Dwayne
Posted: Fri Dec 22, 2006 11:17 am Post subject: Over-torqued GSC Prop |
Has anyone had any sucess in shimming an apparently over torqued GSC three blade on 912... ie; no gap, blades will start going out of pitch in 30-40 hours. Someone has likely been sucessful in shimming this prop. I know this may sound dangerous but it could be done safely too....
flier(at)sbcglobal.net Guest
Posted: Fri Dec 22, 2006 3:00 pm Post subject: Over-torqued GSC Prop |
I just ordered new blades from GSC as I've had my prop now for 10 years.
The first question they asked when I inquired about the prop was whether
there was a gap in between the hub halves. If there's not a gap, there's no
question that the blades should be replaced.
IMHO, don't screw around trying to shim. If the hub isn't holding the
blades, replace the blades. Slinging a blade could end up killing you when
the engine comes off. A set of 3 new blades is $450. Very cheap insurance.
Ted
roncarolnikko(at)hotmail. Guest
Posted: Fri Dec 22, 2006 5:18 pm Post subject: Over-torqued GSC Prop |
Might be better off milling, filling, or sanding off some of the aluminum at
the parting edge. Ron NB Ore
| Quote: | From: "Dwayne" <dwaynemccourt(at)yahoo.com>
Subject: Over-torqued GSC Prop
Date: Fri, 22 Dec 2006 11:17:15 -0800
http://forums.matronics.com/viewtopic.php?p=83056#83056
crazyivan
Posted: Fri Dec 22, 2006 6:24 pm Post subject: Re: Over-torqued GSC Prop |
If the aluminum clam shells are touching then that means that the wooden blades have been crushed at their roots...very bad! Sanding, milling, shimming, or filing the aluminum will only make the prop more dangerous! Do not try to jerry-rig a fix. Remove it, send it to GSC, and have them evaluate it.
Throwing a prop and crashing because you did your own make-shift maintenance is not only bad for your health and insurance premiums, but it is another argument people can make against experimental aircraft.
_________________ Dave
Piper PA-22/20 |
davedawe(at)msn.com Guest
Posted: Sat Dec 23, 2006 6:39 am Post subject: Over-torqued GSC Prop |
Merry Christmas to all!
[quote] From: dwaynemccourt(at)yahoo.com
--> Kitfox-List message posted by: "Dwayne" <dwaynemccourt(at)yahoo.com>
&g'http://ideas.live.com/programpage.aspx?versionId=5d21c51a-b161-4314-9b0e-4911fb2b2e6d' target='_new'>Windows Live Mail.
Dwayne
Posted: Sun Dec 31, 2006 2:42 pm Post subject: Re: Over-torqued GSC Prop |
Thanks to everyone for their input. Its finally good to at least get some response here. I have sought information in the past on seemingly vague Kitfox questions, ie; torque specs, etc that should have been in the build manuals but never got a response here.
IMO, even though I have owned 4 Kitfox- 2--M4-912 Speedsters, M3 and M2 -582 for 600 hrs. Kitfox kits and parts are, or at least were, just crazy overpriced. .......... However well built two -strokes for $15K and 912s for $25K are good deals...... Just glad that I haven't paid the big bucks for a kit, put all the hours in building then see that when then need comes to sell- --------you've thrown away half of your money and all of your time.........BTW crazyivan, what does "experimental" mean?
crazyivan
Posted: Sun Dec 31, 2006 9:20 pm Post subject: Re: Over-torqued GSC Prop |
Dwayne...sarcasm?
Experimental means you can do whatever the heck you want to to your airplane...as long as it remains airworthy. Flying with a damaged prop or with a damaged prop and speculatively modified hub would not be airworthy according to my (sometimes less than) humble amature, experimental opinion.
Piper PA-22/20 |
369PL
Posted: Wed Jan 10, 2007 6:22 pm Post subject: Re: Over-torqued GSC Prop |
Is there a minimum space? Maybe it could be checked with feeler blades. Does anyone know what the spec is? or is enough to say there is a space?
crazyivan
Malcolmbru(at)aol.com Guest
Posted: Wed Jan 10, 2007 7:14 pm Post subject: Over-torqued GSC Prop |
call gsc they told me about over torking and shims for tracking. they are nice to talk to . mal
Float Flyr
Posted: Thu Jan 11, 2007 5:51 am Post subject: Over-torqued GSC Prop |
Check out this page... Most of your questions will be answered here
http://www.ultralightprops.com/technical.htm#What%20is%20the%20recommended%2
0torque%20on%20all%20the%20bolts?
If the link doesn't work it's probably because the "?" question mark is
supposed to be part of the URL. You may have to cur and paste it into your
location bar.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave
Posted: Thu Jan 11, 2007 6:58 am Post subject: Over-torqued GSC Prop |
GSC prop.
If there is No space then the blade root ends have been crushed, squished or
comprimised.
I would strongly suggest that you not shim it but call Rick Peters at GSC
and replace those blades.
Did some one say GSC said to shim them ?
If interested I will post you pics of broken GSC blades at the ROOT .
I have first hand experience on blade departures and you do not want to be
there when it happens.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Fox5flyer Guest
Posted: Thu Jan 11, 2007 7:39 am Post subject: Over-torqued GSC Prop |
Was the blade that departed a GSC?
Deke
dave
FLIER(at)sbcglobal.net Guest
Posted: Thu Jan 11, 2007 8:53 am Post subject: Over-torqued GSC Prop |
Ouch! Now if that won't make you think I don't know
what will.
I have new blades on the way for my GSC. It's 10yrs
old which is about 7 yrs beyond GSC recommendations.
I got my monies worth. It still *appears* in
excellent shape and I do have space in between the
hub halves but $450 for new blades is a lot cheaper
than a 912, 912 mount, or my life (some say anyway)!
I'm seriously thinking I'm gonna add some retention
cables to my engine...
Ted
--- Original Message ---
Subject: Re: Re: Over-torqued GSC Prop
<dave(at)cfisher.com>
Yes -- A wooden GSC I saw last year .
Was near me but not me. I welded him up a new
engine mount and replaced
| Quote: | the Engine and gear box.
Luckily he took off as normal but something seemed
not right so he landed
| Quote: | and was taxing up to hangar when it departed. He
told me his 503 was about
| Quote: | 4000 rpm max as he taxied up and BOOM blade flew
off . Engine did the
| Quote: | boogie -ripped the engine mount apart and broke the
lower cowl which I
| Quote: | repaired as well for him .
Deke , you justd got me busy fora minute i
hade you a quick page on
[quote]the GSC Wooden Blade that Departed
http://www.cfisher.com/gsc/
Dave
Fox5flyer Guest
Posted: Thu Jan 11, 2007 9:20 am Post subject: Over-torqued GSC Prop |
Thanks Dave. That's the first failed GSC that I'm aware of, but I don't
travel much outside this list. Was the factory made aware of the failure?
Are you sure it was caused by over torqueing? I'm sure the factory would
like to have a look at it.
Deke
lcfitt(at)sbcglobal.net Guest
Posted: Thu Jan 11, 2007 10:54 am Post subject: Over-torqued GSC Prop |
I don't have a GSC prop, but his discussion raises a couple of questions.
1) does the GSC blade have a knob at the base to be retained in a similarly
shaped cavity in the hub?
2) If so, and I suppose it does, how can over tourquing result in blade
failure. At first glance, I suspect it would result in an inability to
retain pitch and maybe tracking. And if seriously abused maybe wobble.
I suspect properly torqued prop might vary in tightness due to humidity and
temperatures. With the failed blade mentioned, I doubt it happened solely
because of torquing issues.
Lowell
barry(at)pgtc.com Guest
Posted: Thu Jan 11, 2007 12:46 pm Post subject: Over-torqued GSC Prop |
Ted and all, you should also order the newer hub that has one of the prop
bolts going through each blade. I saw some small splits in two of the
blades after about 200 to 300 hours and got all new everything. Now up to
about 500 hours and no problems.
Barry West
Float Flyr
Posted: Thu Jan 11, 2007 12:57 pm Post subject: Over-torqued GSC Prop |
Lowell:
The GSC prop has either an aluminium root or an aluminium collar on the
root. They also have a slot cut in them for a retaining bolt that actually
passes right through the blade. They have been known to crack/depart but as
far as I know only after the GSC recommended TBO. That is 5 yr or 500Hr.
Which ever occurs first. I'm sure many are in service a lot longer than
that.
I first flew my plane on a 15 yr. old three blade GSC prop that only had the
high side of 100 hr. on it. I contacted GSC and the rep on the phone
recommended that I not fly the blades.. He offered me a pretty good
discount on a new set of blades which were in stock.
I went with the Ivo because I wanted the in flight adjustable. The GSC
adjustable which I think is a superior unit unfortunately won't fit on my
"B" box.
Noel
[quote] --
Kitfox III-A
Posted: Thu Jan 11, 2007 1:20 pm Post subject: Over-torqued GSC Prop |
Lowell and all, I believe the older props actually had the hub squeezing the
base of the wood blades.
for the newer ones and the one I now have the base end of the blades sit in
an aluminum cylinder with grooves machined in them and a hole, actually a
slot, through them. One of the hub bolts goes through the slot in the
aluminum and through the wood. Torqueing the bolts squeezes the aluminum
base. It would not be impossible for a blade to break anyway but careful
inspection during preflight looking for any small splits or other problems
should go a long way toward preventing unexpected failure.
Barry West
