possums(at)bellsouth.net Guest
Posted: Fri Jan 12, 2007 10:49 am Post subject: Trottle cables |
At 11:07 AM 1/12/2007, you wrote:
| Quote: | << My cable pull force was high so I greased everything one part at a
time ... Vic >>
Vic - What kind of grease did you use for the throttle cables?
Dennis Kirby |
You can lubricate your choke and throttle cables without taking them off the carbs.
Part # 7435 CABLE LUBER SYSTEM - $17.95 "Prevent cable freezing and extend cable life by lubricating cable with the "Cable Luber" system. Special precision machined lube block allows ease of lubrication between cable and housing without removing the cable. Just attach the Cable Luber to either end of the cable and insert nozzle from aerosol can. Specially designed seals in block force lube down inside cable housing. A must for the serious mechanic. Cable Life Aerosol lubricates and rustproofs moving parts even at temperatures far below -50 degrees.
Buy it at a Motorcycle shop [quote][b]
