
| Quote: | ----- Original Message -----
From: n801bh(at)netzero.com (n801bh(at)netzero.com)
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Sent: Saturday, January 13, 2007 1:09 PM
thanks in advance,
Ben Haas
N801BH
| [b]
