Michel
Posted: Sat Jan 06, 2007 3:03 pm Post subject: Norwegian Stalls |
On Jan 6, 2007, at 7:02 PM, Michael Gibbs wrote:
| Quote: | I think we need a picture of Michel in his cockpit with his Viking
helmet on.
Ok, I will provide that.
Meanwhile, I went flying today, did some stalls (mush down) and
listened to 'the sound.'
Unfortunately, I'll need to have someone else to fly the plane, in
order to find the cause but, so far, I wonder if it is not my elevator.
But first, a question: Is this correct?: When we stall gently (mush
down), the plane starts stalling the wings first then, if we keep the
stick in the stomach, and provided we get enough elevator authority to
get the nose up and the speed down, the horizontal stab (and the
elevator) will stall too, and the nose will drop.
If this is correct, then I think the noise I experience is happening
when the horizontal stab stalls and the elevator shakes.
Am I getting anywhere?
Cheers,
Michel
dave
Posted: Sat Jan 06, 2007 5:45 pm Post subject: Norwegian Stalls |
Michel
Did you get that post i sent in on this earlier ? Same thing bascially
that I found was a thud from the rear.
- Disturbed air from the wing hitting the horiz stab ?
I only heard this while doing deadstick stalls and headset off.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Malcolmbru(at)AOL.COM Guest
Posted: Sat Jan 06, 2007 7:36 pm Post subject: Norwegian Stalls |
every time I drink hot chocolate I get a sharp pain in my eye??
Michel
Posted: Sun Jan 07, 2007 4:13 am Post subject: Norwegian Stalls |
On Jan 7, 2007, at 2:43 AM, dave wrote:
| Quote: | Did you get that post i sent in on this earlier ? Same thing
bascially that I found was a thud from the rear.
Indeed, I read your post, Dave, and that's what led me to think about
the horizontal stab. But, at first, I thought that it couldn't be that
because, if it was, I would feel a vibration in the stick, which I
don't.
But yesterday, I noticed that when I stall, the stick is pull back to
the extend that it rests against the edge of seat (in my model 3) and
that may damp vibrations.
Cheers,
Michel
CrownLJ(at)verizon.net Guest
Posted: Mon Jan 08, 2007 5:46 am Post subject: Norwegian Stalls |
"....the horizontal stab (and the elevator) will stall too, and the nose will drop."
I don't think that this is correct. If the stab was to stall, the nose will pitch up. aka F101 Voodoo. The stab provides a downward force. The elevator will loose authority, but again can't stall as the wings do.
"...Is this correct?: When we stall gently (mush down), the plane starts stalling the wings first then, if we keep the stick in the stomach, and provided we get enough elevator authority to get the nose up and the speed down, the horizontal stab (and the
elevator) will stall too, and the nose will drop..."
You are correct that the wings "starts" to stall. Most modern planes are designed so that the wing will stall in stages. Actually, only part of the wing stalls, the other part is still flying. The plane will mush because the weight of the plane now exceeds the amount of lift that the wings can produce at that angle of attach. If you lob the nose up and gently keep 0 G on - not requiring the wings to provide any lift - it is possible to fly at 0 airspeed. Actually, you are not flying since you will not be overcoming gravity, but the airplane will not stall. You can hold 0 airspeed and still roll the wings to lower the nose letting it drop and now gently obtain airspeed. Just a hair more G than 0 and more lift is required out of the wing and it would stall at the angle of attach.
To see how the wing stalls all at once as you approach your level flight stall speed lob the nose up about 20 degrees and release the back pressure. You will notice that the IAS will be less than "normal" and the nose will drop more abruptly than "normal". This will occur because all of the wing is stalling at about the same time, instead of a part of the wing stalling.
I know that this doesn't help you find you thud, but.....
larry
Bob
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Mon Jan 08, 2007 6:07 am Post subject: Re: Norwegian Stalls |
You've written about this for quite a while, so if fabric was coming off, I'd think you would've seen something by now. As the attitude and loads change, stuff moves around quite a lot. I chased a grinding in the tailcone noise something kind of like this in a Cessna and it turned out the ELT cable rubbed on a frame as the instructors would do stalls and turns. Are you sure it's not something simple like an item rubbing the fabric? Maybe the cargo liner?
Bob
_________________ Remember that internet advice may only be worth what you pay. |
Guy Buchanan
Posted: Mon Jan 08, 2007 9:12 am Post subject: Norwegian Stalls |
At 05:45 AM 1/8/2007, you wrote:
| Quote: | "....the horizontal stab (and the elevator) will stall too, and the nose
will drop."
Sorry Larry; the stab "lifts" down, particularly with the stick in your
lap. It's most definitely possible to stall it too, after all it's only a
lifting airfoil. Most stabs don't stall because they're designed not to.
Certificated aircraft are designed to stall their wings long before the
horizontal stab stalls because were it to be otherwise you would have
really horrific landing behavior. (Picture a severe pitch over at flare
followed by a negative-g drive into the ground.) Anything's possible in
experimental land since many designers push the performance envelope
severely. All my experience with my Kitfox, however, indicates quite
normal, "certificated" behavior at all angle of attacks. I can even do the
"falling leaf" with the stick in my lap. (It really is a falling leaf,
since I have very little dihedral and my plane tends to fall off the
"bubble" to one side or the other.)
Guy
Deceased K-IV 1200
A glider pilot too. |
Michel
Posted: Mon Jan 08, 2007 2:32 pm Post subject: Norwegian Stalls |
On Jan 8, 2007, at 5:49 PM, Guy Buchanan wrote:
| Quote: | Sorry Larry; the stab "lifts" down, particularly with the stick in
your lap.
Wow, this is interesting stuff, Larry and Guy! Now, I have a friend
building a Velocity and he told me that a canard doesn't stall the
wings because the canard wings stalls first and the nose drops, hence
gaining speed.
With our Kitfoxes, the wings stalls before the horizontal stab. Makes
sense. And when our nose drops, it's because the wings stalls first
and the horizontal stab "holds" the tail up.
But when we mush down, then, what happens? Honestly, I am not sure I
know what I am talking about because "mush down" is a word I came to
know from its context, but from a proper definition.
Say, when I put the engine on idle, then gently pull the stick, trying
to keep the same altitude and watch the speed decrease to near stall
speed. At the end of it, I have the stick to the most backward
position, I feel the plane trembling, a wing or the other drops, which
I correct with a bit of rudder and aileron, to keep the ball centered,
then I can't get any slower because I sink now maybe 500 fpm. This is
mushing down, right? At that moment, the wings are partially stalled,
right? And the elevator is not? But why doesn't the nose drops then?
By the way, does anyone know the relative angle between the wings and
horizontal stabs on our Kitfoxes?
Cheers,
Michel
dave
Posted: Mon Jan 08, 2007 3:11 pm Post subject: Norwegian Stalls |
Michel, I can measure the differance if you like in degrees if you let me
know.
Also when my floats go on , I drop the front of the horiz.stab about one
inch an I fly hands free.
the angle does change but the elevator still has the same authority. As a
matter if fact i can drag the tails of the floats down the runway when
landing with gear down. The wear on bottom of the floats shows this
clearly.
I think the disturbed air from the stalled wing is hitting my tail section
some how and causing a thud. I will do further testing this week and let
you know the results - deadstick and headset off so I an hear it .
Dave
kerrjohna(at)comcast.net Guest
Posted: Mon Jan 08, 2007 3:22 pm Post subject: Norwegian Stalls |
Michael, the maneuver you have described is called "falling leaf". It is not so much a stall as operating at a point of minimum lift. My instructor made me practice it with a Super Cub at idle to ingrain in me the notion of lifting the wing with rudder rather than aileron.
John Kerr
[quote] --> Kitfox-List message posted by: Michel Verheughe
> your lap.
gaining speed.
Cheers,
Michel
Guy Buchanan
Posted: Mon Jan 08, 2007 7:32 pm Post subject: Norwegian Stalls |
At 02:28 PM 1/8/2007, you wrote:
| Quote: | At the end of it, I have the stick to the most backward
Yes. You can call it that.
| Quote: | At that moment, the wings are partially stalled,
right?
At least.
| Quote: | And the elevator is not?
Usually no. (Flat spins excepted.)
| Quote: | But why doesn't the nose drops then?
It does. The reason it doesn't drop straight down is because you've got the
stick in your lap, the horizontal stab is not stalled, so that when the
plane moves forward the tail is driven down and the nose up. Your mush may
seem to be at zero airspeed, but it's not. It is an equilibrium balance
between forward airspeed and the concomitant elevator effectiveness, and
the stall of the wings and their associated drop. If you ever achieved zero
airspeed, (say you pull nose high with no thrust,) you'll find the wings
fall through quite perpendicularly. I can't remember what the aerobatic
term for it is as the Decathlon I used wasn't allowed to back-slide at all.
My instructor would never let me achieve "zero" airspeed.
Guy
Deceased K-IV 1200
Posted: Tue Jan 09, 2007 9:06 am Post subject: Norwegian Stalls |
| Quote: | subject: Re: Re: Norwegian Stalls From: Guy Buchanan (bnn(at)nethere.com ([email]bnn(at)nethere.com?subject=Re:%20Re:%20Norwegian%20Stalls&replyto=6.2.1.2.0.20070108082934.0299a698(at)pop3.nethere.net[/email])) Date: [b]Mon Jan 08 - 9:12 AM[/b] | Quote: | | Quote: | At 05:45 AM 1/8/2007, you wrote:
will drop."
Guy, I think that we are saying the same thing - the stab provides downward lift,it is design NOT to stall. If it were to stall, there would be no way to get it flying again, short of a parachute. The F101 Voodoo had a stab placement wherebyit was quite easy to stall. The result was usually the crew ejecting, as the nose would pitch up and the was no way to recover it with the airplane controls. The method was topull the landing drag chute in hope that would point the airplane down again toget air over the tail to get it flying again. Usually there was not enough altitudeto successfully recover. I totally agree with you that most though it is possible to stall the stab, most airplanecan not because of the design. It is impossible to stall the stab in the Kitfox, asit is design NOT to stall. If it were to stall, there would be no way to get it | 0 | Quote: | | it is design NOT to stall. If it were to stall, there would be no way to get it | 1 | Quote: | | it is design NOT to stall. If it were to stall, there would be no way to get it | 2 | Quote: | | it is design NOT to stall. If it were to stall, there would be no way to get it | 3 | Quote: | | it is design NOT to stall. If it were to stall, there would be no way to get it | 4 | Quote: | | it is design NOT to stall. If it were to stall, there would be no way to get it | 5 | Quote: | | it is design NOT to stall. If it were to stall, there would be no way to get it | 6 | Quote: | | it is design NOT to stall. If it were to stall, there would be no way to get it | 7 | Quote: | | it is design NOT to stall. If it were to stall, there would be no way to get it | 8 |
Guy Buchanan
Posted: Wed Jan 10, 2007 7:14 am Post subject: Norwegian Stalls |
At 09:01 AM 1/9/2007, you wrote:
| Quote: | Is this how you see it?
Yep.
Guy Buchanan
Deceased K-IV 1200
Michel
Posted: Thu Jan 11, 2007 11:27 am Post subject: Norwegian Stalls |
On Jan 9, 2007, at 12:08 AM, dave wrote:
| Quote: | Michel, I can measure the differance if you like in degrees if you
let me know.
Yes, please. For your information, in my flight simulator, the
difference between the AoA of the wing and the horizontal stab is 5
degrees i.e. +4 for the wing at the root, and -1 for the stab. The wing
has wash-out, the stab has not. Thanks, Dave!
On Jan 9, 2007, at 12:19 AM, kerrjohna(at)comcast.net wrote:
| Quote: | Michael, the maneuver you have described is called "falling leaf".
Hum, I am not sure my stall goes all the way to "falling leaf," John,
because I still have much forward speed but, thank you, "falling leaf"
is a nice and poetic term.
On Jan 9, 2007, at 4:26 AM, Guy Buchanan wrote:
| Quote: | The reason it doesn't drop straight down is because you've got the
It makes sense, Guy, but then ... the sound can't be my elevator and
horizontal stab stalling, right?
On Jan 9, 2007, at 6:01 PM, Larry Martin wrote:
| Quote: | From Micheal's description, I had the impression that he
thought that the nose dropped because the stab stalled. This is not
correct. The
nose drops because the center of pressure on the wing moves forward.
.. err, you mean 'move aft‚' Larry, right? If the center of pressure
moves forward and the CoG stays hopefully the same, the moment is then
to create a nose-up attitude.
This is interesting because years ago, before I started flying for
real, I had that discussion with a flight simulator group where I meant
to center of pressure (a.k.a center of lift) moved back as the plane
slows down, hence the need to pull the stick. My assumption was based
on the fact that a sailboats attempting to sail close to the wind (i.e.
small AoA) needed to pull something called 'Cunningham hole' in order
to make the leading edge stiffer and move the deepest hollow of the
sail more forward - a sail being a "soft" airfoil.
But I was told that the center of lift never moves on a wing, and that
it is usually at about 1/4 of the cord, from the leading edge.
Cheers,
Michel
dave
Posted: Thu Jan 11, 2007 7:09 pm Post subject: Norwegian Stalls |
Michel ,
I did measure it a few days ago and off the top of my head both
measurements were the same .
I measured the horiz stab in a few places and measured the bar between the
2 wing struts that runs parallel to the bottom of wing approx.
Both were about the same -wing strut and bottom of the wing as well as the
horizontal stab.
Now Like I said when floats go on I drop the front of the horiz.stab about
a inch at the front and that seems to compensate for the extra drag of the
floats. I would only guess that that would be a few degrees difference then
between the wing and horiz.stab.
Understand that mumble jumble ?
I can measure better tomorrow.
Dave
Guy Buchanan
Posted: Thu Jan 11, 2007 8:24 pm Post subject: Norwegian Stalls |
At 11:27 AM 1/11/2007, you wrote:
| Quote: | It makes sense, Guy, but then ... the sound can't be my elevator and
No. I think the sound is fabric slapping against the wing tanks.
correct. The
... err, you mean 'move aft‚' Larry, right? If the center of pressure
Yes and No. You were correct in stating that the SYSTEM Cl moves back,
whereas the wing Cl remains constant before stall. (It moves after stall,
quite dramatically.) The reason the SYSTEM Cl moves back when you slow is
that down force on the tail diminishes as you slow, (remember lift is
proportional to the square of the velocity,) whereas the pitch moment due
to mass remains constant. You balance the mass pitch moment by increasing
the tail's down force by pulling the elevator up, increasing the tail's
negative Cl in direct proportion to the reduction in the square of the
velocity.
Too confusing. Try this. I have a "wing" with 40 units of lift. 10 length
units behind that "wing" I have a "tail" flying along with -4 units of
lift. (It lifts down.) To balance this system my "airplane" weighs 36 units
and it's CG is 1.11 length units in front of the "wing". Now I
instantaneously slow by half. My "wing" and "tail" lift reduce to 10 and -1
units respectively. (Lift is proportional to the square of the velocity.)
However the weight is still 36 at 1.11 in front of the wing. Now there is a
30 unit moment pitching down. To counteract that I have to increase the
"tail" lift back to -4 units. I therefore have to quadruple the Cl by
pulling the elevator up. I then have 10 units of lift on the "wing", -4
units of lift on the "tail", and 36 units of weight 1.11 in front of the
wing. The system balances about the wing, but I have 36 units of weight
versus 14 units of lift and so am accelerating down quite rapidly. (I'll
accelerate down until the increased wing angle of attack (Cl) and the
increased velocity bring the "wing" lift back to 40 units.) Note that with
a "wing" lift of 10 and a "tail" lift of -4, the SYSTEM Cl is
instantaneously quite far aft of what it was at equilibrium, when the
"wing" lift was 40.
There. Clear as mud.
Guy
Deceased K-IV 1200
Michel
Posted: Fri Jan 12, 2007 1:08 am Post subject: Norwegian Stalls |
| Quote: | From: Guy Buchanan [bnn(at)nethere.com]
Thank you, Guy. Clear as spring water. What you wrote is exactly what I was told, years ago. My posting was only as a comment on Larry who says the center of pressure of the wing moves forward.
Dave, if you can be bothered to measure accurately the AoA, thank you very much. The reason I don't do it myself is that I should rig something with a level and an angle measuring device. Then, we also need to refer to a common definition. I think AoA are always measured from the cord, which is an imaginary line going from the leading edge to the trailing one. But ... how do you get then on a built wing? My idea was to use a water hose and measure the difference at the two points. arctan(difference/cord) should then give me the AoA. My problem is that I always think about doing that in the winter, when it is sub-zero temperature, here!
Cheers,
Michel
dave
Posted: Fri Jan 12, 2007 2:59 am Post subject: Norwegian Stalls |
Michel,
I only compared the two with a inclinometer.
I possibly could attach a straight edge to the horiz stab and run it
forwards under the wing and
note the differences at the front and rear of the wing.
Would this help you ?
Dave
PS how about a wingwalker tied on to top of plane? Maybe he/she could have
bird's eye view to what is causing this mystery noise ? How about a
camcorder on tail?
lcfitt(at)sbcglobal.net Guest
Posted: Fri Jan 12, 2007 7:00 am Post subject: Norwegian Stalls |
Guy, when I was building I was watching a couple of guys that were ahead of
me in the process and the tops of their tanks looked marbelized because of
the occasional fabric contact with the wing tanks. Where it touched and
where it didn't looked entirely different in paint - sort of ugly.
I went to lots of trouble ensuring that there was no paint adhesion on the
tank top fabric. I have had others fly close by and evaluate ballooning and
they said they saw none. But the real reason for the post is that my stalls
are virtually silent. I do, however have the IV wing while Michel has the
III.
Lowell
>correct. The
>... err, you mean 'move aft,' Larry, right? If the center of pressure
velocity.
units and it's CG is 1.11 length units in front of the "wing". Now I
and -1 units respectively. (Lift is proportional to the square of the
velocity.) However the weight is still 36 at 1.11 in front of the wing.
Now there is a 30 unit moment pitching down. To counteract that I have to
increase the "tail" lift back to -4 units. I therefore have to quadruple
the Cl by pulling the elevator up. I then have 10 units of lift on the
"wing", -4 units of lift on the "tail", and 36 units of weight 1.11 in
front of the wing. The system balances about the wing, but I have 36 units
of weight versus 14 units of lift and so am accelerating down quite
rapidly. (I'll accelerate down until the increased wing angle of attack
(Cl) and the increased velocity bring the "wing" lift back to 40 units.)
Note that with a "wing" lift of 10 and a "tail" lift of -4, the SYSTEM Cl
is instantaneously quite far aft of what it was at equilibrium, when the
"wing" lift was 40.
Guy
rjdaugh
Posted: Fri Jan 12, 2007 9:31 am Post subject: Norwegian Stalls |
Michel,
I don't think you mean AOA, angle of attack. AOA is measure relative to the
air. Hard to measure without the right instruments.
I think you mean angle of incidence? Someone will step in with the right
term..
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
