sideslip(at)tiscali.co.uk Guest
Posted: Fri Jan 12, 2007 9:00 am Post subject: Mandatory mod no 72 |
Just checked on Europa's website and discovered yet another mandatory mod.
This is Mod No. 72 and involves nearly all aircraft and involves a check of the landing frame for cracks before next flight and then fitting sleeves to the frame before next permit renewal or 25 hours. This operation needs the engine to be removed.
Geoff Leedham G-EOFS
jodel(at)nildram.co.uk Guest
Posted: Fri Jan 12, 2007 10:28 am Post subject: Mandatory mod no 72 |
Given that this has been made mandatory for UK aircraft by the PFA, has anyone had any notice of this from the PFA?
Simon
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Geoff Leedham
Sent: 12 January 2007 16:52
Subject: Mandatory mod no 72
m.clews(at)sky.com Guest
Posted: Fri Jan 12, 2007 10:56 am Post subject: Mandatory mod no 72 |
You've just ruined my and many Europa pilots new year!
Looks straight forward though, thanks for drawing our attention to it Geoff,
G-OMIK
Posted: Fri Jan 12, 2007 12:00 pm Post subject: Mandatory mod no 72 |
Hi! Mike
Removing and replacing your engine is straight forward ?
I’d describe it as something different ! I guess if you say anything quickly it can be considered “straight forward”!
But I put tubes in on my initial build probably not quite to the control standard specified now though .
Perhaps our Mod Committee may like to pass comment?
Bob Harrison G-PTAG (engine out awaiting replacement !)
Robt.C.Harrison
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of m.clews
Sent: 12 January 2007 18:55
Subject: Re: Europa-List: Mandatory mod no 72
G-OMIK
carl(at)flyers.freeserve. Guest
Posted: Fri Jan 12, 2007 1:35 pm Post subject: Mandatory mod no 72 |
If its a mandatory mod, why havent Europa written to us and why havent we been sent the requisite parts. BTW are we talking about monos or trigears or both???
We had enough of this aggro when we were building the aircraft - about 60 or so mods from memory (yes, we were one of the early ones (no49!!!).
Now not so happy G-LABS.
mikenjulie.parkin(at)btop Guest
Posted: Fri Jan 12, 2007 2:04 pm Post subject: Mandatory mod no 72 |
All Europas except those with the classic engine installation
(radiators each side of the spinner) with the Rotax 912 or 912S
engine and Warp Drive ground adjustable propeller or other
propeller weighing less than 25lb (912S engine) or 28lb (912
engine) and no cracks found in the landing gear frame, or those
with landing gear frames supplied by Europa after January 2007.
Straight from the Mod leaflet.
regards,
MP
Posted: Fri Jan 12, 2007 2:13 pm Post subject: Mandatory mod no 72 |
I think we will all be notified in due course both by the PFA and Europa. Parts have to be purchased from Europa either a repair kit if no cracks found or a new complete frame if original is cracked. This mod affects all europas except some classic installations with lightweight props fitted. I suggest everyone reads the mod on Europa Aircraft website
http://www.europa-aircraft.co.uk/
ward.t(at)xtra.co.nz Guest
Posted: Fri Jan 12, 2007 2:59 pm Post subject: Mandatory mod no 72 |
Hi All,
I have the classic engine installation with the Rotax 912S.
Interesting specs, as my Airmaster Prop weighs in at 26lbs!!! except I kept the glass spinner which weighs 1 lb less than the metal one!
So that is within the specs as the cracks are not there!! Already checked it long ago when the fault was first observed .
Will do it anyway, in time.
My 1 lbs worth.
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Ph +64 3 3515166
Mobile 021 0640221
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
pete(at)lawless.info Guest
Posted: Sat Jan 13, 2007 12:53 am Post subject: Mandatory mod no 72 |
Hi Tim
The way I read the mod the 28 lb limit applied to the 912 and the limit for the 912s was 24lbs.
I am just trying to find the weight of the NSI CAP140 – it is not mentioned in the manual or any of the paperwork that came with the prop. We may end up having to weigh it.
Pete
Posted: Sat Jan 13, 2007 1:50 am Post subject: Mandatory mod no 72 |
ami(at)mcfadyean.freeserv Guest
Posted: Sat Jan 13, 2007 2:00 am Post subject: Mandatory mod no 72 |
Surprising that there is no recommendation to turn over the mount rubbers, swap top for bottom or replace.
The weight of the engine would be borne principally by the lower two of the four mount points; the upper arms would (because they yield more under load) take the "nodding" loads of the engine, plus a lesser contribution of the engine weight.
As the more heavily loaded (bottom) rubber mounts yield/creep over time, progressively more weight would be borne by the top arms.
In any case, if the spinner line has sunk below the cowl line (as is normal with time), this would be usefully reset.
Duncan Mcf.
Posted: Sat Jan 13, 2007 2:05 am Post subject: Mandatory mod no 72 |
I've received no notice and will continue to consider the mod as non mandatory until notified by the design authority, i.e. the PFA.
The PFA's website (TADS) also does not currently list this mod.
Duncan McF.
Posted: Sat Jan 13, 2007 7:47 am Post subject: Mandatory mod no 72 |
Good thinking, but should we not as a matter of good practice be replacing
all rubber parts every 5 yrs? If so this would be a smart time to replace
the engine mounts. Regards, David Joyce, G-XSDJ
kheindl(at)msn.com Guest
Posted: Sat Jan 13, 2007 8:19 am Post subject: Mandatory mod no 72 |
Carl Pattinson wrote:
Quote: | If its a mandatory mod, why havent Europa written to us and why havent we
or both???
My sentiments entirely. I always assumed that the original designers knew
what they were doing, but we are being informed at regular intervals about
one failure after another of major components.
What exactly is the point of having the PFA. They passed the Europa with
flying colours, and yet, some of the parts were obviously underdesigned. I
always thought that the engine frame looked kind of flimsy, and I guess the
nosegear frame will be next to bite the dust.
Has anyone got more details about the aircraft where this failure occurred ?
Was it a trigear, and what suspension did it have ?
Karl
MSN Hotmail is evolving – check out the new Windows Live Mail
http://ideas.live.com
Posted: Sat Jan 13, 2007 9:39 am Post subject: Mandatory mod no 72 |
Hi All
When the Europa was designed it was done by people like us, with a lot
of enthusiasm, quite a bit of experience ( think Don Dykins!) but it was
still a very steep learning curve. The early builders were sometimes
ahead of the company, at least one of them wrote parts of the manual.
Just remember very few airplanes can do what a Europa does well and
there aren't as many ADs as there are on a Boeing.
Some of these ADs, possibly Mod 72, I don't know yet, are written to
save the butts of the PFA first, Europa second, but the main reason is
to line the butts of the lawyers with even more fat at our expense. So
imho, blame the US legal system which will eventually kill most
everything it touches. Our UK lawyers are a few miles behind but
catching up.
Here in Europe nobody in a position of responsibility won't make a
decision in case someone sues them.
We might be watching the end of western civilization. Race against time,
will the planet kick us off before we wreck it?
Apologies for being cinical but that is the effect govmint has on me.
Graham
> (no49!!!).
with flying colours, and yet, some of the parts were obviously
underdesigned. I always thought that the engine frame looked kind of
flimsy, and I guess the nosegear frame will be next to bite the dust.
Karl
peterz(at)zutrasoft.com Guest
Posted: Sat Jan 13, 2007 12:04 pm Post subject: Mandatory mod no 72 |
I have to assume that it is if the same type of failure which occurred
about 1 year ago (!), and was actually posted to this list (email
below). Nobody appeared to take notice at the time. I followed up with
an email to Sam requesting a Pic, which I have attached.
I always considered that stress-point at the bracket a weak point, and
am glad that they are addressing it (if it is the same defect!).
Cheers & blue skies,
Peter Zutrauen
Europa Builder A239 dual-wing
http://europa.zutrasoft.com
Ph: 613-831-0348
Cell: 613-850-5551
-----Original EUROPA-LIST Message-----
SPurpura(at)aol.com
Sent: Saturday, January 07, 2006 9:33 PM
Subject: L.G. FRAME CRACK
During preflight today I noticed that the spinner was a little offset
and
hanging a bit low,after removing the cowl I found that the l.g. frame
had cracked
& separated just behind the port upper motor mount. I believe the crack
occured when the manifold cross-over tube was disconnected during carb
balancing
several months ago and the 914 ran so rough (with the cross-over
disconnected )
that it was shut down for fear of breaking a motor mount. If anyone
would
like to see a pic.,let me know where to post it. Sam N77EU
----- FOLLOW UP Message-----
From: SPurpura(at)aol.com [mailto:SPurpura(at)aol.com]
Sent: Sunday, January 08, 2006 8:46 PM
To: Peter Zutrauen
Subject: Re: L.G. FRAME CRACK
The pic shows the tube failed just behind the weld.
I will insert another 4130 tube/rod inside obout 4" long & tig weld the
separated member and the new reinforcment will be welded at the open end
of repaired tube. I will also do this to the starboard side.
Description: |
Filesize: |
25.95 KB |
Viewed: |
476 Time(s) |
Posted: Sat Jan 13, 2007 12:35 pm Post subject: Mandatory mod no 72 |
N77EU
A077
Sam Purpura
2250 hr build time
Rotax 914
Whirlwind CS
Monowheel
877 lbs
2002-04-22 first flight
300 Hrs as of 2004-08-13
Pete
Posted: Sat Jan 13, 2007 12:44 pm Post subject: Mandatory mod no 72 |
Ron and Peter,
This looks like another incident, caused by excessive vibration, as the mod
seems to exclude 914 installations. I wonder why the propeller weight is so
important. My original standard Warp Drive weighed a lot less than 25
pounds, and even my new cs Woodcomp weighs less than 25 pounds.
Vibration is always a potential problem; I experienced it a few times when
cold starting with the old starter motor., and the frame and bolts should be
strong enough to take that kind of punishment.
I am sure E04 will give us an update next week.
Karl do not archive
Quote: |
Posted: Sat Jan 07, 2006
9:37 pm Post subject:
L.G. FRAME CRACK
noticed that the spinner was a little offset and
hanging a
frame
had cracked
& separated
crack
during carb balancing
so rough (with the cross-over disconnected )
that it was
would
like to
Back
to top
Europa81
Forum and Gallery User
Angeles, CA, USA Kit: 81
Type: -
Status:
Flying!
11:05 pm Post
subject: Re: L.G. FRAME CRACK
Wow ! You guys keep hitting
my fear buttons lately ....
clogged fuel filters and
broken engine mounts. Whenever I
was about to fall
asleep during my ocean crossings in
N81EU the visualisation of a cracked
welding in the mount and both fuel filters closed
shut kept a poor soul
awake. For the fuel filters I had
prepared though ... 2 more new filters and
several screens
for in-cockpit replacement.
1 Filter has actually
clogged up once, but the second took over.
Worst was
the failure of the entire fuel lines provided with the
kit.
They
were simply leaking with the rubber part dissolving
during a flight.
Fortunately it was over land and ALL fuel
lines were replcaed within 2 hrs
and have kept up since.
W H A T E L S E C A N G O W R O N G ? ? Anybody needs
my wife's
eMail adress ?
happy landings,
<Thomas, N81EU>
Back
to top
Display posts from
previous: All
Posts1 Day7 Days2
Weeks1 Month3 Months6
Months1
Year Oldest FirstNewest First
EuropaOwners Forum
Index -> Europa-List
All times are
GMT - 5 Hours
Page 1 of
Watch
this topic for replies
Jump to: Select a
forum General----------------Welcome!General
Discussion Photo Gallery----------------How to
upload photos to the Gallery Matronics
Listserver----------------Europa-List Non-English
Language Area----------------Europa-Byggare/Flygare i
Norden Europa
Files----------------VendorsDocument
StorageArticles for Kitplanes
magazineEz-Trim /
Europa-Trim Buy, Sell, Trade----------------Looking
To SellLooking To
BuyFree to a good
home You can post new topics in this forum
You
can reply to topics in this forum
You can edit your
posts in this forum
You can delete your posts in this
forum
You
can attach files in this forum
You can download
files in this forum
Powered
by phpBB
© 2001, 2002 phpBB Group :: Spelling by SpellingCow.
Posted: Sat Jan 13, 2007 3:17 pm Post subject: Mandatory mod no 72 |
Which underlines a point that the description given in the E04 text for Mod
72 is off the mark. It tries to be clear about the effected area but, if
this is it, fails.
Would make inspection easier though!
Duncan McF.
Posted: Sat Jan 13, 2007 3:27 pm Post subject: Mandatory mod no 72 |
That's what Rotax recommend on the engine and is recommended generally for
things like fuel lines, but other rubber components (eg engine mounts which
have a fail safe mode) could be changed merely on condition.
I'm not changing my tyres every 5 years in the absence of any defects
otherwise!
Duncan Mcf.
